Rigid Tapping Help
8 years 3 months ago - 8 years 3 months ago #114504 by NCPatrol
Rigid Tapping Help was created by NCPatrol
I'm slowing delving deeper in to my mill's functionality. I bought it from someone else that built it so I'm a little behind the curve on a lot of things...
I'm using Fusion to make drill/tap operation. In fusion, it simulates fine but when I run it on the mill it goes through the to drill operations and then gets to tapping, moves Z and then stalls at line N455 and doesn't actually tap...spindle is rotating but Z isn't moving.
This is the tapping portion of the code:
(DRILL2) N405 M9 N410 M1 N415 T2 M6 N420 T3 N425 S450 M3 N430 G54 N435 M8 N440 G0 X0.1272 Y-0.1315 N445 G43 Z0.6 H2 N450 G0 Z0.2 N455 G33.1 Z-1. K0.05 N460 G0 Z0.2 N465 X0.1272 Y-0.1315 Z0.6 N470 M9 N475 G53 Z0. N480 M30 %
Can anyone give me any input on what may be wrong here? I've looked at a couple other examples and everything seems right. The machine was set up and used by the PO for rigid tapping (encoder, etc.) so I don't believe it's a hardware issue. I'm leaning toward something in the post, but I'm still very green with gcode and I'm just not seeing it.
Last edit: 8 years 3 months ago by NCPatrol.
8 years 3 months ago #114512 by NCPatrol
Replied by NCPatrol on topic Rigid Tapping Help
Well, after a little more trouble shooting, I may have been quick to dismiss a hardware problem. Seems the encoder is not registering the index signal....but is registering rotation/rpm. More trouble shooting tomorrow!
8 years 3 months ago - 8 years 3 months ago #114556 by OT-CNC
Replied by OT-CNC on topic Rigid Tapping Help
Do you have an A and B channel besides index? Make sure it counts + and -. Also, It's sometimes hard to see the index pulse using halmeter. Did you look at the index signal with the scope?
Last edit: 8 years 3 months ago by OT-CNC.
8 years 3 months ago #114557 by NCPatrol
Index doesn't show anything on the scope...assuming I'm looking at the right thing.
A & B appear to be reading.
Poke around some more tonight - verified that wiring was clean and not damaged.
I'm kind of leaning toward one of two theories:
1) The index portion of the encoder is bad.....this doesn't seem very likely.
2) The previous owner gave me the wrong config file. Shortly after buying it, I replaced the PC he gave me with a smaller unit and and did a fresh install on a new SSD. He walked me through loading the backed up config files he gave me when I bought it. It's possible that the backup he gave me didn't have the encoder properly configured.
For #1 - Is there a way to test the encoder to verify it's actually working?
For #2 - how to do I go about figuring out configured properly....or at all?
This is with Mesa 5i25, 7i77 and a Automation Direct TRDA-2E1000VD encoder if that helps.
8 years 3 months ago #114561 by PCW
Replied by PCW on topic Rigid Tapping Help
can you post your hal/ini files here?
8 years 3 months ago #114610 by NCPatrol
Sure...
hal:
# Generated by PNCconf at Fri Dec 25 14:13:58 2015 # If you make changes to this file, they will be # overwritten when you run PNCconf again loadrt timedelay count=1 loadrt abs count=1 loadrt trivkins loadrt [EMCMOT]EMCMOT servo_period_nsec=[EMCMOT]SERVO_PERIOD num_joints=[TRAJ]AXES loadrt hostmot2 loadrt hm2_pci config=" num_encoders=6 num_pwmgens=0 num_stepgens=0 sserial_port_0=0020 " setp hm2_5i25.0.watchdog.timeout_ns 5000000 loadrt pid names=pid.x,pid.y,pid.z,pid.a,pid.s addf hm2_5i25.0.read servo-thread addf motion-command-handler servo-thread addf motion-controller servo-thread addf pid.x.do-pid-calcs servo-thread addf pid.y.do-pid-calcs servo-thread addf pid.z.do-pid-calcs servo-thread addf pid.a.do-pid-calcs servo-thread addf pid.s.do-pid-calcs servo-thread addf hm2_5i25.0.write servo-thread #additional commands loadrt mux16 count=4 loadrt mux_generic config="ss32,ss32" loadrt ilowpass loadrt comp count=1 loadrt mult2 count=1 addf timedelay.0 servo-thread addf ilowpass.0 servo-thread addf mux16.0 servo-thread #jogincr addf mux16.1 servo-thread #Feedrate overide addf mux16.2 servo-thread addf mux16.3 servo-thread addf mux-gen.00 servo-thread addf mux-gen.01 servo-thread addf mult2.0 servo-thread addf abs.0 servo-thread addf comp.0 servo-thread loadrt near addf near.0 servo-thread # external output signals # ---COOLANT CONROL --- net coolant-flood hm2_5i25.0.7i77.0.0.output-01 # ---LUBRICATION SYSTEM --- # The first input to the comparator is zero. setp comp.0.in0 0.01 # The other input to the comparator is the current axis movement velocity net moving comp.0.in1 <= motion.current-vel # It needs to be connected to an output bit net pump comp.0.out => hm2_5i25.0.7i77.0.0.output-02 #Rotary input signals net rotary.clamped <= hm2_5i25.0.7i77.0.0.input-17 net rotary.unclamped <= hm2_5i25.0.7i77.0.0.input-18 # --- SPINDLE-BRAKE --- #net spindle-brake hm2_5i25.0.7i77.0.0.output-00 net spindle-brake => timedelay.0.in net spindle-delayed timedelay.0.out => hm2_5i25.0.7i77.0.0.output-00 setp timedelay.0.on-delay 14 setp timedelay.0.off-delay 0 # --- BOTH-HOME-X --- net both-home-x <= hm2_5i25.0.7i77.0.0.input-00 # --- BOTH-HOME-Y --- net both-home-y <= hm2_5i25.0.7i77.0.0.input-01 # --- MAX-HOME-Z --- net max-home-z <= hm2_5i25.0.7i77.0.0.input-03 # --- HOME-A --- net home-a <= hm2_5i25.0.7i77.0.0.input-16-not # --- MIN-Z --- net min-z <= hm2_5i25.0.7i77.0.0.input-04 # --- JOINT-SELECT-a-X --- net joint-select-a <= hm2_5i25.0.7i84.0.2.input-28 # --- JOINT-SELECT-b-Y --- net joint-select-b <= hm2_5i25.0.7i84.0.2.input-29 # --- JOINT-SELECT-c-Z --- net joint-select-c <= hm2_5i25.0.7i84.0.2.input-30 # --- JOINT-SELECT-d-A --- net joint-select-d <= hm2_5i25.0.7i84.0.2.input-31 # --- JOG-INCR-A --- net jog-incr-a <= hm2_5i25.0.7i84.0.2.input-11 # --- JOG-INCR-B --- net jog-incr-b <= hm2_5i25.0.7i84.0.2.input-10 # --- JOG-INCR-C --- net jog-incr-c <= hm2_5i25.0.7i84.0.2.input-09 # --- Feedrate overide - FO-INCR-A --- net fo-incr-a <= hm2_5i25.0.7i84.0.2.input-08 # --- FO-INCR-B --- net fo-incr-b <= hm2_5i25.0.7i84.0.2.input-07 # --- FO-INCR-C --- net fo-incr-c <= hm2_5i25.0.7i84.0.2.input-06 # --- FO-INCR-D --- net fo-incr-d <= hm2_5i25.0.7i84.0.2.input-05 # --- FO-INCR-E --- net fo-incr-e <= hm2_5i25.0.7i84.0.2.input-04 # --- Spindle override - SO-INCR-A --- net so-incr-a <= hm2_5i25.0.7i84.0.2.input-25 # --- SO-INCR-B --- net so-incr-b <= hm2_5i25.0.7i84.0.2.input-26 # --- SO-INCR-C --- net so-incr-c <= hm2_5i25.0.7i84.0.2.input-27 # --- Max velocity override - MVO-INCR-A --- net mvo-incr-a <= hm2_5i25.0.7i84.0.2.input-20 # --- MVO-INCR-B --- net mvo-incr-b <= hm2_5i25.0.7i84.0.2.input-21 # --- MVO-INCR-C --- net mvo-incr-c <= hm2_5i25.0.7i84.0.2.input-22 # --- MVO-INCR-D --- net mvo-incr-d <= hm2_5i25.0.7i84.0.2.input-23 # --- MVO-INCR-E --- net mvo-incr-e <= hm2_5i25.0.7i84.0.2.input-24 # --- FO-ENABLE --- net fo-enable <= hm2_5i25.0.7i84.0.2.input-14 # external input signals #******************* # AXIS X #******************* setp pid.x.Pgain [AXIS_0]P setp pid.x.Igain [AXIS_0]I setp pid.x.Dgain [AXIS_0]D setp pid.x.bias [AXIS_0]BIAS setp pid.x.FF0 [AXIS_0]FF0 setp pid.x.FF1 [AXIS_0]FF1 setp pid.x.FF2 [AXIS_0]FF2 setp pid.x.deadband [AXIS_0]DEADBAND setp pid.x.maxoutput [AXIS_0]MAX_OUTPUT setp pid.x.error-previous-target true setp pid.x.maxerror .0 net x-index-enable <=> pid.x.index-enable net x-enable => pid.x.enable net x-pos-cmd => pid.x.command net x-vel-cmd => pid.x.command-deriv net x-pos-fb => pid.x.feedback net x-output => pid.x.output # ---PWM Generator signals/setup--- setp hm2_5i25.0.7i77.0.1.analogout0-scalemax [AXIS_0]OUTPUT_SCALE setp hm2_5i25.0.7i77.0.1.analogout0-minlim [AXIS_0]OUTPUT_MIN_LIMIT setp hm2_5i25.0.7i77.0.1.analogout0-maxlim [AXIS_0]OUTPUT_MAX_LIMIT net x-output => hm2_5i25.0.7i77.0.1.analogout0 net x-pos-cmd axis.0.motor-pos-cmd net x-enable axis.0.amp-enable-out # enable _all_ sserial pwmgens net x-enable hm2_5i25.0.7i77.0.1.analogena # ---Encoder feedback signals/setup--- setp hm2_5i25.0.encoder.03.counter-mode 0 setp hm2_5i25.0.encoder.03.filter 1 setp hm2_5i25.0.encoder.03.index-invert 0 setp hm2_5i25.0.encoder.03.index-mask 0 setp hm2_5i25.0.encoder.03.index-mask-invert 0 setp hm2_5i25.0.encoder.03.scale [AXIS_0]ENCODER_SCALE net x-pos-fb <= hm2_5i25.0.encoder.03.position net x-vel-fb <= hm2_5i25.0.encoder.03.velocity net x-pos-fb => axis.0.motor-pos-fb net x-index-enable axis.0.index-enable <=> hm2_5i25.0.encoder.03.index-enable net x-pos-rawcounts <= hm2_5i25.0.encoder.03.rawcounts # ---setup home / limit switch signals--- net both-home-x => axis.0.home-sw-in net both-home-x => axis.0.neg-lim-sw-in net both-home-x => axis.0.pos-lim-sw-in #******************* # AXIS Y #******************* setp pid.y.Pgain [AXIS_1]P setp pid.y.Igain [AXIS_1]I setp pid.y.Dgain [AXIS_1]D setp pid.y.bias [AXIS_1]BIAS setp pid.y.FF0 [AXIS_1]FF0 setp pid.y.FF1 [AXIS_1]FF1 setp pid.y.FF2 [AXIS_1]FF2 setp pid.y.deadband [AXIS_1]DEADBAND setp pid.y.maxoutput [AXIS_1]MAX_OUTPUT setp pid.y.error-previous-target true setp pid.y.maxerror .000 net y-index-enable <=> pid.y.index-enable net y-enable => pid.y.enable net y-pos-cmd => pid.y.command net y-vel-cmd => pid.y.command-deriv net y-pos-fb => pid.y.feedback net y-output => pid.y.output # ---PWM Generator signals/setup--- setp hm2_5i25.0.7i77.0.1.analogout1-scalemax [AXIS_1]OUTPUT_SCALE setp hm2_5i25.0.7i77.0.1.analogout1-minlim [AXIS_1]OUTPUT_MIN_LIMIT setp hm2_5i25.0.7i77.0.1.analogout1-maxlim [AXIS_1]OUTPUT_MAX_LIMIT net y-output => hm2_5i25.0.7i77.0.1.analogout1 net y-pos-cmd axis.1.motor-pos-cmd net y-enable axis.1.amp-enable-out # ---Encoder feedback signals/setup--- setp hm2_5i25.0.encoder.01.counter-mode 0 setp hm2_5i25.0.encoder.01.filter 1 setp hm2_5i25.0.encoder.01.index-invert 0 setp hm2_5i25.0.encoder.01.index-mask 0 setp hm2_5i25.0.encoder.01.index-mask-invert 0 setp hm2_5i25.0.encoder.01.scale [AXIS_1]ENCODER_SCALE net y-pos-fb <= hm2_5i25.0.encoder.01.position net y-vel-fb <= hm2_5i25.0.encoder.01.velocity net y-pos-fb => axis.1.motor-pos-fb net y-index-enable axis.1.index-enable <=> hm2_5i25.0.encoder.01.index-enable net y-pos-rawcounts <= hm2_5i25.0.encoder.01.rawcounts # ---setup home / limit switch signals--- net both-home-y => axis.1.home-sw-in net both-home-y => axis.1.neg-lim-sw-in net both-home-y => axis.1.pos-lim-sw-in #******************* # AXIS Z #******************* setp pid.z.Pgain [AXIS_2]P setp pid.z.Igain [AXIS_2]I setp pid.z.Dgain [AXIS_2]D setp pid.z.bias [AXIS_2]BIAS setp pid.z.FF0 [AXIS_2]FF0 setp pid.z.FF1 [AXIS_2]FF1 setp pid.z.FF2 [AXIS_2]FF2 setp pid.z.deadband [AXIS_2]DEADBAND setp pid.z.maxoutput [AXIS_2]MAX_OUTPUT setp pid.z.error-previous-target true setp pid.z.maxerror .000 net z-index-enable <=> pid.z.index-enable net z-enable => pid.z.enable net z-pos-cmd => pid.z.command net z-vel-cmd => pid.z.command-deriv net z-pos-fb => pid.z.feedback net z-output => pid.z.output # ---PWM Generator signals/setup--- setp hm2_5i25.0.7i77.0.1.analogout2-scalemax [AXIS_2]OUTPUT_SCALE setp hm2_5i25.0.7i77.0.1.analogout2-minlim [AXIS_2]OUTPUT_MIN_LIMIT setp hm2_5i25.0.7i77.0.1.analogout2-maxlim [AXIS_2]OUTPUT_MAX_LIMIT net z-output => hm2_5i25.0.7i77.0.1.analogout2 net z-pos-cmd axis.2.motor-pos-cmd net z-enable axis.2.amp-enable-out # ---Encoder feedback signals/setup--- setp hm2_5i25.0.encoder.02.counter-mode 0 setp hm2_5i25.0.encoder.02.filter 1 setp hm2_5i25.0.encoder.02.index-invert 0 setp hm2_5i25.0.encoder.02.index-mask 0 setp hm2_5i25.0.encoder.02.index-mask-invert 0 setp hm2_5i25.0.encoder.02.scale [AXIS_2]ENCODER_SCALE net z-pos-fb <= hm2_5i25.0.encoder.02.position net z-vel-fb <= hm2_5i25.0.encoder.02.velocity net z-pos-fb => axis.2.motor-pos-fb net z-index-enable axis.2.index-enable <=> hm2_5i25.0.encoder.02.index-enable net z-pos-rawcounts <= hm2_5i25.0.encoder.02.rawcounts # ---setup home / limit switch signals--- net max-home-z => axis.2.home-sw-in net min-z => axis.2.neg-lim-sw-in net max-home-z => axis.2.pos-lim-sw-in #******************* # AXIS A #******************* setp pid.a.Pgain [AXIS_3]P setp pid.a.Igain [AXIS_3]I setp pid.a.Dgain [AXIS_3]D setp pid.a.bias [AXIS_3]BIAS setp pid.a.FF0 [AXIS_3]FF0 setp pid.a.FF1 [AXIS_3]FF1 setp pid.a.FF2 [AXIS_3]FF2 setp pid.a.deadband [AXIS_3]DEADBAND setp pid.a.maxoutput [AXIS_3]MAX_OUTPUT setp pid.a.error-previous-target true setp pid.a.maxerror .000 net a-index-enable <=> pid.a.index-enable net a-enable => pid.a.enable net a-pos-cmd => pid.a.command net a-vel-cmd => pid.a.command-deriv net a-pos-fb => pid.a.feedback net a-output => pid.a.output # ---PWM Generator signals/setup--- setp hm2_5i25.0.7i77.0.1.analogout3-scalemax [AXIS_3]OUTPUT_SCALE setp hm2_5i25.0.7i77.0.1.analogout3-minlim [AXIS_3]OUTPUT_MIN_LIMIT setp hm2_5i25.0.7i77.0.1.analogout3-maxlim [AXIS_3]OUTPUT_MAX_LIMIT net a-output => hm2_5i25.0.7i77.0.1.analogout3 net a-pos-cmd axis.3.motor-pos-cmd net a-enable axis.3.amp-enable-out # ---Encoder feedback signals/setup--- setp hm2_5i25.0.encoder.04.counter-mode 0 setp hm2_5i25.0.encoder.04.filter 1 setp hm2_5i25.0.encoder.04.index-invert 0 setp hm2_5i25.0.encoder.04.index-mask 0 setp hm2_5i25.0.encoder.04.index-mask-invert 0 setp hm2_5i25.0.encoder.04.scale [AXIS_3]ENCODER_SCALE net a-pos-fb <= hm2_5i25.0.encoder.04.position net a-vel-fb <= hm2_5i25.0.encoder.04.velocity net a-pos-fb => axis.3.motor-pos-fb net a-index-enable axis.3.index-enable <=> hm2_5i25.0.encoder.04.index-enable net a-pos-rawcounts <= hm2_5i25.0.encoder.04.rawcounts # ---setup home / limit switch signals--- net home-a => axis.3.home-sw-in net a-neg-limit => axis.3.neg-lim-sw-in net a-pos-limit => axis.3.pos-lim-sw-in #******************* # SPINDLE S #******************* setp pid.s.Pgain [SPINDLE_9]P setp pid.s.Igain [SPINDLE_9]I setp pid.s.Dgain [SPINDLE_9]D setp pid.s.bias [SPINDLE_9]BIAS setp pid.s.FF0 [SPINDLE_9]FF0 setp pid.s.FF1 [SPINDLE_9]FF1 setp pid.s.FF2 [SPINDLE_9]FF2 setp pid.s.deadband [SPINDLE_9]DEADBAND setp pid.s.maxoutput [SPINDLE_9]MAX_OUTPUT setp pid.s.error-previous-target true setp pid.s.maxerror .0000 net spindle-index-enable <=> pid.s.index-enable net spindle-enable => pid.s.enable net spindle-vel-cmd-rpm-abs => pid.s.command net spindle-vel-fb-rpm-abs => pid.s.feedback net spindle-output <= pid.s.output # ---PWM Generator signals/setup--- setp hm2_5i25.0.7i77.0.1.analogout5-scalemax [SPINDLE_9]OUTPUT_SCALE setp hm2_5i25.0.7i77.0.1.analogout5-minlim [SPINDLE_9]OUTPUT_MIN_LIMIT setp hm2_5i25.0.7i77.0.1.analogout5-maxlim [SPINDLE_9]OUTPUT_MAX_LIMIT net spindle-output => hm2_5i25.0.7i77.0.1.analogout5 net spindle-enable => hm2_5i25.0.7i77.0.1.spinena # ---Encoder feedback signals/setup--- setp hm2_5i25.0.encoder.05.counter-mode 0 setp hm2_5i25.0.encoder.05.filter 1 setp hm2_5i25.0.encoder.05.index-invert 0 setp hm2_5i25.0.encoder.05.index-mask 0 setp hm2_5i25.0.encoder.05.index-mask-invert 0 setp hm2_5i25.0.encoder.05.scale [SPINDLE_9]ENCODER_SCALE net spindle-revs <= hm2_5i25.0.encoder.05.position net spindle-vel-fb-rps abs.0.in <= hm2_5i25.0.encoder.05.velocity net spindle-index-enable <=> hm2_5i25.0.encoder.05.index-enable # ---setup spindle control signals--- net spindle-vel-cmd-rps <= motion.spindle-speed-out-rps net spindle-vel-cmd-rps-abs <= motion.spindle-speed-out-rps-abs net spindle-vel-cmd-rpm <= motion.spindle-speed-out net spindle-vel-cmd-rpm-abs <= motion.spindle-speed-out-abs net spindle-enable <= motion.spindle-on net spindle-cw <= motion.spindle-forward net spindle-ccw <= motion.spindle-reverse net spindle-brake <= motion.spindle-brake net spindle-revs => motion.spindle-revs net spindle-at-speed => motion.spindle-at-speed net spindle-vel-fb-rps => motion.spindle-speed-in net spindle-index-enable <=> motion.spindle-index-enable net spindle-cw => hm2_5i25.0.7i77.0.0.output-04 net spindle-ccw => hm2_5i25.0.7i77.0.0.output-05 net spindle-vel-fb-rps-abs <= abs.0.out # ---Setup spindle at speed signals--- net spindle-vel-cmd-rpm-abs => near.0.in1 net spindle-vel-fb-rpm => near.0.in2 net spindle-at-speed <= near.0.out setp near.0.scale 1.000000 setp near.0.difference 75.0 setp mult2.0.in0 60 net spindle-vel-fb-rps-abs => mult2.0.in1 net spindle-vel-fb-rpm <= mult2.0.out # Use ACTUAL spindle velocity from spindle encoder # spindle-velocity bounces around so we filter it with lowpass # spindle-velocity is signed so we use absolute component to remove sign # ACTUAL velocity is in RPS not RPM so we scale it. #setp scale.spindle.gain 60 #setp lowpass.spindle.gain 1.000000 #net spindle-vel-fb-rps => scale.spindle.in #net spindle-fb-rpm scale.spindle.out => abs.spindle.in #net spindle-fb-rpm-abs abs.spindle.out => lowpass.spindle.in #net spindle-fb-rpm-abs-filtered lowpass.spindle.out #****************************** # connect miscellaneous signals #****************************** # ---HALUI signals--- net joint-select-a halui.joint.0.select net x-is-homed halui.joint.0.is-homed net jog-x-pos halui.jog.0.plus net jog-x-neg halui.jog.0.minus net jog-x-analog halui.jog.0.analog net joint-select-b halui.joint.1.select net y-is-homed halui.joint.1.is-homed net jog-y-pos halui.jog.1.plus net jog-y-neg halui.jog.1.minus net jog-y-analog halui.jog.1.analog net joint-select-c halui.joint.2.select net z-is-homed halui.joint.2.is-homed net jog-z-pos halui.jog.2.plus net jog-z-neg halui.jog.2.minus net jog-z-analog halui.jog.2.analog net joint-select-d halui.joint.3.select net a-is-homed halui.joint.3.is-homed net jog-a-pos halui.jog.3.plus net jog-a-neg halui.jog.3.minus net jog-a-analog halui.jog.3.analog net jog-selected-pos halui.jog.selected.plus net jog-selected-neg halui.jog.selected.minus net spindle-manual-cw halui.spindle.forward net spindle-manual-ccw halui.spindle.reverse net spindle-manual-stop halui.spindle.stop net machine-is-on halui.machine.is-on net jog-speed halui.jog-speed net MDI-mode halui.mode.is-mdi # ---coolant signals--- net coolant-mist <= iocontrol.0.coolant-mist net coolant-flood <= iocontrol.0.coolant-flood # ---probe signal--- net probe-in => motion.probe-input # ---jog button signals--- net jog-speed <= hm2_5i25.0.7i84.0.2.analogin0 #sets jog-speed .16 ## MPG stuff########## # ---jogwheel signals to mesa encoder - shared MPG--- net joint-selected-count <= hm2_5i25.0.7i84.0.2.enc0.count setp hm2_5i25.0.encoder.00.filter true setp hm2_5i25.0.encoder.00.counter-mode true # ---mpg signals--- # for axis x MPG setp axis.0.jog-vel-mode 0 net selected-jog-incr => axis.0.jog-scale net joint-select-a => axis.0.jog-enable net joint-selected-count => axis.0.jog-counts # for axis y MPG setp axis.1.jog-vel-mode 0 net selected-jog-incr => axis.1.jog-scale net joint-select-b => axis.1.jog-enable net joint-selected-count => axis.1.jog-counts # for axis z MPG setp axis.2.jog-vel-mode 0 net selected-jog-incr => axis.2.jog-scale net joint-select-c => axis.2.jog-enable net joint-selected-count => axis.2.jog-counts # for axis a MPG setp axis.3.jog-vel-mode 0 net selected-jog-incr => axis.3.jog-scale net joint-select-d => axis.3.jog-enable net joint-selected-count => axis.3.jog-counts ##connect jog incr override increments net jog-incr-a => mux16.0.sel0 net jog-incr-b => mux16.0.sel1 net jog-incr-c => mux16.0.sel2 net jog-incr-d => mux16.0.sel3 net selected-jog-incr <= mux16.0.out-f setp mux16.0.debounce-time 0.200000 setp mux16.0.use-graycode False setp mux16.0.suppress-no-input False setp mux16.0.in00 0.0001 setp mux16.0.in01 0.001 setp mux16.0.in02 .01 setp mux16.0.in03 .1 setp mux16.0.in04 1 # connect feed overide increments - switches setp halui.feed-override.count-enable true setp halui.feed-override.direct-value true setp halui.feed-override.scale .01 net feedoverride-incr => halui.feed-override.counts net fo-incr-a => mux-gen.00.sel-bit-00 net fo-incr-b => mux-gen.00.sel-bit-01 net fo-incr-c => mux-gen.00.sel-bit-02 net fo-incr-d => mux-gen.00.sel-bit-03 net fo-incr-e => mux-gen.00.sel-bit-04 net feedoverride-incr <= mux-gen.00.out-s32 setp mux-gen.00.debounce-us 200000 setp mux-gen.00.suppress-no-input False setp mux-gen.00.in-s32-00 0 setp mux-gen.00.in-s32-01 10 setp mux-gen.00.in-s32-02 20 setp mux-gen.00.in-s32-03 30 setp mux-gen.00.in-s32-04 40 setp mux-gen.00.in-s32-05 50 setp mux-gen.00.in-s32-06 60 setp mux-gen.00.in-s32-07 70 setp mux-gen.00.in-s32-08 80 setp mux-gen.00.in-s32-09 90 setp mux-gen.00.in-s32-10 100 setp mux-gen.00.in-s32-11 110 setp mux-gen.00.in-s32-12 120 setp mux-gen.00.in-s32-13 130 setp mux-gen.00.in-s32-14 140 setp mux-gen.00.in-s32-15 150 setp mux-gen.00.in-s32-16 160 setp mux-gen.00.in-s32-17 170 setp mux-gen.00.in-s32-18 180 setp mux-gen.00.in-s32-19 190 setp mux-gen.00.in-s32-20 200 # connect max velocity overide increments - switches setp halui.max-velocity.count-enable true setp halui.max-velocity.direct-value true setp halui.max-velocity.scale 0.016670 net max-vel-override-incr => halui.max-velocity.counts net mvo-incr-a => mux-gen.01.sel-bit-00 net mvo-incr-b => mux-gen.01.sel-bit-01 net mvo-incr-c => mux-gen.01.sel-bit-02 net mvo-incr-d => mux-gen.01.sel-bit-03 net mvo-incr-e => mux-gen.01.sel-bit-04 net max-vel-override-incr <= mux-gen.01.out-s32 setp mux-gen.01.debounce-us 200000 setp mux-gen.01.suppress-no-input False setp mux-gen.01.in-s32-00 0 setp mux-gen.01.in-s32-01 2 setp mux-gen.01.in-s32-02 4 setp mux-gen.01.in-s32-03 6 setp mux-gen.01.in-s32-04 8 setp mux-gen.01.in-s32-05 10 setp mux-gen.01.in-s32-06 12 setp mux-gen.01.in-s32-07 14 setp mux-gen.01.in-s32-08 16 setp mux-gen.01.in-s32-09 18 setp mux-gen.01.in-s32-10 20 setp mux-gen.01.in-s32-11 25 setp mux-gen.01.in-s32-12 30 setp mux-gen.01.in-s32-13 35 setp mux-gen.01.in-s32-14 40 setp mux-gen.01.in-s32-15 45 setp mux-gen.01.in-s32-16 50 setp mux-gen.01.in-s32-17 55 setp mux-gen.01.in-s32-18 60 # connect spindle overide increments setp halui.spindle-override.count-enable true setp halui.spindle-override.direct-value true setp halui.spindle-override.scale .01 net spindleoverride-incr => halui.spindle-override.counts net so-incr-a => mux16.3.sel0 net so-incr-b => mux16.3.sel1 net so-incr-c => mux16.3.sel2 net spindleoverride-incr <= mux16.3.out-s setp mux16.3.debounce-time 0.200000 setp mux16.3.use-graycode False setp mux16.3.suppress-no-input False setp mux16.3.in00 100.000000 setp mux16.3.in01 90.000000 setp mux16.3.in02 70.000000 setp mux16.3.in03 80.000000 setp mux16.3.in04 110.000000 setp mux16.3.in05 120.000000 setp mux16.3.in06 60.000000 setp mux16.3.in07 50.000000 # ---motion control signals--- net in-position <= motion.in-position net machine-is-enabled <= motion.motion-enabled # ---digital in / out signals--- # ---estop signals--- # ---estop signals--- net estop-out <= hm2_5i25.0.7i84.0.2.input-15 net estop-out => iocontrol.0.emc-enable-in # ---manual tool change signals--- loadusr -W hal_manualtoolchange net tool-change-request iocontrol.0.tool-change => hal_manualtoolchange.change net tool-change-confirmed iocontrol.0.tool-changed <= hal_manualtoolchange.changed net tool-number iocontrol.0.tool-prep-number => hal_manualtoolchange.number net tool-prepare-loopback iocontrol.0.tool-prepare => iocontrol.0.tool-prepared
ini:
# Generated by PNCconf at Fri Dec 25 14:13:58 2015 # If you make changes to this file, they will be # overwritten when you run PNCconf again [EMC] MACHINE = Boss5_servo DEBUG = 0 [DISPLAY] DISPLAY = axis POSITION_OFFSET = RELATIVE POSITION_FEEDBACK = ACTUAL MAX_FEED_OVERRIDE = 2.000000 MAX_SPINDLE_OVERRIDE = 1.000000 MIN_SPINDLE_OVERRIDE = 0.500000 INTRO_GRAPHIC = linuxcnc.gif INTRO_TIME = 5 PROGRAM_PREFIX = /home/shefron/linuxcnc/nc_files INCREMENTS = .1in .05in .01in .005in .001in .0005in .0001in POSITION_FEEDBACK = ACTUAL DEFAULT_LINEAR_VELOCITY = 0.250000 MAX_LINEAR_VELOCITY = 2.08 MIN_LINEAR_VELOCITY = 0.010000 DEFAULT_ANGULAR_VELOCITY = 0.250000 MAX_ANGULAR_VELOCITY = 1.000000 MIN_ANGULAR_VELOCITY = 0.010000 EDITOR = gedit GEOMETRY = xyz-aw PYVCP = spindle.xml PYVCP = LEDs.xml [FILTER] PROGRAM_EXTENSION = .png,.gif,.jpg Greyscale Depth Image PROGRAM_EXTENSION = .py Python Script png = image-to-gcode gif = image-to-gcode jpg = image-to-gcode py = python [TASK] TASK = milltask CYCLE_TIME = 0.010 [RS274NGC] PARAMETER_FILE = linuxcnc.var USER_M_PATH= M-codes [EMCMOT] EMCMOT = motmod COMM_TIMEOUT = 1.0 COMM_WAIT = 0.010 SERVO_PERIOD = 1000000 [HOSTMOT2] # **** This is for info only **** # DRIVER0=hm2_pci # BOARD0=5i25 [HAL] HALUI = halui HALFILE = Boss5_servo.hal HALFILE = custom.hal POSTGUI_HALFILE = postgui_call_list.hal POSTGUI_HALFILE = spindle_to_pyvcp.hal SHUTDOWN = shutdown.hal [HALUI] [TRAJ] AXES = 9 COORDINATES = X Y Z W A MAX_ANGULAR_VELOCITY = 360.00 DEFAULT_ANGULAR_VELOCITY = 36.00 LINEAR_UNITS = inch ANGULAR_UNITS = degree CYCLE_TIME = 0.010 DEFAULT_VELOCITY = 0.10 MAX_LINEAR_VELOCITY = 2.08 [EMCIO] EMCIO = io CYCLE_TIME = 0.100 TOOL_TABLE = tool.tbl TOOL_CHANGE_QUILL_UP = 1 #******************** # Axis X #******************** [AXIS_0] TYPE = LINEAR HOME = 9 FERROR = 1 MIN_FERROR = 1 MAX_VELOCITY = 1.0 MAX_ACCELERATION = 30.0 P = 100 I = 0 D = 0 FF0 = 0 FF1 = 3.03 FF2 = 0 BIAS = 0 DEADBAND = 0 MAX_OUTPUT = 0 ENCODER_SCALE = -163840 OUTPUT_SCALE = 10 OUTPUT_MIN_LIMIT = -10 OUTPUT_MAX_LIMIT = 10 MIN_LIMIT = .25 MAX_LIMIT = 18.0 HOME_OFFSET = 0 HOME_SEARCH_VEL = -.2 HOME_LATCH_VEL = 0.016667 HOME_FINAL_VEL = 0.000000 HOME_USE_INDEX = NO HOME_IGNORE_LIMITS = YES HOME_SEQUENCE = 1 #******************** # Axis Y #******************** [AXIS_1] TYPE = LINEAR HOME = 10 FERROR = 1 MIN_FERROR = 1 MAX_VELOCITY = 2.08 MAX_ACCELERATION = 30.0 P = 500 I = 0 D = 0 FF0 = 0 FF1 = 3.03 FF2 = 0 BIAS = 0 DEADBAND = 0 MAX_OUTPUT = 0 ENCODER_SCALE = -40960 OUTPUT_SCALE = 10 OUTPUT_MIN_LIMIT = -10 OUTPUT_MAX_LIMIT = 10 MIN_LIMIT = -0 MAX_LIMIT = 12 HOME_OFFSET = 12 HOME_SEARCH_VEL = 0.2 HOME_LATCH_VEL = -0.016667 HOME_FINAL_VEL = 0.000000 HOME_USE_INDEX = NO HOME_IGNORE_LIMITS = YES HOME_SEQUENCE = 2 #******************** # Axis Z #******************** [AXIS_2] TYPE = LINEAR HOME = 0.0 FERROR = 1 MIN_FERROR = 1 MAX_VELOCITY = 1.0 MAX_ACCELERATION = 30.0 P = 300 I = 0 D = 0 FF0 = 0 FF1 = 3.1 FF2 = 0 BIAS = 0 DEADBAND = 0 MAX_OUTPUT = 0 ENCODER_SCALE = -163840 OUTPUT_SCALE = 10 OUTPUT_MIN_LIMIT = -10 OUTPUT_MAX_LIMIT = 10 MIN_LIMIT = -5 MAX_LIMIT = 0.001 HOME_OFFSET = 0.05 HOME_SEARCH_VEL = 0.100000 HOME_LATCH_VEL = 0.016667 HOME_FINAL_VEL = 0.000000 HOME_USE_INDEX = NO HOME_IGNORE_LIMITS = YES HOME_SEQUENCE = 0 #******************** # Axis W #******************** [AXIS_8] TYPE = LINEAR ENCODER_SCALE = -6350 ##Immediate Homing### HOME_SEARCH_VEL = 0 HOME_LATCH_VEL = 0 HOME_FINAL_VEL = 0 HOME_USE_INDEX = NO HOME_SEQUENCE = 0 #******************** # Axis A #******************** [AXIS_3] TYPE = ANGULAR HOME = 13.411 FERROR = 360 MIN_FERROR = 30 MAX_VELOCITY = 140 MAX_ACCELERATION = 30 P = 60 I = 0 D = 0 FF0 = 0 FF1 = 3.03 FF2 = 0 BIAS = 0 DEADBAND = 0 MAX_OUTPUT = 0 ENCODER_SCALE = -16384 OUTPUT_SCALE = 10 OUTPUT_MIN_LIMIT = -10 OUTPUT_MAX_LIMIT = 10 MIN_LIMIT = -9999999.0 MAX_LIMIT = 9999999.0 ##Immediate Homing### HOME_SEARCH_VEL = 0 HOME_LATCH_VEL = 0 HOME_FINAL_VEL = 0 HOME_USE_INDEX = NO HOME_SEQUENCE = 0 ##Repeatable homing## #HOME_OFFSET = 1 #HOME_SEARCH_VEL = 10.000000 #HOME_LATCH_VEL = -0.500000 #HOME_FINAL_VEL = 0.000000 #HOME_USE_INDEX = YES #******************** # Spindle #******************** [SPINDLE_9] P = 0.0 I = 0.0 D = 0.0 FF0 = 1.0 FF1 = 0.0 FF2 = 0.0 BIAS = 0.0 DEADBAND = 0.0 MAX_OUTPUT = 3600.0 ENCODER_SCALE = 4000.0 OUTPUT_SCALE = 3600.0 OUTPUT_MIN_LIMIT = 0.0 OUTPUT_MAX_LIMIT = 3600.0 #******************** # Axis B #******************** [AXIS_4] #******************** # Axis C #******************** [AXIS_5] #******************** # Axis U #******************** [AXIS_6] #******************** # Axis V #******************** [AXIS_7]
Time to create page: 1.459 seconds
