G76, Troubleshooting needed!
7 years 11 months ago - 7 years 11 months ago #120255 by Victor
Replied by Victor on topic G76, Troubleshooting needed!
Hi Andy.
Today the encoder is mounted below the spindle shaft with a timing belt 1:1 to the spindle shaft.
no mater what encoder i get i think i have to make a bearing housing for the timing pulley shaft and attach the encoder to that shaft.
i'm more worried if the encoder it'self is a good choice and what ppr i should get.
Edit: found a couple images of the stock encoder online, added them to attached files
Br Victor
Last edit: 7 years 11 months ago by Victor.
7 years 11 months ago #120257 by andypugh
Replied by andypugh on topic G76, Troubleshooting needed!
No eBay APP ID and/or Cert ID defined in Kunena configurationIf you get an encoder with a shaft and its own bearings then there is no need for anything more. For any sensible amount of encoder belt tension the load on the encoder bearings will be tiny.
This:
Appears to be one of these:
docs-emea.rs-online.com/webdocs/1398/0900766b813988fd.pdf
So it is an ABZ encoder (quadrature + index) with differential output (Which I think it optimal for the 7i76)
The following user(s) said Thank You: Victor
7 years 11 months ago #120258 by Victor
Agreed that would be the easiest way but i think the pulley is like 100-120mm in steel or alu and the belt is 12-15mm wide, and if i look at the encoders in the price range i'm looking in (max 100$) i'm a bit scared to let them handle that pulley.
I have looked at those Omron nock-offs do you know if they are any good?
Br Victor
7 years 11 months ago #120260 by andypugh
Victor wrote: Agreed that would be the easiest way but i think the pulley is like 100-120mm in steel or alu and the belt is 12-15mm wide, and if i look at the encoders in the price range i'm looking in (max 100$) i'm a bit scared to let them handle that pulley.[/code]
Look at the specs of 6mm bore ball bearings:
simplybearings.co.uk/shop/p2624/Major-Br...mm/product_info.html
They are rated for 500N (50kg) and 52,000 rpm. There really isn't any cause for concern.
I have some, but didn't use them as I accidentally got no-index versions. So I can't really comment.
The encoder you have looks like it should be OK, though. Is it possible to move the sensor relative to the wheel? A radial movement would alter the slot-pitch as seen by the sensor and might reduce quadrature error.
Are those reflective or transmissive sensors?
It might also be interesting to change the Z axis acceleration limits.
7 years 11 months ago #120261 by Victor
Hi, Well i don't really know if i can adjust it or not, i have not opened the encoder myself.
I figured since the encoder is almost 30 years old and i only have A & Index pulse i might as well change it, rigid tapping would be useful.
Are there any numbers in the specifications on the one i suggested (HEDSS - IHU4808) that i should be concerned about?
And what would be a good ppr count?
Br Victor
7 years 11 months ago #120263 by andypugh
The optimum encoder count depends on the spindle speed and the Mesa card counting rate.
Are you sure that the encoder only has A + Z? The photo shows enough pins for 0V, 5V A B Z. And the sensors look like they could be dual-channel ones.
There is an adjustment pot on the encoder board, does that improve the mark/space ratio?
Time to create page: 0.146 seconds
