Remora for RP2040
2 years 3 months ago #305736 by scotta
Replied by scotta on topic Remora for RP2040
Ok, some more investigation. Using the publish uf2 file and your config I confirm the issue. I've recompiled my master branch which had some unpublished clean-ups (debug info) from the ping-pong buffer implementation, and your config happily loads and runs.
I've also added a firmware folder to the repo to make finding the uf2 file easier.
github.com/scottalford75/Remora-RP2040-W...ora-rp2040-1.0.1.uf2
I'm working on making the RP2040 version compatible with the latest LinuxCNC Remora ethernet component, but currently this version still uses the legacy remora-nv component.
2 years 3 months ago - 2 years 3 months ago #305739 by scotta
I've migrated the Remora for RP2040 to now use the Remora-eth-3.0 component.
Download the latest firmware
github.com/scottalford75/Remora-RP2040-W5500/tree/main/firmware
Upload the remora-rp2040-2.0.0.uf2 file to your pico.
To configure the linuxcnc hal module and configs use the files here:
Hal Files (run halcompile on these)
github.com/scottalford75/Remora-RT1052-c...omponents/Remora-eth
and the configs:
github.com/scottalford75/Remora-RP2040-W...onfigs/remora-rp2040
Last edit: 2 years 3 months ago by scotta. Reason: typo
The following user(s) said Thank You: Baazengr, avive
2 years 3 months ago #306310 by avive
Replied by avive on topic Remora for RP2040
Is it possible to work with rp2040 via uart instead of Ethernet? Is the bandwidth and response time enough? I'm considering a variant of sbc on Intel n100 with rp2040.
2 years 3 months ago #306440 by scotta
No, even at high baud rates, serial is just not fast enough.
The following user(s) said Thank You: avive
2 years 2 months ago - 2 years 2 months ago #306940 by Bari
Replied by Bari on topic Remora for RP2040
Shipping soon:
linuxgizmos.com/w55rp20-evb-pico-integra...ntroller-and-rp2040/
W55RP20-EVB-PICO: Integrating W5500 TCP/IP Controller and RP2040
[img
Last edit: 2 years 2 months ago by Bari.
2 years 2 months ago - 2 years 2 months ago #307379 by Bari
$5 Raspberry Pi Pico 2 with RP2350 Microcontroller
linuxgizmos.com/introducing-the-5-raspbe...350-microcontroller/
Now we need them to combine the newer 2350 with the W5500.
Time to create page: 0.451 seconds
