Error in ArcBuddy
13 years 1 week ago #40213
by Sterling
Until I placed G21 near the bottom of the code, once the drilling was done for the peg-holes, and just before the edge cutting for the borders...wasn't aware that you could 'mix' the two.
Replied by Sterling on topic Error in ArcBuddy
But...I had G20 in my preamble.BigJohnT wrote: What I was hinting at was you needed a G21 in your preamble...
JT
13 years 1 week ago #40225
by BigJohnT
Replied by BigJohnT on topic Error in ArcBuddy
Probably not a good idea to mix inch and mm G code in the same file just to minimize the possibility of mistakes. If by "mix" you mean on the same line, no that is not possible as both are in the same modal group.
I downloaded Qcad and the export cam button doesn't seem to do anything. How did you get it to export the G code?
JT
JT
13 years 1 week ago #40254
by Sterling
Howdy -
By 'Mix' what I did is set the G20 in my Preamble. Then about 1100 lines of code later, to cut out the actual triangle, I popped in the G21.
I have not tested this yet, but it looks good on screen.
CAM export.
I presume you've clicked on the [CAM] menu option...?
...and nothing happens?
My first guess is that the time has expired regarding your 15min activation. Before you try the export, Look in the lower right for the following =
The 'Properties Window' may be in the way, preventing you from seeing this. If these are green, you're good to go. If not, you must SAVE THE FILE, exit the program, re-open the file, THEN export.
CAM export.
13 years 1 week ago #40255
by BigJohnT
Are you running Qcad in windoze or Linux? Yea, I had three green's and tried selecting the circle then clicking on export. Does a prompt come up to get any info before the G code file is created?
JT
JT
13 years 1 week ago #40256
by Sterling
13 years 1 week ago #40257
by BigJohnT
I didn't get it to work in Linux, so I was testing on XP. If if will do a decent job of generating a profile it will be a time saver for me on plasma.
JT
JT
Time to create page: 0.308 seconds
