Remora for RP2040
- 3404gerber
- Thank you received: 14
14 May 2026 06:06 #346387
by 3404gerber
Replied by 3404gerber on topic Remora for RP2040
Hi eraserhd,
Can't wait to see your working PIO. On my side I managed to move a Tmc5160 stepper driver in full Spi mode in Remora, so no step generation needed for this specific driver (could, in theory, run 6 axis or more from a Tiny2040 ). I didn't go further than a PoC test. (Moved to a CANopen test with LCNC)
Cheers
Cheers
- scotta
- Thank you received: 489
16 May 2026 21:49 #346448
by scotta
Replied by scotta on topic Remora for RP2040
cbaugher has shared is RP2035 version which used remora-core. A really neat implementation that has both ethernet and spi communication options. Uses PIO for the SPI and hardware QEI (Quadrature Encoder Interface).
github.com/cbaugher/Remora-RP2350-PIO/tree/main
The following user(s) said Thank You: tommylight, 3404gerber
- 3404gerber
17 May 2026 08:55 #346452
by 3404gerber
I had a quick look at the PortingPlan.md. Am I right to presume that this was AI assisted coding? It's insane how this thing is a game changer for non coder; I have some understanding of coding, read a lot of source code, but am not able to write more than a couple of functions to adapt an existing code (and even that part is mainly copy-pasting form existing libraries). Yet, within three days had a CANopen motor connected to a RPi spinning smoothly in CSP mode. I wouldn't say with Claude-code's help, but rather than Claude-code had it working with some of my contribution for hradware connection and debugging.
Back to the topic, I think that eraserhd is one the right path when trying to generate pulse from PIO. Guess that's just a prompt more for the RP2350-(not PIO as it was there for Platform-IO, right?). The stepper-ninja for LCNC claims a 1MHz per channel step generator using PIO.
Cheers
Cheers
- kb9ydn
19 May 2026 02:21 #346489
by kb9ydn
It is AI assisted, Claude in fact! And yes, Claude did basically all of the actual coding based on existing work. I did have to do a fair bit of flashing binaries and scoping pins for voltages and timing. And it does need some guidance for how to fix issues that come up. It seems very good at writing code given enough direction. But it doesn't necessarily know which way to do things when there are multiple options available. It can also go off on tangents when troubleshooting complex problems. That said, it saves an unbelievable amount of time. I do have quite a few years of hobby programming experience in a number of contexts, but I've never been a professional programmer. I'm more into hardware hacking. So indeed, AI assisted coding is literally game changing for less than great programmers!
C|
Replied by kb9ydn on topic Remora for RP2040
C|
- eraserhd
02 Jun 2026 14:56 #346852
by eraserhd
Replied by eraserhd on topic Remora for RP2040
Nice!
I did get PIO working and made a pull request . I hadn't announced it yet because I want to stress the heck out of it, and I just ordered a PCB that will form a hardware test harness for it. It seems like it will work well, but I want to make sure that when six axes are chugging along full speed, the scheduling doesn't slip or lock up.
It theoretically should be capable of 200KHz stepping, but again, I haven't stressed it yet.
I bought the WIZNet RP2350 board as well. One of my pull requests should in fact work on it, but I haven't tried it. I'll check out this code soon!
Hey @scotta , any chance we can get some of the other PRs merged? They are starting to stack. #12, #14, #15, and #17 should all be good to merge, and #11 could be closed if #15 is merged. (The forum won't let me link the PRs.)
- Mars
28 Jul 2026 17:46 #348141
by Mars
Replied by Mars on topic Remora for RP2040
I am not a regular on the linuxcnc forum so please bear with me if I am not following the protocol/etiquette. The Remora RP2040-w5500 looks like a great approach to a cost effective linuxcnc setup. It is hard for me to understand how stable the current software/design is. Are people using it routinely or is it still being developed? About a year ago I started down the Remora path with one of the 3D printer stepper boards only to find out that the on-line documentation was not up to date. I appreciate how complex this project is and can understand if it is not ready for prime time. TIA.
- CNCJIM
28 Oct 2026 22:46 #350520
by CNCJIM
Replied by CNCJIM on topic Remora for RP2040
From what I understand - this doesn't have configuration and hal files to match just yet - bit as Mars mentioned it is a complex project - but a cost effective linuxcnc solution would be a big plus to the community. I was considering building an STM32F446 or an STMF32F7xx custom card with a LAN9252 Microchip to use as an EtherCAT controller. This setup might be a lot less expensive overall. Once your team is ready to introduce the wider community to Remora for RP2040 that would be great. I also apprecieate the complexity - and the "small team" working out the details.
Time to create page: 0.175 seconds
