Remora for RP2040
12 Aug 2024 20:18 #307589 by Limo
Replied by Limo on topic Remora for RP2040
I don't want to seem intrusive. But does anyone have an idea and could help?
  • scotta
  • Platinum Member
  • Platinum Member
12 Aug 2024 20:38 - 12 Aug 2024 20:38 #307592 by scotta
Replied by scotta on topic Remora for RP2040
Hi, maybe this thread could help
Lathe Spindle control with step/dir - LinuxCNC
Last edit: 12 Aug 2024 20:38 by scotta.
12 Aug 2024 22:40 #307599 by cakeslob
Replied by cakeslob on topic Remora for RP2040
limo, I saw you in the discord the otherday I think, you arent using the rp2040 right?
Is remora capable of doing it? Most likely, so long as you stay within the parameters of the remora board you are using, by which I mean, if your stepgen steprate is too high, remora might not be able to accommodate. Otherwise it sounds like a standard affair, as just configuring a stepgen.
Do we know how to configure a spindle with step/dir with remora? I dont personally. The bulk of it will be linuxcnc, and we can help you with connecting to remora
13 Aug 2024 09:24 #307620 by Limo
Yes, that was probably me over on Discord.
In terms of hardware I wanted to use the 2040 because it is rather cheap and I can get it pretty easy.
I have managed to make a spindle work with stepgen in the past. I am just a little unsure how to connect it to remora. My thought is that in remora I just add a velocity joint in addition to my other joints/linear axis. And then connect the spindle.0.speed-out-rps to the remora.joint.0.vel-cmd. But I think I got a little confused with what an actual joint is in linux-cnc.
That thread what scotta linked was actually from me.
If I notice that remora with rp2040 can't obtain the step rates it is cheap "fail", and then I will investigate other options.
Thank you.
13 Aug 2024 14:27 #307637 by cakeslob
We would probably need to do some math to verify that it can provide the step speeds you need for all axis. I saw you mentioned something about an encoder, but rp2040 cannot do encoders if thats also what you need.
13 Aug 2024 17:38 #307644 by Limo
Encoder support is also something I am looking to have. Then the rp2040 is then probably not the best option any more. How can I estimate the performance in terms of drive frequency for the axis?
13 Aug 2024 23:06 #307680 by cakeslob
I think this is how to do the math for the axis timing, im fairly sure its the same idea
linuxcnc.org/docs/devel/html/motion/twea...ose_your_base_period
If encoder support is what you need, the rp2040 does not support encoders at this time, and im not sure if it will or what its limits will be. the RT1052 will probably be your best bet if you want something ethernet
14 Aug 2024 08:32 #307704 by Limo
I have looked through the remora documentation and there are software encoders mentioned with a frequency up to 30kHz. If I get close to that number with a rp2040 I am fine with that. That would result in theoretical encoder resolution to roughly 360ppr with 5k rpm and 30kHz max input frequency. It is just the question if the pi2040 is up to the task of handling these things
  • scotta
  • Platinum Member
  • Platinum Member
14 Aug 2024 20:43 #307743 by scotta
As Cakeslob mention, the RP2040 fork does not currently have encoder (software or hardware) support. It wouldn't take much to port over the software encoder module to the RP2040 though. Limited to base thread frequency.
github.com/scottalford75/Remora/tree/mai...-OS5/modules/encoder
If someone was keen they could also potentially look at the PIOs to increase the capable frequency.
github.com/p-o-l-e/quadrature-decoder
14 Aug 2024 22:14 #307752 by Limo
How much effort in programming skills are needed, to implement the hardware encoder support with the PIO? And where is the best place to start. To be honest I am not very familiar with linuxcnc let alone remora. If it is within my capabilities I would really want to get a go at it. I would really appreciate if someone can point me in the right direction where to start looking.
Time to create page: 0.342 seconds
