G76, Troubleshooting needed!
- Victor
8 years 2 days ago #119652
by Victor
Replied by Victor on topic G76, Troubleshooting needed!
Hmm pretty sure i did not understand you correctly.
Should i change "loadrt lowpass names=lowpass.spindle" that is in my main .hal file to
"loadrt names=lowpass.spindle,lowpass.spindlepos" ?
Got this error code:
Agreed that Pncconf has done it's job but since i lack the coding skills, if i want to add something or change an input I'm lost without it so i have to use Pncconf and then replace all the custom bits i have added after.
Br Victor
Debug file information:
Note: Using POSIX realtime
names=lowpass.spindle,lowpass.spindlepos: dlopen: /usr/lib/linuxcnc/modules/names=lowpass.spindle,lowpass.spindlepos.so: cannot open shared object file: No such file or directory
./Emco-120P.hal:13: waitpid failed /usr/bin/rtapi_app names=lowpass.spindle,lowpass.spindlepos
./Emco-120P.hal:13: /usr/bin/rtapi_app exited without becoming ready
./Emco-120P.hal:13: insmod for names=lowpass.spindle,lowpass.spindlepos failed, returned -1
4514
Br Victor
8 years 2 days ago #119653
Replied by andypugh on topic G76, Troubleshooting needed!
It looks like you left out the "loadrt lowpass" ?
The following user(s) said Thank You: Victor
- Victor
8 years 2 days ago #119655
by Victor
But i have "loadrt lowpass count=1" in the custom.hal file
if i have this in the main .hal file:
I get the error message that lowpass already exists.
I'm really out in the deep here so it would be greatly appreciated if you could point out exactly what should be in the main .hal file. and perhaps if i need to change anything in the code you provided earlier for custom.hal file.
Thank you!
Br Victor
Thank you!
Br Victor
8 years 1 day ago #119656
You can only normally have one loadrt for a particular component.
But there is a way round this, using TWOPASS.
You might as well do this, to make things easier later.
linuxcnc.org/docs/2.7/html/config/ini-config.html#_hal_section
So put
in the HAL section of the INI.
Put the loadrt in the main HAL back to how it was.
in the custom.hal change the loadrt to:
You can call it something else if you want, but the name needs to match everywhere else it is used.
So put
TWOPASS=ON
loadrt lowpass names=lowpass.0
- Victor
8 years 1 day ago #119657
by Victor
TWOPASS=ON did produce a fair amount of errors:
Br Victor
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_CONFIG_DIR=
LINUXCNC_LANG_DIR=/usr/share/linuxcnc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
LINUXCNC_EMCSH=/usr/bin/wish8.5
LINUXCNC - 2.7.8
Machine configuration directory is '/home/victor/linuxcnc/configs/Emco-120P'
Machine configuration file is 'Emco-120P.ini'
INIFILE=/home/victor/linuxcnc/configs/Emco-120P/Emco-120P.ini
PARAMETER_FILE=linuxcnc.var
TASK=milltask
HALUI=halui
DISPLAY=axis
Starting LinuxCNC...
twopass:invoked with <> options
twopass:found ./Emco-120P.hal
twopass:found ./custom.hal
Running HAL shutdown script
Killing task linuxcncsvr, PID=5330
hm2: unloading
Unknown parameter `num_encoders=1'
waitpid failed /usr/bin/rtapi_app hm2_eth
insmod for hm2_eth failed, returned -1
while executing
"hal loadrt hm2_eth board_ip=\"10.10.10.10\" config=\"firmware=hm2/7i76/7i76e.BIT num_encoders=1 num_pwmgens=0 num_stepgens=2 sserial_port_0=00xxxx\""
("eval" body line 1)
invoked from within
"eval hal loadrt $args"
(procedure "orig_loadrt" line 1)
invoked from within
"orig_loadrt hm2_eth board_ip=\"10.10.10.10\" config=\"firmware=hm2/7i76/7i76e.BIT num_encoders=1 num_pwmgens=0 num_stepgens=2 sserial_port_0=00xxxx\""
invoked from within
"eval $cmd"
(procedure "load_the_modules" line 22)
invoked from within
"load_the_modules"
(procedure "::tp::pass0" line 11)
invoked from within
"::tp::pass0"
(file "/usr/lib/tcltk/linuxcnc/twopass.tcl" line 556)
invoked from within
"source $filename"
invoked from within
"set result [source $filename]"
(file "/usr/bin/haltcl" line 55)
5330
PID TTY STAT TIME COMMAND
Stopping realtime threads
Unloading hal components
Kernel message information:
[ 432.153770] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 432.157533] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_SLEEP] macid=0, org reg_0x4d4=0x00000000
[ 432.935457] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000001
[ 433.905079] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 434.912829] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 434.945826] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 436.392704] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 436.426326] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 436.428703] RTL871X: survey done event(e) band:0 for wlan0
[ 436.428765] RTL871X: rtw_indicate_scan_done(wlan0)
[ 436.913507] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 436.913521] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 452.945259] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 469.002603] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 491.024397] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 491.024410] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 495.032168] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 495.032182] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 499.041207] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 499.041217] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 501.046103] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 501.046117] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 515.073341] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 531.105388] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 552.154096] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-LPS_CTRL_LEAVE
[ 552.154110] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 552.158269] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_SLEEP] macid=0, org reg_0x4d4=0x00000000
[ 553.430111] RTL871X: Drop duplicate management frame with seq_num = 2432.
[ 553.912202] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 555.157960] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 555.191202] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 556.373330] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 556.406955] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000001
[ 556.409577] RTL871X: survey done event(a) band:0 for wlan0
[ 556.409599] RTL871X: rtw_indicate_scan_done(wlan0)
[ 557.156698] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 557.156712] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 567.177000] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 583.209660] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 599.241498] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 615.274130] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 631.305504] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 653.349548] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 669.381568] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 672.154119] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-LPS_CTRL_LEAVE
[ 672.154132] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 672.158292] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_SLEEP] macid=0, org reg_0x4d4=0x00000000
[ 673.976706] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 675.416456] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 675.449575] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 676.419076] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 676.452577] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000001
[ 676.455324] RTL871X: survey done event(c) band:0 for wlan0
[ 676.455347] RTL871X: rtw_indicate_scan_done(wlan0)
[ 677.397133] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 677.397147] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 685.413075] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 701.449776] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 717.482533] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 733.513459] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 761.570910] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 777.601296] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 783.611833] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 783.611846] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 789.624563] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 789.624578] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 791.628199] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 791.628208] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 792.154173] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_SLEEP] macid=0, org reg_0x4d4=0x00000000
[ 793.895329] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 795.640578] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 795.672205] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000001
[ 795.677991] RTL871X: OnAction_back
[ 795.678001] RTL871X: OnAction_back, action=2
[ 795.678008] RTL871X: OnAction_back(): DELBA: 0(0)
[ 795.678027] RTL871X: OnAction_back
[ 795.678040] RTL871X: OnAction_back, action=0
[ 795.678064] RTL871X: issue_addba_rsp(wlan0) ra=08:60:6e:be:f2:60 status=0, tid=0, size=64
[ 795.679444] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 795.680115] RTL871X: Drop duplicate management frame with seq_num = 1148.
[ 796.343937] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 796.380452] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 796.382825] RTL871X: survey done event(a) band:0 for wlan0
[ 796.382934] RTL871X: rtw_indicate_scan_done(wlan0)
[ 797.046761] RTL871X: OnAction_back
[ 797.046772] RTL871X: OnAction_back, action=0
[ 797.047053] RTL871X: issue_addba_rsp(wlan0) ra=08:60:6e:be:f2:60 status=0, tid=0, size=64
[ 799.644052] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 799.644065] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 803.652638] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 803.652652] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 805.656357] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 805.656371] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 808.098325] RTL871X: OnAction_back
[ 808.098336] RTL871X: OnAction_back, action=2
[ 808.098343] RTL871X: OnAction_back(): DELBA: 0(0)
[ 821.691344] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 837.720396] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 840.561300] RTL871X: OnAction_back
[ 840.561311] RTL871X: OnAction_back, action=0
[ 840.561564] RTL871X: issue_addba_rsp(wlan0) ra=08:60:6e:be:f2:60 status=0, tid=0, size=64
[ 841.728466] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 841.728479] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 845.736727] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 845.736741] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 849.745830] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 849.745844] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 851.748558] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 851.748572] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 861.768923] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 861.768937] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 863.772481] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 863.772495] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 883.815343] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 899.844718] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 912.153748] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-LPS_CTRL_LEAVE
[ 912.153758] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 912.157954] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_SLEEP] macid=0, org reg_0x4d4=0x00000000
[ 913.938329] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 915.893202] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 915.926457] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000001
[ 915.933698] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 916.376830] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 916.410325] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 916.412827] RTL871X: survey done event(e) band:0 for wlan0
[ 916.412847] RTL871X: rtw_indicate_scan_done(wlan0)
[ 917.881501] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 917.881515] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 931.910448] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 963.975332] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 980.005535] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 996.037100] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 1012.069296] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 1028.100968] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 1032.153487] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-LPS_CTRL_LEAVE
[ 1032.153499] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 1032.157247] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_SLEEP] macid=0, org reg_0x4d4=0x00000000
[ 1033.901579] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 1034.118579] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 1034.151328] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 1036.128704] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 1036.160081] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000001
[ 1036.167324] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 1036.353081] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 1036.386826] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 1036.389202] RTL871X: survey done event(e) band:0 for wlan0
[ 1036.389223] RTL871X: rtw_indicate_scan_done(wlan0)
[ 1038.120277] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 1038.120291] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 1080.205468] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 1084.212048] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 1084.212062] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 1086.216087] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 1086.216101] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 1090.224211] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 1090.224226] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 1092.228313] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 1092.228327] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 1106.257058] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 1122.289000] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 1138.320878] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 1152.154077] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-LPS_CTRL_LEAVE
[ 1152.154090] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 1152.158965] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_SLEEP] macid=0, org reg_0x4d4=0x00000000
[ 1153.985454] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 1154.357079] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 1154.389704] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 1156.369834] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 1156.402210] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000001
[ 1156.409456] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 1156.466581] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 1156.501576] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 1156.504082] RTL871X: survey done event(f) band:0 for wlan0
[ 1156.504195] RTL871X: rtw_indicate_scan_done(wlan0)
[ 1160.365189] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 1160.365204] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 1180.405548] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 1188.420402] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 1188.420418] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 1190.424269] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 1190.424283] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 1192.428136] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 1192.428146] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 1194.432687] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 1194.432701] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 1208.461920] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 1224.493055] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 1240.525062] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 1258.560394] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 1258.560407] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 1260.564217] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 1260.564232] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 1272.153756] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-LPS_CTRL_LEAVE
[ 1272.153769] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 1272.156875] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_SLEEP] macid=0, org reg_0x4d4=0x00000000
[ 1273.959721] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 1274.594444] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 1274.627065] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 1276.451330] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 1276.486561] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000001
[ 1276.489067] RTL871X: survey done event(4) band:0 for wlan0
[ 1276.489082] RTL871X: rtw_indicate_scan_done(wlan0)
[ 1276.596161] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 1276.596175] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 1280.604910] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 1296.637050] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 1306.656037] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 1306.656051] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 1308.659836] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 1308.659850] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 1312.668196] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 1312.668210] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 1314.672772] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 1314.672786] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 1316.676202] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 1316.676215] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 1320.684125] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 1320.684139] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 1322.688646] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 1322.688659] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 1324.694137] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 1324.694151] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 1338.720520] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 1362.771426] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 1378.802440] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 1392.154511] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-LPS_CTRL_LEAVE
[ 1392.154524] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 1392.159738] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_SLEEP] macid=0, org reg_0x4d4=0x00000000
[ 1393.570862] RTL871X: Drop duplicate management frame with seq_num = 3656.
[ 1393.574858] RTL871X: Drop duplicate management frame with seq_num = 3656.
[ 1393.579074] RTL871X: Drop duplicate management frame with seq_num = 3656.
[ 1393.923706] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 1394.850829] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 1394.882939] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000001
[ 1394.887710] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 1396.345318] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 1396.378827] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 1396.381204] RTL871X: survey done event(9) band:0 for wlan0
[ 1396.381226] RTL871X: rtw_indicate_scan_done(wlan0)
[ 1396.836430] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 1396.836443] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 1410.865628] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 1424.893347] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 1424.893361] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 1426.897257] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 1426.897271] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 1428.902161] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 1428.902174] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 1430.906121] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 1430.906135] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 1444.932552] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 1444.932566] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 1448.939832] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 1448.939846] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 1452.948071] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 1452.948083] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 1454.952351] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 1454.952364] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 1456.956155] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 1456.956168] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 1462.969056] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 1462.969075] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 1464.973045] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 1464.973058] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 1466.976963] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 1466.976977] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 1481.005506] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 1497.037405] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 1512.154653] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-LPS_CTRL_LEAVE
[ 1512.154667] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 1512.159100] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_SLEEP] macid=0, org reg_0x4d4=0x00000000
[ 1513.300985] RTL871X: Drop duplicate management frame with seq_num = 1243.
[ 1513.908580] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 1515.096204] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 1515.128826] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 1516.354953] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 1516.388450] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000001
[ 1516.390701] RTL871X: survey done event(a) band:0 for wlan0
[ 1516.390722] RTL871X: rtw_indicate_scan_done(wlan0)
[ 1517.076960] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 1517.076973] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 1527.098320] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 1543.129338] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 1573.189399] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 1589.221586] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 1605.253828] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 1621.285504] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 1632.154229] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-LPS_CTRL_LEAVE
[ 1632.154242] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 1632.158519] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_SLEEP] macid=0, org reg_0x4d4=0x00000000
[ 1633.888201] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 1635.328578] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 1635.361200] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 1636.324955] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 1636.358702] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000001
[ 1636.361322] RTL871X: survey done event(b) band:0 for wlan0
[ 1636.361344] RTL871X: rtw_indicate_scan_done(wlan0)
[ 1637.317791] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 1637.319516] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 1637.319611] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 1681.405505] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 1697.437540] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 1713.469849] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 1729.501175] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 1745.535716] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 1752.154323] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-LPS_CTRL_LEAVE
[ 1752.154336] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 1752.158672] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_SLEEP] macid=0, org reg_0x4d4=0x00000000
[ 1753.920204] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 1755.558706] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 1755.591327] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 1756.388577] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 1756.422077] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000001
[ 1756.424200] RTL871X: survey done event(5) band:0 for wlan0
[ 1756.424220] RTL871X: rtw_indicate_scan_done(wlan0)
[ 1757.556405] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 1757.556419] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 1777.597535] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 1793.629520] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 1831.705913] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 1863.769843] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 1872.153649] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-LPS_CTRL_LEAVE
[ 1872.153662] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 1872.158504] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_SLEEP] macid=0, org reg_0x4d4=0x00000000
[ 1873.565111] RTL871X: Drop duplicate management frame with seq_num = 1083.
[ 1873.568982] RTL871X: Drop duplicate management frame with seq_num = 1083.
[ 1873.916577] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 1875.796956] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 1875.828955] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000001
[ 1875.838575] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 1876.378830] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 1876.412702] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 1876.414700] RTL871X: survey done event(b) band:0 for wlan0
[ 1876.414721] RTL871X: rtw_indicate_scan_done(wlan0)
[ 1877.797027] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 1877.797041] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 1891.826629] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 1907.857757] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 1923.890618] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 1939.922597] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 1980.003350] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 1992.152615] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-LPS_CTRL_LEAVE
[ 1992.152628] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 1992.158672] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_SLEEP] macid=0, org reg_0x4d4=0x00000000
[ 1993.167360] RTL871X: Drop duplicate management frame with seq_num = 2379.
[ 1993.916952] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 1994.032829] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 1994.065826] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 1996.047831] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 1996.079830] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000001
[ 1996.087076] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 1996.405701] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 1996.439202] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 1996.441701] RTL871X: survey done event(a) band:0 for wlan0
[ 1996.441720] RTL871X: rtw_indicate_scan_done(wlan0)
[ 1998.037322] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 1998.037336] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 2012.066243] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 2028.097511] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 2044.129804] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 2084.209406] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 2104.249660] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 2112.153724] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-LPS_CTRL_LEAVE
[ 2112.153738] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 2112.162557] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_SLEEP] macid=0, org reg_0x4d4=0x00000000
[ 2113.170862] RTL871X: Drop duplicate management frame with seq_num = 3734.
[ 2113.307735] RTL871X: Drop duplicate management frame with seq_num = 3737.
[ 2113.918076] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 2114.275204] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 2114.308076] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 2116.286703] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 2116.318456] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000001
[ 2116.325699] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 2116.388201] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 2116.421701] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 2116.424204] RTL871X: survey done event(a) band:0 for wlan0
[ 2116.424224] RTL871X: rtw_indicate_scan_done(wlan0)
[ 2118.277053] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 2118.277068] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 2132.305533] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 2148.337504] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 2180.401411] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 2196.434982] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 2212.466309] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 2228.497516] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 2232.153934] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-LPS_CTRL_LEAVE
[ 2232.153948] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 2232.160381] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_SLEEP] macid=0, org reg_0x4d4=0x00000000
[ 2233.156487] RTL871X: Drop duplicate management frame with seq_num = 930.
[ 2233.160593] RTL871X: Drop duplicate management frame with seq_num = 930.
[ 2233.883581] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 2234.511453] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 2234.544826] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 2236.359329] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 2236.392827] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000001
[ 2236.394951] RTL871X: survey done event(9) band:0 for wlan0
[ 2236.394971] RTL871X: rtw_indicate_scan_done(wlan0)
[ 2236.512210] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 2236.512223] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 2244.528894] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 2260.560869] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 2284.609070] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 2300.640683] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 2300.640696] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 2302.644655] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 2302.644670] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 2326.693402] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 2342.724698] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 2352.153903] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-LPS_CTRL_LEAVE
[ 2352.153917] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 2352.157081] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_SLEEP] macid=0, org reg_0x4d4=0x00000000
[ 2353.276485] RTL871X: Drop duplicate management frame with seq_num = 2273.
[ 2353.282085] RTL871X: Drop duplicate management frame with seq_num = 2273.
[ 2353.285877] RTL871X: Drop duplicate management frame with seq_num = 2273.
[ 2353.290082] RTL871X: Drop duplicate management frame with seq_num = 2273.
[ 2353.887703] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 2354.752205] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 2354.785576] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 2356.348327] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 2356.381827] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000001
[ 2356.384078] RTL871X: survey done event(8) band:0 for wlan0
[ 2356.384099] RTL871X: rtw_indicate_scan_done(wlan0)
[ 2356.752369] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 2356.752383] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 2358.756947] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 2386.813663] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 2402.845936] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 2418.877752] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 2434.909233] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 2450.941822] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 2466.973587] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 2472.153623] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-LPS_CTRL_LEAVE
[ 2472.153636] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 2472.156981] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_SLEEP] macid=0, org reg_0x4d4=0x00000000
[ 2473.223988] RTL871X: Drop duplicate management frame with seq_num = 3576.
[ 2473.228459] RTL871X: Drop duplicate management frame with seq_num = 3576.
[ 2473.973076] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 2474.993076] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 2475.025953] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 2476.464328] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 2476.497826] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000001
[ 2476.500079] RTL871X: survey done event(8) band:0 for wlan0
[ 2476.500099] RTL871X: rtw_indicate_scan_done(wlan0)
[ 2476.993169] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 2476.993183] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 2485.009383] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 2501.043411] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 2517.073507] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 2533.107714] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 2549.138624] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 2565.170394] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 2592.154262] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-LPS_CTRL_LEAVE
[ 2592.154276] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 2592.159622] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_SLEEP] macid=0, org reg_0x4d4=0x00000000
[ 2593.952010] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 2595.230833] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 2595.263594] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 2596.446330] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 2596.479830] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000001
[ 2596.482200] RTL871X: survey done event(8) band:0 for wlan0
[ 2596.482220] RTL871X: rtw_indicate_scan_done(wlan0)
[ 2597.232940] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 2597.232954] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 2601.241739] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 2617.274306] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 2633.307713] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 2649.339345] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 2657.351974] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 2657.351986] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 2665.368573] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 2665.368587] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 2667.372538] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 2667.372552] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 2669.378117] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 2669.378131] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 2699.438979] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 2712.153402] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-LPS_CTRL_LEAVE
[ 2712.153415] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 2712.158395] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_SLEEP] macid=0, org reg_0x4d4=0x00000000
[ 2713.912206] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 2715.486955] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 2715.517078] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000001
[ 2715.523951] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 2716.357327] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 2716.390827] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 2716.393202] RTL871X: survey done event(4) band:0 for wlan0
[ 2716.393223] RTL871X: rtw_indicate_scan_done(wlan0)
[ 2717.473327] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 2717.473341] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 2731.501505] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 2743.992315] RTL871X: recv eapol packet
[ 2743.992638] RTL871X: ~~~~set sta key:groupkey
[ 2743.992649] RTL871X: ==> rtw_set_key algorithm(4),keyid(1),key_mask(0)
[ 2743.992710] RTL871X: send eapol packet
[ 2743.996469] RTL871X: set group key camid:6, addr:08:60:6e:be:f2:60, kid:1, type:AES
[ 2743.997327] RTL871X: SetHwReg8812A, 5703, RCR= f40760ce
[ 2744.014370] RTL871X: recv eapol packet
[ 2744.014728] RTL871X: send eapol packet
[ 2761.561137] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 2777.593508] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 2795.629998] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 2811.661433] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 2827.693596] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 2832.154659] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-LPS_CTRL_LEAVE
[ 2832.154672] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 2832.157837] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_SLEEP] macid=0, org reg_0x4d4=0x00000000
[ 2833.894579] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 2835.710827] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 2835.742708] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000001
[ 2835.751704] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 2836.294706] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 2836.328954] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 2836.331078] RTL871X: survey done event(4) band:0 for wlan0
[ 2836.331099] RTL871X: rtw_indicate_scan_done(wlan0)
[ 2837.712683] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 2837.712698] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 2851.741120] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 2867.773053] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 2885.808265] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 2885.808278] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 2889.816767] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 2889.816781] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 2903.844946] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 2919.876333] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 2935.909478] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 2951.941089] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 2952.153976] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-LPS_CTRL_LEAVE
[ 2952.153989] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 2952.156017] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_SLEEP] macid=0, org reg_0x4d4=0x00000000
[ 2953.880328] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 2953.948452] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 2953.981076] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 2955.950453] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 2955.982079] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000001
[ 2955.989327] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 2956.298702] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 2956.332203] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 2956.335199] RTL871X: survey done event(4) band:0 for wlan0
[ 2956.335219] RTL871X: rtw_indicate_scan_done(wlan0)
[ 2957.952648] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 2957.952662] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 2967.998160] RTL871X: issue_probereq_ex(wlan0) to 08:60:6e:be:f2:60, ch:10, 3/3 in 24 ms
[ 2967.998333] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 2968.028471] RTL871X: issue_nulldata(wlan0) to 08:60:6e:be:f2:60, ch:10, 3/3 in 32 ms
[ 2970.007003] RTL871X: issue_probereq_ex(wlan0) to 08:60:6e:be:f2:60, ch:10, 3/3 in 28 ms
[ 2970.007274] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 2970.039034] RTL871X: issue_nulldata(wlan0) to 08:60:6e:be:f2:60, ch:10, 3/3 in 32 ms
[ 2972.006993] RTL871X: issue_probereq_ex(wlan0) to 08:60:6e:be:f2:60, ch:10, 3/3 in 24 ms
[ 2972.007300] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 2972.041085] RTL871X: issue_nulldata(wlan0) to 08:60:6e:be:f2:60, ch:10, 3/3 in 36 ms
[ 2974.011202] RTL871X: issue_probereq_ex(wlan0) to 08:60:6e:be:f2:60, ch:10, 3/3 in 24 ms
[ 2974.011444] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 2974.041448] RTL871X: issue_nulldata(wlan0) to 08:60:6e:be:f2:60, ch:10, 3/3 in 32 ms
[ 2976.014955] RTL871X: issue_probereq_ex(wlan0) to 08:60:6e:be:f2:60, ch:10, 3/3 in 24 ms
[ 2976.015200] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 2976.048848] RTL871X: issue_nulldata(wlan0) to 08:60:6e:be:f2:60, ch:10, 3/3 in 36 ms
[ 2976.048858] RTL871X: linked_status_chk(wlan0) disconnect or roaming
[ 2976.048865] RTL871X: receive_disconnect
[ 2976.048879] RTL871X: report_del_sta_event: delete STA, mac_id=0
[ 2976.053715] RTL871X: rtw_stadel_event_callback(mac_id=0)=08:60:6e:be:f2:60
[ 2976.053724] RTL871X: [MacId], Set MacId Ctrl(original) = 0x0
[ 2976.054824] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 2976.056994] RTL871X: ### Clean STA_(0) info ###
[ 2976.057004] RTL871X: free disconnecting network
[ 2976.057028] RTL871X: roaming from Shadownetwork 2.4Ghz(08:60:6e:be:f2:60), length:20
[ 2976.057051] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-LPS_CTRL_DISCONNECT
[ 2976.057060] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 2976.058574] RTL871X: rtl8812_set_FwJoinBssReport_cmd mstatus(0)
[ 2976.058587] RTL871X: beamforming_deinit_entry Idx 0
[ 2976.058594] RTL871X: beamforming_notify BeamformState 0 bSounding 0
[ 2977.730574] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 2980.184829] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 2980.219083] RTL871X: survey done event(0) band:0 for wlan0
[ 2980.219103] RTL871X: rtw_select_and_join_from_scanned_queue: return _FAIL(candidate == NULL)
[ 2980.219111] RTL871X: try_to_join, but select scanning queue fail, to_roam:2
[ 2980.219127] RTL871X: rtw_indicate_scan_done(wlan0)
[ 2981.929079] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 2984.359330] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 2984.393578] RTL871X: survey done event(1) band:0 for wlan0
[ 2984.393598] RTL871X: rtw_select_and_join_from_scanned_queue: return _FAIL(candidate == NULL)
[ 2984.393606] RTL871X: try_to_join, but select scanning queue fail, to_roam:1
[ 2984.393696] RTL871X: indicate disassoc
[ 2984.393766] RTL871X: rtw_indicate_scan_done(wlan0)
[ 2984.393797] RTL871X: rtl8812_set_FwJoinBssReport_cmd mstatus(0)
[ 2984.393809] RTL871X: beamforming_deinit_entry Idx 0
[ 2984.393817] RTL871X: beamforming_notify BeamformState 0 bSounding 0
[ 2984.399574] RTL871X: ==>rtw_ps_processor .fw_state(8)
[ 2984.399581] RTL871X: ==>ips_enter cnts:2
[ 2984.399586] RTL871X: nolinked power save enter
[ 2984.399591] RTL871X: ===> rtw_ips_pwr_down...................
[ 2984.399597] RTL871X: ====> rtw_ips_dev_unload...
[ 2984.410368] RTL871X: usb_read_port_cancel
[ 2984.410452] RTL871X: usb_read_port_complete() RX Warning! bDriverStopped(0) OR bSurpriseRemoved(0)
[ 2984.410571] RTL871X: usb_read_port_complete() RX Warning! bDriverStopped(0) OR bSurpriseRemoved(0)
[ 2984.410695] RTL871X: usb_read_port_complete() RX Warning! bDriverStopped(0) OR bSurpriseRemoved(0)
[ 2984.410821] RTL871X: usb_read_port_complete() RX Warning! bDriverStopped(0) OR bSurpriseRemoved(0)
[ 2984.410944] RTL871X: usb_read_port_complete() RX Warning! bDriverStopped(0) OR bSurpriseRemoved(0)
[ 2984.411070] RTL871X: usb_read_port_complete() RX Warning! bDriverStopped(0) OR bSurpriseRemoved(0)
[ 2984.411196] RTL871X: usb_read_port_complete() RX Warning! bDriverStopped(0) OR bSurpriseRemoved(0)
[ 2984.411321] RTL871X: usb_read_port_complete() RX Warning! bDriverStopped(0) OR bSurpriseRemoved(0)
[ 2984.411340] RTL871X: usb_write_port_cancel
[ 2984.411371] RTL871X: ==> rtl8812au_hal_deinit
[ 2984.412696] RTL871X: hal_poweroff_8812au
[ 2984.417317] RTL871X: =====> _8051Reset8812(): 8051 reset success .
[ 2984.423571] RTL871X: SetHwReg8812A: bMacPwrCtrlOn=0
[ 2984.423820] RTL871X: <=== rtw_ips_pwr_down..................... in 24ms
[ 2985.227240] RTL871X: _rtw_pwr_wakeup call ips_leave....
[ 2985.227251] RTL871X: ==>ips_leave cnts:2
[ 2985.227257] RTL871X: ===> rtw_ips_pwr_up..............
[ 2985.227269] RTL871X: ===> ips_netdrv_open.........
[ 2985.227835] RTL871X: power-on :REG_SYS_CLKR 0x09=0xb0. REG_CR 0x100=0xea.
[ 2985.227842] RTL871X: MAC has not been powered on yet.
[ 2985.234450] RTL871X: SetHwReg8812A: bMacPwrCtrlOn=1
[ 2985.300450] RTL871X: FirmwareDownload8812 fw source from Header
[ 2985.300461] RTL871X: FirmwareDownload8812 fw:NIC, size: 31936
[ 2985.300469] RTL871X: FirmwareDownload8812: fw_ver=38 fw_subver=0 sig=0x9501
[ 2985.344076] RTL871X: polling_fwdl_chksum: Checksum report OK! (1, 0ms), REG_MCUFWDL:0x00070705
[ 2985.345944] RTL871X: =====> _8051Reset8812(): 8051 reset success .
[ 2985.373950] RTL871X: _FWFreeToGo8812: Polling FW ready OK! (220, 28ms), REG_MCUFWDL:0x000707c6
[ 2985.373958] RTL871X: FWDL success. write_fw:1, 72ms
[ 2985.373966] RTL871X: rtl8812au_hal_init: Download Firmware Success!!
[ 2985.399200] RTL871X: ===> phy_BB8812_Config_ParaFile() EEPROMRegulatory 1
[ 2985.720953] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 2986.438456] RTL871X: pDM_Odm TxPowerTrackControl = 1
[ 2986.440581] RTL871X: MAC Address from REG_MACID = 9c:5c:8e:b2:b5:a9
[ 2986.440592] RTL871X: rtl8812au_hal_init in 1216ms
[ 2986.474815] RTL871X: hw_var_set_opmode()-4935 mode = 2
[ 2986.475336] RTL871X: <=== rtw_ips_pwr_up.............. in 1248ms
[ 2986.475341] RTL871X: nolinked power save leave
[ 2986.475438] RTL871X: ==> ips_leave.....LED(0x00028220)...
[ 2988.172946] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 2990.584829] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 2990.619818] RTL871X: survey done event(0) band:0 for wlan0
[ 2990.619834] RTL871X: rtw_indicate_scan_done(wlan0)
[ 2990.627444] RTL871X: ==>rtw_ps_processor .fw_state(8)
[ 2990.627450] RTL871X: ==>ips_enter cnts:3
[ 2990.627453] RTL871X: nolinked power save enter
[ 2990.627456] RTL871X: ===> rtw_ips_pwr_down...................
[ 2990.627460] RTL871X: ====> rtw_ips_dev_unload...
[ 2990.638764] RTL871X: usb_read_port_cancel
[ 2990.638950] RTL871X: usb_read_port_complete() RX Warning! bDriverStopped(0) OR bSurpriseRemoved(0)
[ 2990.639065] RTL871X: usb_read_port_complete() RX Warning! bDriverStopped(0) OR bSurpriseRemoved(0)
[ 2990.639187] RTL871X: usb_read_port_complete() RX Warning! bDriverStopped(0) OR bSurpriseRemoved(0)
[ 2990.639315] RTL871X: usb_read_port_complete() RX Warning! bDriverStopped(0) OR bSurpriseRemoved(0)
[ 2990.639443] RTL871X: usb_read_port_complete() RX Warning! bDriverStopped(0) OR bSurpriseRemoved(0)
[ 2990.639796] RTL871X: usb_read_port_complete() RX Warning! bDriverStopped(0) OR bSurpriseRemoved(0)
[ 2990.639969] RTL871X: usb_read_port_complete() RX Warning! bDriverStopped(0) OR bSurpriseRemoved(0)
[ 2990.640199] RTL871X: usb_read_port_complete() RX Warning! bDriverStopped(0) OR bSurpriseRemoved(0)
[ 2990.640215] RTL871X: usb_write_port_cancel
[ 2990.640238] RTL871X: ==> rtl8812au_hal_deinit
[ 2990.641432] RTL871X: hal_poweroff_8812au
[ 2990.645816] RTL871X: =====> _8051Reset8812(): 8051 reset success .
[ 2990.652446] RTL871X: SetHwReg8812A: bMacPwrCtrlOn=0
[ 2990.652690] RTL871X: <=== rtw_ips_pwr_down..................... in 28ms
[ 2995.622678] RTL871X: _rtw_pwr_wakeup call ips_leave....
[ 2995.622688] RTL871X: ==>ips_leave cnts:3
[ 2995.622694] RTL871X: ===> rtw_ips_pwr_up..............
[ 2995.622705] RTL871X: ===> ips_netdrv_open.........
[ 2995.622979] RTL871X: power-on :REG_SYS_CLKR 0x09=0xb0. REG_CR 0x100=0xea.
[ 2995.622986] RTL871X: MAC has not been powered on yet.
[ 2995.628828] RTL871X: SetHwReg8812A: bMacPwrCtrlOn=1
[ 2995.696577] RTL871X: FirmwareDownload8812 fw source from Header
[ 2995.696589] RTL871X: FirmwareDownload8812 fw:NIC, size: 31936
[ 2995.696597] RTL871X: FirmwareDownload8812: fw_ver=38 fw_subver=0 sig=0x9501
[ 2995.743329] RTL871X: polling_fwdl_chksum: Checksum report OK! (1, 0ms), REG_MCUFWDL:0x00070705
[ 2995.745195] RTL871X: =====> _8051Reset8812(): 8051 reset success .
[ 2995.773201] RTL871X: _FWFreeToGo8812: Polling FW ready OK! (224, 28ms), REG_MCUFWDL:0x000707c6
[ 2995.773211] RTL871X: FWDL success. write_fw:1, 76ms
[ 2995.773219] RTL871X: rtl8812au_hal_init: Download Firmware Success!!
[ 2995.798197] RTL871X: ===> phy_BB8812_Config_ParaFile() EEPROMRegulatory 1
[ 2996.120329] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 2996.839814] RTL871X: pDM_Odm TxPowerTrackControl = 1
[ 2996.841812] RTL871X: MAC Address from REG_MACID = 9c:5c:8e:b2:b5:a9
[ 2996.841818] RTL871X: rtl8812au_hal_init in 1220ms
[ 2996.875202] RTL871X: hw_var_set_opmode()-4935 mode = 2
[ 2996.875738] RTL871X: <=== rtw_ips_pwr_up.............. in 1256ms
[ 2996.875746] RTL871X: nolinked power save leave
[ 2996.875951] RTL871X: ==> ips_leave.....LED(0x00028220)...
[ 2996.875961] RTL871X: IW_SCAN_THIS_ESSID, ssid=Shadownetwork 2.4Ghz, len=20
[ 2998.556451] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 3001.005204] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 3001.040079] RTL871X: survey done event(1) band:0 for wlan0
[ 3001.040103] RTL871X: rtw_indicate_scan_done(wlan0)
[ 3001.040934] RTL871X: wpa_set_auth_algs, AUTH_ALG_OPEN_SYSTEM
[ 3001.040948] RTL871X: set_mode = IW_MODE_INFRA
[ 3001.040988] RTL871X:
[ 3001.040991] wpa_ie(length:22):
[ 3001.040999] RTL871X: 0x30 0x14 0x01 0x00 0x00 0x0f 0xac 0x04
[ 3001.041006] RTL871X: 0x01 0x00 0x00 0x0f 0xac 0x04 0x01 0x00
[ 3001.041014] RTL871X: 0x00 0x0f 0xac 0x02 0x00 0x00 0x00 0x00
[ 3001.041702] RTL871X: SetHwReg8812A, 5710, RCR= f40060ca
[ 3001.041828] RTL871X: hw_var_set_opmode()-4935 mode = 2
[ 3001.041838] RTL871X: rtw_wx_set_freq: set to channel 10
[ 3001.041868] RTL871X: =>rtw_wx_set_essid
[ 3001.041874] RTL871X: ssid=Shadownetwork 2.4Ghz, len=20
[ 3001.041887] RTL871X: set ssid [Shadownetwork 2.4Ghz] fw_state=0x00000008
[ 3001.041893] RTL871X: Set SSID under fw_state=0x00000008
[ 3001.041906] RTL871X: [by_bssid:0][assoc_ssid:Shadownetwork 2.4Ghz][to_roam:0] new candidate: Shadownetwork 2.4Ghz(08:60:6e:be:f2:60, ch10) rssi:-58
[ 3001.041917] RTL871X: rtw_select_and_join_from_scanned_queue: candidate: Shadownetwork 2.4Ghz(08:60:6e:be:f2:60, ch:10)
[ 3001.041930] RTL871X: link to Broadcom AP
[ 3001.041940] RTL871X: [HT] HAL Support STBC = 0x01
[ 3001.041947] RTL871X: [HT] Declare supporting RX STBC_2R
[ 3001.041955] RTL871X: [VHT] Support STBC = 0x03
[ 3001.041960] RTL871X: [VHT] Support Beamformee
[ 3001.041971] RTL871X: <=rtw_wx_set_essid, ret 0
[ 3001.041998] RTL871X: set bssid:08:60:6e:be:f2:60
[ 3001.042005] RTL871X: Set BSSID under fw_state=0x00000088
[ 3001.042462] RTL871X: start_join_set_ch_bw: ch=10, bwmode=0, ch_offset=0
[ 3001.111492] RTL871X: OnBeacon: beacon keys ready
[ 3001.111505] RTL871X: link to Broadcom AP
[ 3001.111513] RTL871X: start auth
[ 3001.111537] RTL871X: issue_auth
[ 3001.114855] RTL871X: OnAuthClient
[ 3001.114863] RTL871X: auth success, start assoc
[ 3001.114878] RTL871X: network.SupportedRates[0]=82
[ 3001.114884] RTL871X: network.SupportedRates[1]=84
[ 3001.114889] RTL871X: network.SupportedRates[2]=8B
[ 3001.114894] RTL871X: network.SupportedRates[3]=96
[ 3001.114900] RTL871X: network.SupportedRates[4]=24
[ 3001.114905] RTL871X: network.SupportedRates[5]=30
[ 3001.114910] RTL871X: network.SupportedRates[6]=48
[ 3001.114916] RTL871X: network.SupportedRates[7]=6C
[ 3001.114921] RTL871X: network.SupportedRates[8]=0C
[ 3001.114926] RTL871X: network.SupportedRates[9]=12
[ 3001.114932] RTL871X: network.SupportedRates[10]=18
[ 3001.114937] RTL871X: network.SupportedRates[11]=60
[ 3001.114943] RTL871X: bssrate_len = 12
[ 3001.119682] RTL871X: OnAssocRsp
[ 3001.119701] RTL871X: report_join_res(8)
[ 3001.119710] RTL871X: rtw_joinbss_update_network
[ 3001.119718] RTL871X: +rtw_update_ht_cap()
[ 3001.119735] RTL871X: rtw_alloc_macid(wlan0) if1, hwaddr:08:60:6e:be:f2:60 macid:0
[ 3001.119742] RTL871X: rtw_joinbss_update_stainfo
[ 3001.119777] RTL871X: supp_mcs_set = ff, ff, 00, rf_type=2, tx_ra_bitmap=000000000fffffff
[ 3001.119784] RTL871X: ### Set STA_(0) info ###
[ 3001.119794] RTL871X: assoc success
[ 3001.119870] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 3001.120945] RTL871X: WMM(0): 0, a42b
[ 3001.121067] RTL871X: WMM(1): 0, a44f
[ 3001.121247] RTL871X: WMM(2): 0, 5e4322
[ 3001.121662] RTL871X: WMM(3): 0, 2f3222
[ 3001.121670] RTL871X: wmm_para_seq(0): 0
[ 3001.121675] RTL871X: wmm_para_seq(1): 1
[ 3001.121681] RTL871X: wmm_para_seq(2): 2
[ 3001.121686] RTL871X: wmm_para_seq(3): 3
[ 3001.121692] RTL871X: HTOnAssocRsp
[ 3001.121826] RTL871X: VHTOnAssocRsp
[ 3001.121843] RTL871X: ODM_Get_Rate_Bitmap ==> rssi_level:0x00, WirelessMode:0x0b, rate_bitmap:0x0f8ff005
[ 3001.121853] RTL871X: UpdateHalRAMask8812A => mac_id:0, networkType:0x0b, mask:0x0fffffff
[ 3001.121856] ==> rssi_level:0, rate_bitmap:0x0f8ff005, psta->raid=2
[ 3001.122945] RTL871X: [MacId], Set MacId Ctrl(original) = 0x10000
[ 3001.124806] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 3001.126316] RTL871X: rtl8812_set_FwJoinBssReport_cmd mstatus(1)
[ 3001.127828] RTL871X: rtw_hal_set_fw_rsvd_page PageSize: 512, RsvdPageNUm: 7
[ 3001.127840] RTL871X: LocPsPoll: 2
[ 3001.127846] RTL871X: LocNullData: 3
[ 3001.127852] RTL871X: LocQosNull: 4
[ 3001.128072] RTL871X: rtw_hal_set_fw_rsvd_page: Set RSVD page location to Fw ,TotalPacketLen(2634), TotalPageNum(5)
[ 3001.128081] RTL871X: RsvdPageLoc: ProbeRsp=0 PsPoll=2 Null=3 QoSNull=4 BTNull=0
[ 3001.129073] RTL871X: wlan0: 1 DL RSVD page success! DLBcnCount:1, poll:1
[ 3001.129504] RTL871X: OnAction_back
[ 3001.129514] RTL871X: OnAction_back, action=0
[ 3001.129537] RTL871X: issue_addba_rsp(wlan0) ra=08:60:6e:be:f2:60 status=0, tid=0, size=64
[ 3001.129817] RTL871X: Set RSVD page location to Fw.
[ 3001.129945] RTL871X: =>mlmeext_joinbss_event_callback
[ 3001.131484] RTL871X: recv eapol packet
[ 3001.133943] RTL871X: send eapol packet
[ 3001.150901] RTL871X: recv eapol packet
[ 3001.151116] RTL871X: send eapol packet
[ 3001.151177] RTL871X: ~~~~set sta key:unicastkey
[ 3001.151333] RTL871X: ~~~~set sta key:groupkey
[ 3001.151343] RTL871X: ==> rtw_set_key algorithm(4),keyid(1),key_mask(0)
[ 3001.151565] RTL871X: set pairwise key camid:4, addr:08:60:6e:be:f2:60, kid:0, type:AES
[ 3001.154829] RTL871X: set group key camid:5, addr:08:60:6e:be:f2:60, kid:1, type:AES
[ 3001.155198] RTL871X: SetHwReg8812A, 5703, RCR= f40060ce
[ 3003.056074] RTL871X: ODM_Get_Rate_Bitmap ==> rssi_level:0x02, WirelessMode:0x0b, rate_bitmap:0x0f8ff000
[ 3003.056083] RTL871X: UpdateHalRAMask8812A => mac_id:0, networkType:0x0b, mask:0x0fffffff
[ 3003.056085] ==> rssi_level:2, rate_bitmap:0x0f8ff000, psta->raid=2
[ 3011.559563] wlan0: no IPv6 routers present
[ 3021.084628] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 3021.084648] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 3051.145218] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 3072.153809] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-LPS_CTRL_LEAVE
[ 3072.153823] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 3072.158423] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_SLEEP] macid=0, org reg_0x4d4=0x00000000
[ 3074.020453] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 3075.204079] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 3075.237074] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 3076.447828] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 3076.482942] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000001
[ 3076.486940] RTL871X: survey done event(5) band:0 for wlan0
[ 3076.486954] RTL871X: rtw_indicate_scan_done(wlan0)
[ 3077.198111] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 3077.198126] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 3083.209450] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 3097.240017] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 3112.158446] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-LPS_CTRL_LEAVE
[ 3112.158460] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 3112.164162] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_SLEEP] macid=0, org reg_0x4d4=0x00000000
[ 3113.911065] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 3115.274829] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 3115.333333] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000001
[ 3115.342827] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 3116.400830] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 3116.434325] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 3116.436451] RTL871X: survey done event(0) band:0 for wlan0
[ 3116.436472] RTL871X: rtw_indicate_scan_done(wlan0)
[ 3117.277291] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 3117.277305] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 3131.304067] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 3131.304076] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 3135.312954] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 3135.312969] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 3137.316736] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 3137.316749] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 3141.324020] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 3141.324034] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 3155.352992] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 3171.385128] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 3172.157406] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-LPS_CTRL_LEAVE
[ 3172.157420] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 3172.162246] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_SLEEP] macid=0, org reg_0x4d4=0x00000000
[ 3173.896711] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 3175.399079] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 3175.431831] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 3176.360579] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 3176.394078] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000001
[ 3176.396579] RTL871X: survey done event(3) band:0 for wlan0
[ 3176.396600] RTL871X: rtw_indicate_scan_done(wlan0)
[ 3177.396980] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 3177.396994] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 3229.502470] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 3252.154370] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-LPS_CTRL_LEAVE
[ 3252.154384] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 3252.159394] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_SLEEP] macid=0, org reg_0x4d4=0x00000000
[ 3253.917076] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 3255.557828] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 3255.589334] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000001
[ 3255.596575] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 3256.399453] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 3256.432951] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 3256.435451] RTL871X: survey done event(5) band:0 for wlan0
[ 3256.435510] RTL871X: rtw_indicate_scan_done(wlan0)
[ 3257.557751] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 3257.557765] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 3275.593149] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 3291.633548] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 3295.635334] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 3313.669692] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 3323.687822] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 3323.687831] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 3325.691960] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 3325.691974] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 3341.724204] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 3341.724215] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 3343.728069] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 3343.728083] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 3347.736662] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 3347.736676] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 3349.739825] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 3349.739835] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 3352.158706] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-LPS_CTRL_LEAVE
[ 3352.158720] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 3352.164780] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_SLEEP] macid=0, org reg_0x4d4=0x00000000
[ 3353.945827] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 3355.764078] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 3355.796700] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 3356.372704] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 3356.406200] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000001
[ 3356.408578] RTL871X: survey done event(4) band:0 for wlan0
[ 3356.408598] RTL871X: rtw_indicate_scan_done(wlan0)
[ 3357.756014] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 3357.756028] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 3363.769397] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 3367.777330] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 3367.777343] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 3373.788355] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 3373.788369] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 3375.792024] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 3375.792037] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 3379.800337] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 3379.800350] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 3393.828913] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 3409.865011] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 3441.947961] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 3447.947831] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 3447.978398] RTL871X: issue_nulldata(wlan0) to 08:60:6e:be:f2:60, ch:10, 3/3 in 32 ms
[ 3449.945704] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 3472.157962] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-LPS_CTRL_LEAVE
[ 3472.157975] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 3472.159635] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_SLEEP] macid=0, org reg_0x4d4=0x00000000
[ 3473.878453] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 3473.994568] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 3474.025328] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000001
[ 3474.030199] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 3475.998587] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 3476.030081] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 3476.037454] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 3476.318201] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 3476.354201] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 3476.356454] RTL871X: survey done event(7) band:0 for wlan0
[ 3476.356477] RTL871X: rtw_indicate_scan_done(wlan0)
[ 3477.999831] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 3477.999845] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 3506.055951] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 3538.119952] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 3568.179953] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 3584.211953] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 3592.155371] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-LPS_CTRL_LEAVE
[ 3592.155385] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 3592.157207] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_SLEEP] macid=0, org reg_0x4d4=0x00000000
[ 3593.146989] RTL871X: Drop duplicate management frame with seq_num = 3850.
[ 3593.874452] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 3594.234582] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 3594.267698] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 3596.238589] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 3596.270952] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000001
[ 3596.278455] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 3596.311200] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 3596.344954] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 3596.347200] RTL871X: survey done event(9) band:0 for wlan0
[ 3596.347223] RTL871X: rtw_indicate_scan_done(wlan0)
[ 3598.239830] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 3598.239845] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 3646.335832] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 3646.335846] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 3650.343835] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 3650.343848] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 3712.153042] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-LPS_CTRL_LEAVE
[ 3712.153056] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 3712.155084] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_SLEEP] macid=0, org reg_0x4d4=0x00000000
[ 3713.151266] RTL871X: Drop duplicate management frame with seq_num = 1072.
[ 3713.155881] RTL871X: Drop duplicate management frame with seq_num = 1072.
[ 3713.874451] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 3714.474473] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 3714.507604] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 3716.274326] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 3716.308198] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000001
[ 3716.310951] RTL871X: survey done event(6) band:0 for wlan0
[ 3716.310972] RTL871X: rtw_indicate_scan_done(wlan0)
[ 3716.475954] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 3716.475968] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 3724.491954] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 3750.543952] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 3766.575951] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 3782.607951] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 3798.639951] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 3814.671964] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 3832.157401] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-LPS_CTRL_LEAVE
[ 3832.157415] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 3832.159208] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_SLEEP] macid=0, org reg_0x4d4=0x00000000
[ 3833.922588] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 3834.714463] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 3834.748075] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 3836.286201] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 3836.320084] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000001
[ 3836.322699] RTL871X: survey done event(7) band:0 for wlan0
[ 3836.322722] RTL871X: rtw_indicate_scan_done(wlan0)
[ 3836.715957] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 3836.715971] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 3846.735950] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 3862.767952] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 3878.799950] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 3894.831951] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 3910.864201] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 3926.896074] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 3952.153978] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-LPS_CTRL_LEAVE
[ 3952.153991] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 3952.155837] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_SLEEP] macid=0, org reg_0x4d4=0x00000000
[ 3952.977326] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000001
[ 3953.906454] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 3954.954459] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 3954.987576] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 3956.278201] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 3956.311825] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 3956.313946] RTL871X: survey done event(7) band:0 for wlan0
[ 3956.313968] RTL871X: rtw_indicate_scan_done(wlan0)
[ 3956.955956] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 3956.955970] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 3968.979950] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 3985.011954] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 4001.044327] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 4017.076078] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 4053.147952] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 4069.179939] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 4072.156382] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-LPS_CTRL_LEAVE
[ 4072.156397] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 4072.158340] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_SLEEP] macid=0, org reg_0x4d4=0x00000000
[ 4073.890436] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 4075.194447] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 4075.228708] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 4076.270445] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 4076.308212] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000001
[ 4076.310460] RTL871X: survey done event(4) band:0 for wlan0
[ 4076.310486] RTL871X: rtw_indicate_scan_done(wlan0)
[ 4077.195835] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 4077.195848] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 4085.211940] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 4101.243944] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 4117.275937] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 4133.307940] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 4155.351950] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 4171.383935] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 4187.415957] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 4192.157266] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-LPS_CTRL_LEAVE
[ 4192.157280] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 4192.159064] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_SLEEP] macid=0, org reg_0x4d4=0x00000000
[ 4193.537898] RTL871X: Drop duplicate management frame with seq_num = 2276.
[ 4193.542140] RTL871X: Drop duplicate management frame with seq_num = 2276.
[ 4193.546147] RTL871X: Drop duplicate management frame with seq_num = 2276.
[ 4193.882939] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 4195.434439] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 4195.467945] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 4196.258199] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 4196.292460] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000001
[ 4196.294952] RTL871X: survey done event(6) band:0 for wlan0
[ 4196.294973] RTL871X: rtw_indicate_scan_done(wlan0)
[ 4197.436077] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 4197.436091] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 4203.447937] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 4209.459815] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 4209.459824] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 4211.463833] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 4211.463842] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 4231.503952] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 4271.583941] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 4287.615937] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 4303.647957] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 4312.156255] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-LPS_CTRL_LEAVE
[ 4312.156269] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 4312.157938] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_SLEEP] macid=0, org reg_0x4d4=0x00000000
[ 4313.280243] RTL871X: Drop duplicate management frame with seq_num = 3554.
[ 4313.886705] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 4315.674559] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 4315.707948] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 4316.266189] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 4316.300824] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000001
[ 4316.303449] RTL871X: survey done event(7) band:0 for wlan0
[ 4316.303477] RTL871X: rtw_indicate_scan_done(wlan0)
[ 4317.675819] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 4317.675829] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 4319.679944] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 4335.711945] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 4367.776077] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 4383.807940] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 4399.839942] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 4415.871948] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 4431.903940] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 4432.156354] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-LPS_CTRL_LEAVE
[ 4432.156371] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 4432.158711] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_SLEEP] macid=0, org reg_0x4d4=0x00000000
[ 4433.274745] RTL871X: Drop duplicate management frame with seq_num = 748.
[ 4433.878441] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 4433.910438] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 4433.944315] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 4435.918696] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 4435.952579] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000001
[ 4435.959815] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 4436.270324] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 4436.306069] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 4436.308313] RTL871X: survey done event(9) band:0 for wlan0
[ 4436.308329] RTL871X: rtw_indicate_scan_done(wlan0)
[ 4437.915957] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 4437.915972] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 4465.972065] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 4482.003941] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 4498.035943] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 4514.067945] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 4530.099948] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 4552.153077] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-LPS_CTRL_LEAVE
[ 4552.153090] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 4552.154941] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_SLEEP] macid=0, org reg_0x4d4=0x00000000
[ 4553.526748] RTL871X: Drop duplicate management frame with seq_num = 2034.
[ 4553.530621] RTL871X: Drop duplicate management frame with seq_num = 2034.
[ 4553.874689] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 4554.153455] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 4554.188701] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 4556.162066] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 4556.194566] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000001
[ 4556.201824] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 4556.258691] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 4556.293687] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 4556.299943] RTL871X: survey done event(7) band:0 for wlan0
[ 4556.299959] RTL871X: rtw_indicate_scan_done(wlan0)
[ 4558.155817] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 4558.155826] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 4572.183953] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 4588.215936] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 4604.247951] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 4620.280069] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 4636.311943] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 4662.364077] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 4672.156223] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-LPS_CTRL_LEAVE
[ 4672.156236] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 4672.157957] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_SLEEP] macid=0, org reg_0x4d4=0x00000000
[ 4673.278737] RTL871X: Drop duplicate management frame with seq_num = 3333.
[ 4673.282934] RTL871X: Drop duplicate management frame with seq_num = 3333.
[ 4673.535969] RTL871X: Drop duplicate management frame with seq_num = 3339.
[ 4673.878582] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 4674.413453] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 4674.447960] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 4676.274205] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 4676.308202] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000001
[ 4676.310496] RTL871X: survey done event(9) band:0 for wlan0
[ 4676.310548] RTL871X: rtw_indicate_scan_done(wlan0)
[ 4676.391836] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 4676.391849] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 4678.395953] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 4694.427942] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 4710.459953] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 4726.492076] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 4742.523951] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 4760.559952] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 4776.591950] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 4792.153142] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-LPS_CTRL_LEAVE
[ 4792.153155] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 4792.154818] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_SLEEP] macid=0, org reg_0x4d4=0x00000000
[ 4792.652811] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000001
[ 4793.279102] RTL871X: Drop duplicate management frame with seq_num = 517.
[ 4793.878702] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 4794.630830] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 4794.664702] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 4796.322339] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 4796.357705] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 4796.359835] RTL871X: survey done event(6) band:0 for wlan0
[ 4796.359860] RTL871X: rtw_indicate_scan_done(wlan0)
[ 4796.631817] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 4796.631826] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 4808.656208] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 4824.687944] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 4856.751951] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 4872.783949] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 4888.816072] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 4904.847951] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 4912.156323] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-LPS_CTRL_LEAVE
[ 4912.156339] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 4912.157941] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_SLEEP] macid=0, org reg_0x4d4=0x00000000
[ 4913.278117] RTL871X: Drop duplicate management frame with seq_num = 1778.
[ 4913.282372] RTL871X: Drop duplicate management frame with seq_num = 1778.
[ 4913.286489] RTL871X: Drop duplicate management frame with seq_num = 1778.
[ 4913.531267] RTL871X: Drop duplicate management frame with seq_num = 1783.
[ 4913.535422] RTL871X: Drop duplicate management frame with seq_num = 1783.
[ 4913.539511] RTL871X: Drop duplicate management frame with seq_num = 1783.
[ 4913.543383] RTL871X: Drop duplicate management frame with seq_num = 1783.
[ 4913.878588] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 4914.870568] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 4914.903310] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 4916.318200] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 4916.355086] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000001
[ 4916.357838] RTL871X: survey done event(9) band:0 for wlan0
[ 4916.357864] RTL871X: rtw_indicate_scan_done(wlan0)
[ 4916.871834] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 4916.871849] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 4920.880071] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 4936.912261] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 4954.947954] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 4970.979950] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 4987.011952] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 5003.043958] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 5019.075953] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 5032.152809] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-LPS_CTRL_LEAVE
[ 5032.152822] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 5032.154458] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_SLEEP] macid=0, org reg_0x4d4=0x00000000
[ 5033.338653] RTL871X: Drop duplicate management frame with seq_num = 3084.
[ 5033.342523] RTL871X: Drop duplicate management frame with seq_num = 3084.
[ 5033.594862] RTL871X: Drop duplicate management frame with seq_num = 3089.
[ 5033.598656] RTL871X: Drop duplicate management frame with seq_num = 3089.
[ 5033.602763] RTL871X: Drop duplicate management frame with seq_num = 3089.
[ 5033.938576] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 5035.110455] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 5035.140813] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000001
[ 5035.145323] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 5036.326208] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 5036.361448] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 5036.364950] RTL871X: survey done event(7) band:0 for wlan0
[ 5036.365031] RTL871X: rtw_indicate_scan_done(wlan0)
[ 5037.111835] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 5037.111848] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 5049.135829] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 5049.135842] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 5053.143820] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 5053.143829] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 5055.147831] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 5055.147844] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 5057.151832] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 5057.151846] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 5071.180363] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 5087.211948] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 5103.244076] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 5129.295936] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 5152.157821] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-LPS_CTRL_LEAVE
[ 5152.157834] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 5152.159470] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_SLEEP] macid=0, org reg_0x4d4=0x00000000
[ 5153.922456] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 5155.350451] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 5155.383575] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 5156.314199] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 5156.349444] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000001
[ 5156.351813] RTL871X: survey done event(6) band:0 for wlan0
[ 5156.351828] RTL871X: rtw_indicate_scan_done(wlan0)
[ 5157.351996] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 5157.352011] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 5163.364105] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 5179.395950] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 5195.427936] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 5211.459938] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 5227.491940] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 5243.523942] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 5271.579951] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 5272.153635] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-LPS_CTRL_LEAVE
[ 5272.153648] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 5272.155331] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_SLEEP] macid=0, org reg_0x4d4=0x00000000
[ 5273.902457] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 5275.590584] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 5275.623463] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000001
[ 5275.630700] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 5276.282201] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 5276.315825] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 5276.318696] RTL871X: survey done event(6) band:0 for wlan0
[ 5276.318719] RTL871X: rtw_indicate_scan_done(wlan0)
[ 5277.591832] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 5277.591846] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 5291.619952] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 5307.651951] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 5323.683951] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 5339.715952] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 5359.756084] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 5375.787952] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 5391.819953] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 5392.157995] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-LPS_CTRL_LEAVE
[ 5392.158008] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 5392.159709] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_SLEEP] macid=0, org reg_0x4d4=0x00000000
[ 5393.149735] RTL871X: Drop duplicate management frame with seq_num = 3251.
[ 5393.153613] RTL871X: Drop duplicate management frame with seq_num = 3251.
[ 5393.886580] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 5395.830451] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 5395.861953] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000001
[ 5395.869200] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 5396.274200] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 5396.307703] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 5396.309821] RTL871X: survey done event(9) band:0 for wlan0
[ 5396.309842] RTL871X: rtw_indicate_scan_done(wlan0)
[ 5397.831832] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 5397.831845] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 5425.887950] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 5461.959950] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 5490.015951] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 5506.047955] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 5512.157093] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-LPS_CTRL_LEAVE
[ 5512.157107] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 5512.159209] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_SLEEP] macid=0, org reg_0x4d4=0x00000000
[ 5513.534383] RTL871X: Drop duplicate management frame with seq_num = 534.
[ 5513.878463] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 5514.066458] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 5514.100072] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 5516.070458] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 5516.105456] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000001
[ 5516.112820] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 5516.270199] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 5516.304325] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 5516.307702] RTL871X: survey done event(9) band:0 for wlan0
[ 5516.307725] RTL871X: rtw_indicate_scan_done(wlan0)
[ 5518.071832] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 5518.071845] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 5532.099949] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 5558.151952] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 5574.183950] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 5590.215951] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 5606.247951] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 5622.279950] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 5632.157372] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-LPS_CTRL_LEAVE
[ 5632.157386] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 5632.159082] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_SLEEP] macid=0, org reg_0x4d4=0x00000000
[ 5633.894458] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 5634.306471] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 5634.339076] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 5636.262200] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 5636.296328] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000001
[ 5636.298824] RTL871X: survey done event(8) band:0 for wlan0
[ 5636.298844] RTL871X: rtw_indicate_scan_done(wlan0)
[ 5636.307828] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 5636.307841] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 5638.311948] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 5656.347952] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 5672.379950] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 5688.411951] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 5704.443952] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 5720.475950] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 5736.507951] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 5752.157864] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-LPS_CTRL_LEAVE
[ 5752.157877] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 5752.159594] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_SLEEP] macid=0, org reg_0x4d4=0x00000000
[ 5753.281759] RTL871X: Drop duplicate management frame with seq_num = 3239.
[ 5753.285760] RTL871X: Drop duplicate management frame with seq_num = 3239.
[ 5753.882457] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 5754.546460] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 5754.580700] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 5756.246201] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 5756.280078] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000001
[ 5756.282578] RTL871X: survey done event(8) band:0 for wlan0
[ 5756.282599] RTL871X: rtw_indicate_scan_done(wlan0)
[ 5756.547832] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 5756.547845] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 5766.567951] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 5782.599949] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 5798.631940] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 5814.663951] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 5830.695955] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 5846.727958] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 5864.763942] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 5872.154807] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-LPS_CTRL_LEAVE
[ 5872.154820] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 5872.156571] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_SLEEP] macid=0, org reg_0x4d4=0x00000000
[ 5873.530744] RTL871X: Drop duplicate management frame with seq_num = 508.
[ 5873.534518] RTL871X: Drop duplicate management frame with seq_num = 508.
[ 5873.538498] RTL871X: Drop duplicate management frame with seq_num = 508.
[ 5873.874456] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 5874.786454] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 5874.823702] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 5876.266326] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 5876.300571] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000001
[ 5876.304200] RTL871X: survey done event(6) band:0 for wlan0
[ 5876.304219] RTL871X: rtw_indicate_scan_done(wlan0)
[ 5876.787816] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 5876.787826] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 5880.795939] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 5890.815816] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 5890.815825] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 5892.819959] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 5892.819969] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 5912.860794] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 5928.892641] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 5930.896207] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 5930.896217] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 5932.115699] RTL871X: rtw_issue_addbareq_cmd, p=0
[ 5932.115765] RTL871X: BA_starting_seqctrl = 809 for TID=0
[ 5932.115787] RTL871X: issue_addba_req(wlan0) ra=08:60:6e:be:f2:60 tid=0
[ 5932.144013] RTL871X: OnAction_back
[ 5932.144020] RTL871X: OnAction_back, action=1
[ 5932.144024] RTL871X: agg_enable for TID=0
[ 5938.912135] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 5938.912144] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 5940.916612] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 5940.916625] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 5944.924604] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 5944.924618] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 5960.958130] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 5976.989056] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 5992.157772] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-LPS_CTRL_LEAVE
[ 5992.157785] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 5992.161395] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_SLEEP] macid=0, org reg_0x4d4=0x00000000
[ 5993.056953] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000001
[ 5993.913204] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 5995.030955] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 5995.063704] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 5996.376453] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 5996.410701] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 5996.412701] RTL871X: survey done event(3) band:0 for wlan0
[ 5996.412721] RTL871X: rtw_indicate_scan_done(wlan0)
[ 5997.028938] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 5997.028952] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 6009.052930] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 6025.085558] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 6077.189576] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 6093.221722] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 6109.253253] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 6112.157853] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-LPS_CTRL_LEAVE
[ 6112.157866] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 6112.161673] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_SLEEP] macid=0, org reg_0x4d4=0x00000000
[ 6113.896953] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 6115.269453] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 6115.302073] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 6116.352078] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 6116.385825] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000001
[ 6116.388701] RTL871X: survey done event(3) band:0 for wlan0
[ 6116.388722] RTL871X: rtw_indicate_scan_done(wlan0)
[ 6117.268378] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 6117.268388] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 6125.285281] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 6141.317844] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 6157.348651] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 6173.381320] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 6189.413267] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 6205.445506] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 6221.477300] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 6232.152555] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-LPS_CTRL_LEAVE
[ 6232.152569] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 6232.154708] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_SLEEP] macid=0, org reg_0x4d4=0x00000000
[ 6233.882451] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 6235.508204] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 6235.540825] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 6236.336578] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 6236.371582] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000001
[ 6236.373948] RTL871X: survey done event(5) band:0 for wlan0
[ 6236.373970] RTL871X: rtw_indicate_scan_done(wlan0)
[ 6237.508140] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 6237.509683] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 6237.509695] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 6253.541237] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 6260.127877] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-LPS_CTRL_SPECIAL_PACKET
[ 6260.127886] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 6261.556794] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 6261.556808] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 6277.589144] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 6285.604654] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 6285.604668] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 6287.608473] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 6287.608488] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 6291.617984] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 6291.617998] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 6293.620387] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 6293.620398] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 6295.624043] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 6295.624056] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 6299.632265] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 6299.632274] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 6301.636075] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 6301.636088] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 6309.652629] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 6309.652643] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 6313.661908] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 6313.661922] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 6317.668953] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 6317.668967] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 6319.673372] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 6319.673386] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 6321.678117] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 6321.678131] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 6334.873699] RTL871X: recv eapol packet
[ 6334.874086] RTL871X: ~~~~set sta key:groupkey
[ 6334.874098] RTL871X: ==> rtw_set_key algorithm(4),keyid(2),key_mask(0)
[ 6334.874161] RTL871X: send eapol packet
[ 6334.875748] RTL871X: recv eapol packet
[ 6334.876051] RTL871X: send eapol packet
[ 6334.878078] RTL871X: set group key camid:6, addr:08:60:6e:be:f2:60, kid:2, type:AES
[ 6334.878445] RTL871X: SetHwReg8812A, 5703, RCR= f40760ce
[ 6352.157013] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-LPS_CTRL_LEAVE
[ 6352.157026] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 6352.160522] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_SLEEP] macid=0, org reg_0x4d4=0x00000000
[ 6353.283862] RTL871X: Drop duplicate management frame with seq_num = 1657.
[ 6353.287987] RTL871X: Drop duplicate management frame with seq_num = 1657.
[ 6353.292209] RTL871X: Drop duplicate management frame with seq_num = 1657.
[ 6353.937952] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 6355.761078] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 6355.792831] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000001
[ 6355.800074] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 6356.372953] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 6356.406449] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 6356.408952] RTL871X: survey done event(a) band:0 for wlan0
[ 6356.408972] RTL871X: rtw_indicate_scan_done(wlan0)
[ 6357.748946] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 6357.748960] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 6371.777381] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 6395.825424] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 6411.857276] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 6435.905402] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 6459.954468] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 6472.157475] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-LPS_CTRL_LEAVE
[ 6472.157489] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 6472.162430] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_SLEEP] macid=0, org reg_0x4d4=0x00000000
[ 6473.918828] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 6473.986328] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 6474.019702] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 6475.993828] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 6476.025581] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000001
[ 6476.032826] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 6476.348703] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 6476.382701] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 6476.384827] RTL871X: survey done event(9) band:0 for wlan0
[ 6476.384847] RTL871X: rtw_indicate_scan_done(wlan0)
[ 6477.989061] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 6477.989076] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 6492.017501] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 6508.049413] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 6540.113548] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 6556.145396] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 6572.177394] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 6588.209149] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 6592.158379] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-LPS_CTRL_LEAVE
[ 6592.158393] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 6592.163367] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_SLEEP] macid=0, org reg_0x4d4=0x00000000
[ 6593.909329] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 6594.225451] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 6594.258950] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 6596.240577] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 6596.273200] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 6596.339322] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 6596.374701] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000001
[ 6596.379457] RTL871X: survey done event(6) band:0 for wlan0
[ 6596.379480] RTL871X: rtw_indicate_scan_done(wlan0)
[ 6598.228906] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 6598.228920] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 6604.241392] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 6628.289196] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 6644.321247] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 6662.357383] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 6678.389216] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 6694.421436] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 6712.157705] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-LPS_CTRL_LEAVE
[ 6712.157719] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 6712.161646] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_SLEEP] macid=0, org reg_0x4d4=0x00000000
[ 6713.331505] RTL871X: Drop duplicate management frame with seq_num = 1719.
[ 6713.592860] RTL871X: Drop duplicate management frame with seq_num = 1724.
[ 6713.597300] RTL871X: Drop duplicate management frame with seq_num = 1724.
[ 6713.601297] RTL871X: Drop duplicate management frame with seq_num = 1724.
[ 6713.939075] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 6714.479323] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 6714.512200] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 6716.366451] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 6716.403703] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000001
[ 6716.405950] RTL871X: survey done event(a) band:0 for wlan0
[ 6716.406011] RTL871X: rtw_indicate_scan_done(wlan0)
[ 6716.464702] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 6716.464716] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 6736.505423] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 6752.537550] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 6768.569445] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 6784.601442] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 6800.633725] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 6816.665437] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 6832.158550] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-LPS_CTRL_LEAVE
[ 6832.158563] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 6832.163900] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_SLEEP] macid=0, org reg_0x4d4=0x00000000
[ 6833.186736] RTL871X: Drop duplicate management frame with seq_num = 3260.
[ 6833.191082] RTL871X: Drop duplicate management frame with seq_num = 3260.
[ 6833.578360] RTL871X: Drop duplicate management frame with seq_num = 3267.
[ 6833.582483] RTL871X: Drop duplicate management frame with seq_num = 3267.
[ 6833.932331] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 6834.704955] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 6834.738326] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 6836.432702] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 6836.466204] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000001
[ 6836.468577] RTL871X: survey done event(9) band:0 for wlan0
[ 6836.468597] RTL871X: rtw_indicate_scan_done(wlan0)
[ 6836.704789] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 6836.704803] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 6846.725433] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 6862.757784] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 6878.789468] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 6894.821457] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 6910.853325] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 6926.885153] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 6952.156366] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-LPS_CTRL_LEAVE
[ 6952.156375] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 6952.162580] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_SLEEP] macid=0, org reg_0x4d4=0x00000000
[ 6953.561485] RTL871X: Drop duplicate management frame with seq_num = 579.
[ 6953.920956] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 6954.946455] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 6954.979832] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150
[ 6956.446954] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
[ 6956.480586] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000001
[ 6956.482956] RTL871X: survey done event(b) band:0 for wlan0
[ 6956.482978] RTL871X: rtw_indicate_scan_done(wlan0)
[ 6956.944441] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 6956.944451] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 6962.956671] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 6972.975837] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 6972.975850] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 6976.984267] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 6976.984281] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 6978.989010] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY
[ 6978.989024] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0
[ 6980.992766] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE
[ 6980.992780] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0
[ 6995.021602] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 7011.053471] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 7027.085523] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
[ 7043.117396] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
Br Victor
8 years 1 day ago #119658
Replied by andypugh on topic G76, Troubleshooting needed!
That's wierd
(don't worry about the \ characters)
I don't know what the problem is there. Before editing again, try a restart.
Unknown parameter `num_encoders=1'
waitpid failed /usr/bin/rtapi_app hm2_eth
/usr/bin/rtapi_app exited without becoming ready
insmod for hm2_eth failed, returned -1
while executing
"hal loadrt hm2_eth board_ip=\"10.10.10.10\" config=\"firmware=hm2/7i76/7i76e.BIT num_encoders=1 num_pwmgens=0 num_stepgens=2 sserial_port_0=00xxxx\""
The following user(s) said Thank You: Victor
Time to create page: 0.163 seconds
