Error in ArcBuddy
13 years 2 weeks ago - 13 years 2 weeks ago #39885 by BigJohnT
Replied by BigJohnT on topic Error in ArcBuddy
The ArcBuddy now works fine. There is a feature if you open arcbuddy.py in axis the Quit button changes to Sent to Axis and Quit. The Send to Axis and Quit feature seems to be broken now. Something must have changed in Axis. The current version 1.3 will work except for this feature.
Just download the current one from the wiki.
JT
Last edit: 13 years 2 weeks ago by BigJohnT.
The following user(s) said Thank You: Sterling
13 years 2 weeks ago #39888 by Sterling
Replied by Sterling on topic Error in ArcBuddy
Awesome deal, THANX~!!!!
I am heading out of town today, but will give it a shot when I get back next week!
Just an FYI, (which you most likely already know) is that when I selected [Show Me] then [Copy to Clipboard] then [Quit] the text would not save in memory and I could not copy it to the file I am working on.
What I would do is select [Copy to Clipboard] then [Alt+Tab] to the file, copy in the Arc data, [Save] the file, *then* I'd quit Arcbuddy.
...I don't know if that was/is normal or a byproduct of what was wrong.
Thanx again!!!
13 years 2 weeks ago - 13 years 2 weeks ago #39891 by BigJohnT
It appears that the text copied to the clipboard only stays in the clipboard when arcbuddy is running. Must be an undocumented feature of Tk clipboard_append. I don't use Tk anymore and prefer using Gtk now for many reasons like this one.
Let me know how it works out for you.
JT
13 years 2 weeks ago #39892 by Sterling
Well...due to time constraints, I can't run the machine today. however, I was able to download the new file and give it a try.
Unfortunately, I again received an error... (as posted in image below)
I'm a PC/Windows user and am slowly understanding/learning Linux. Am I doing something wrong?
13 years 2 weeks ago #39893 by BigJohnT
Post a screen shot of ArcBuddy with the fields filled in.
JT
13 years 2 weeks ago #39894 by Sterling
Howdy -
Here you are. Opened it up, and typed them in...
Time to create page: 0.355 seconds
