Error in ArcBuddy
13 years 1 week ago #40258 by Sterling
Replied by Sterling on topic Error in ArcBuddy
I just loaded it and gave it a go = it worked fine in Linux for me as well.
Hmmm...Do you know which version you downloaded? I used the Linux 32-bit Installer (First button under the Linux area) = Download Page
I'm not a Linux guy, and have no idea how to tell if you have a 32 or 64 bit system. (In fact installing this program was when I learned how to execute a RUN file...)
Maybe it is a 'Permission' setting?
13 years 1 week ago - 13 years 1 week ago #40259 by BigJohnT
Replied by BigJohnT on topic Error in ArcBuddy
3.4 and Cam show active. I just tried it on this windoze and the Ubuntu 10.04 next to it and nothing happens when I click on export cam.
I see Command: camexport on the command line when I click the button... but nothing.
Cam Import however works well...
JT
Last edit: 13 years 1 week ago by BigJohnT.
13 years 1 week ago #40267 by Sterling
Well...that's interesting. :dry:
If I were encountering this problem, I would...
#1) Ensure that ALL versions were uninstalled
#2) Reboot the computer
#3) Re-install the software (Possibly using a different file = meaning if you used the 'Installer' for your WinXP machine, try the ZIP file instead, etc...)
...if that didn't work...I'd start looking for help on-line; this is new to me as well~!
13 years 1 week ago #40268 by Sterling
I looked up their User Forums and did a search regarding "CAM Export". I turned up nothing that would help. :(
13 years 1 week ago #40285 by BigJohnT
Replied by BigJohnT on topic Qcad CAM
I looked in scripts/Cam/CamConfigurationsGCode.js and it has an include for scripts/Cam/CamExport/CamExporter.js and neither the tar or the installed have that file. That may be the problem.
13 years 6 days ago #40310 by BigJohnT
I got on the Qcad forum and the latest update fixes the missing files.
The machine file GCode converts to mm. There is supposed to be a machine configuration file GCodeInch but it is lost too. I'm going to try and create a LinuxCNC machine configuration file.
JT
Time to create page: 0.306 seconds
