G76, Troubleshooting needed!
8 years 1 day ago #119659 by Victor
Replied by Victor on topic G76, Troubleshooting needed!
Ok did a restart but still same issue.
If i put # before TWOPASS=ON it starts right up, if i remove it i get the error message as above.
[HAL] HALUI = halui HALFILE = Emco-120P.hal HALFILE = custom.hal POSTGUI_HALFILE = postgui_call_list.hal SHUTDOWN = shutdown.hal #TWOPASS=ON
Br Victor
8 years 1 day ago #119660 by andypugh
Replied by andypugh on topic G76, Troubleshooting needed!
Does it start up and actually work with that commented out?
The following user(s) said Thank You: Victor
8 years 1 day ago #119661 by Victor
Yup, starts right up with # before TWOPASS=ON
Have runned it like that for some time now.. i have removed the code you gave me in custom.hal so the only diffrence is the twopass line.
Br Victor
8 years 1 day ago #119662 by andypugh
Oh. I thought you were saying that it was all working, which would have been a surprise.
So, put the loadrt for both lowpasses in the main HAL, and the rest in the custom.hal. What happens then?
8 years 1 day ago #119663 by Victor
No when i put the TWOPASS=ON it stops working.
This is what i now have in my main .HAL file:
# Generated by PNCconf at Wed Jul 5 19:54:29 2017 # If you make changes to this file, they will be # overwritten when you run PNCconf again loadrt trivkins loadrt [EMCMOT]EMCMOT servo_period_nsec=[EMCMOT]SERVO_PERIOD num_joints=[TRAJ]AXES loadrt hostmot2 loadrt hm2_eth board_ip="10.10.10.10" config="firmware=hm2/7i76/7i76e.BIT num_encoders=1 num_pwmgens=0 num_stepgens=2 sserial_port_0=00xxxx" setp hm2_7i76e.0.watchdog.timeout_ns 5000000 loadrt pid names=pid.x,pid.z,pid.s loadrt abs names=abs.spindle loadrt lowpass names=lowpass.spindle loadrt lowpass names=lowpass.0 loadrt scale names=scale.spindle addf hm2_7i76e.0.read servo-thread addf motion-command-handler servo-thread addf motion-controller servo-thread addf pid.x.do-pid-calcs servo-thread addf pid.z.do-pid-calcs servo-thread addf pid.s.do-pid-calcs servo-thread addf scale.spindle servo-thread addf abs.spindle servo-thread addf lowpass.spindle servo-thread addf hm2_7i76e.0.write servo-thread setp hm2_7i76e.0.dpll.01.timer-us -50 setp hm2_7i76e.0.stepgen.timer-number 1 # external output signals # --- COOLANT-FLOOD --- net coolant-flood hm2_7i76e.0.7i76.0.0.output-00 # external input signals # --- ESTOP-EXT --- net estop-ext <= hm2_7i76e.0.7i76.0.0.input-04 # --- HOME-X --- net home-x <= hm2_7i76e.0.7i76.0.0.input-06-not # --- HOME-Z --- net home-z <= hm2_7i76e.0.7i76.0.0.input-07-not #******************* # AXIS X #******************* setp pid.x.Pgain [AXIS_0]P setp pid.x.Igain [AXIS_0]I setp pid.x.Dgain [AXIS_0]D setp pid.x.bias [AXIS_0]BIAS setp pid.x.FF0 [AXIS_0]FF0 setp pid.x.FF1 [AXIS_0]FF1 setp pid.x.FF2 [AXIS_0]FF2 setp pid.x.deadband [AXIS_0]DEADBAND setp pid.x.maxoutput [AXIS_0]MAX_OUTPUT setp pid.x.error-previous-target true setp pid.x.maxerror .0005 net x-index-enable <=> pid.x.index-enable net x-enable => pid.x.enable net x-pos-cmd => pid.x.command net x-vel-cmd => pid.x.command-deriv net x-pos-fb => pid.x.feedback net x-output => pid.x.output # Step Gen signals/setup setp hm2_7i76e.0.stepgen.00.dirsetup [AXIS_0]DIRSETUP setp hm2_7i76e.0.stepgen.00.dirhold [AXIS_0]DIRHOLD setp hm2_7i76e.0.stepgen.00.steplen [AXIS_0]STEPLEN setp hm2_7i76e.0.stepgen.00.stepspace [AXIS_0]STEPSPACE setp hm2_7i76e.0.stepgen.00.position-scale [AXIS_0]STEP_SCALE setp hm2_7i76e.0.stepgen.00.step_type 0 setp hm2_7i76e.0.stepgen.00.control-type 1 setp hm2_7i76e.0.stepgen.00.maxaccel [AXIS_0]STEPGEN_MAXACCEL setp hm2_7i76e.0.stepgen.00.maxvel [AXIS_0]STEPGEN_MAXVEL setp hm2_7i76e.0.gpio.000.invert_output true # ---closedloop stepper signals--- net x-pos-cmd <= axis.0.motor-pos-cmd net x-vel-cmd <= axis.0.joint-vel-cmd net x-output <= hm2_7i76e.0.stepgen.00.velocity-cmd net x-pos-fb <= hm2_7i76e.0.stepgen.00.position-fb net x-pos-fb => axis.0.motor-pos-fb net x-enable <= axis.0.amp-enable-out net x-enable => hm2_7i76e.0.stepgen.00.enable # ---setup home / limit switch signals--- net home-x => axis.0.home-sw-in net x-neg-limit => axis.0.neg-lim-sw-in net x-pos-limit => axis.0.pos-lim-sw-in #******************* # AXIS Z #******************* setp pid.z.Pgain [AXIS_2]P setp pid.z.Igain [AXIS_2]I setp pid.z.Dgain [AXIS_2]D setp pid.z.bias [AXIS_2]BIAS setp pid.z.FF0 [AXIS_2]FF0 setp pid.z.FF1 [AXIS_2]FF1 setp pid.z.FF2 [AXIS_2]FF2 setp pid.z.deadband [AXIS_2]DEADBAND setp pid.z.maxoutput [AXIS_2]MAX_OUTPUT setp pid.z.error-previous-target true setp pid.z.maxerror .0005 net z-index-enable <=> pid.z.index-enable net z-enable => pid.z.enable net z-pos-cmd => pid.z.command net z-vel-cmd => pid.z.command-deriv net z-pos-fb => pid.z.feedback net z-output => pid.z.output # Step Gen signals/setup setp hm2_7i76e.0.stepgen.01.dirsetup [AXIS_2]DIRSETUP setp hm2_7i76e.0.stepgen.01.dirhold [AXIS_2]DIRHOLD setp hm2_7i76e.0.stepgen.01.steplen [AXIS_2]STEPLEN setp hm2_7i76e.0.stepgen.01.stepspace [AXIS_2]STEPSPACE setp hm2_7i76e.0.stepgen.01.position-scale [AXIS_2]STEP_SCALE setp hm2_7i76e.0.stepgen.01.step_type 0 setp hm2_7i76e.0.stepgen.01.control-type 1 setp hm2_7i76e.0.stepgen.01.maxaccel [AXIS_2]STEPGEN_MAXACCEL setp hm2_7i76e.0.stepgen.01.maxvel [AXIS_2]STEPGEN_MAXVEL # ---closedloop stepper signals--- net z-pos-cmd <= axis.2.motor-pos-cmd net z-vel-cmd <= axis.2.joint-vel-cmd net z-output <= hm2_7i76e.0.stepgen.01.velocity-cmd net z-pos-fb <= hm2_7i76e.0.stepgen.01.position-fb net z-pos-fb => axis.2.motor-pos-fb net z-enable <= axis.2.amp-enable-out net z-enable => hm2_7i76e.0.stepgen.01.enable # ---setup home / limit switch signals--- net home-z => axis.2.home-sw-in net z-neg-limit => axis.2.neg-lim-sw-in net z-pos-limit => axis.2.pos-lim-sw-in #******************* # SPINDLE S #******************* setp pid.s.Pgain [SPINDLE_9]P setp pid.s.Igain [SPINDLE_9]I setp pid.s.Dgain [SPINDLE_9]D setp pid.s.bias [SPINDLE_9]BIAS setp pid.s.FF0 [SPINDLE_9]FF0 setp pid.s.FF1 [SPINDLE_9]FF1 setp pid.s.FF2 [SPINDLE_9]FF2 setp pid.s.deadband [SPINDLE_9]DEADBAND setp pid.s.maxoutput [SPINDLE_9]MAX_OUTPUT setp pid.s.error-previous-target true net spindle-index-enable <=> pid.s.index-enable net spindle-enable => pid.s.enable net spindle-vel-cmd-rpm-abs => pid.s.command net spindle-vel-fb-rpm-abs => pid.s.feedback net spindle-output <= pid.s.output # ---digital potentionmeter output signals/setup--- setp hm2_7i76e.0.7i76.0.0.spinout-minlim [SPINDLE_9]OUTPUT_MIN_LIMIT setp hm2_7i76e.0.7i76.0.0.spinout-maxlim [SPINDLE_9]OUTPUT_MAX_LIMIT setp hm2_7i76e.0.7i76.0.0.spinout-scalemax [SPINDLE_9]OUTPUT_SCALE net spindle-vel-cmd-rpm-abs => hm2_7i76e.0.7i76.0.0.spinout net spindle-enable => hm2_7i76e.0.7i76.0.0.spinena net spindle-ccw => hm2_7i76e.0.7i76.0.0.spindir # ---Encoder feedback signals/setup--- setp hm2_7i76e.0.encoder.00.counter-mode 1 setp hm2_7i76e.0.encoder.00.filter 1 setp hm2_7i76e.0.encoder.00.index-invert 0 setp hm2_7i76e.0.encoder.00.index-mask 0 setp hm2_7i76e.0.encoder.00.index-mask-invert 0 setp hm2_7i76e.0.encoder.00.scale [SPINDLE_9]ENCODER_SCALE net spindle-revs <= hm2_7i76e.0.encoder.00.position net spindle-vel-fb-rps <= hm2_7i76e.0.encoder.00.velocity net spindle-index-enable <=> hm2_7i76e.0.encoder.00.index-enable # ---setup spindle control signals--- net spindle-vel-cmd-rps <= motion.spindle-speed-out-rps net spindle-vel-cmd-rps-abs <= motion.spindle-speed-out-rps-abs net spindle-vel-cmd-rpm <= motion.spindle-speed-out net spindle-vel-cmd-rpm-abs <= motion.spindle-speed-out-abs net spindle-enable <= motion.spindle-on net spindle-cw <= motion.spindle-forward net spindle-ccw <= motion.spindle-reverse net spindle-brake <= motion.spindle-brake net spindle-revs => motion.spindle-revs net spindle-at-speed => motion.spindle-at-speed net spindle-vel-fb-rps => motion.spindle-speed-in net spindle-index-enable <=> motion.spindle-index-enable # ---Setup spindle at speed signals--- sets spindle-at-speed true # Use ACTUAL spindle velocity from spindle encoder # spindle-velocity bounces around so we filter it with lowpass # spindle-velocity is signed so we use absolute component to remove sign # ACTUAL velocity is in RPS not RPM so we scale it. setp scale.spindle.gain 60 setp lowpass.spindle.gain 1.000000 net spindle-vel-fb-rps => scale.spindle.in net spindle-fb-rpm scale.spindle.out => abs.spindle.in net spindle-fb-rpm-abs abs.spindle.out => lowpass.spindle.in net spindle-fb-rpm-abs-filtered lowpass.spindle.out #****************************** # connect miscellaneous signals #****************************** # ---HALUI signals--- net joint-select-a halui.joint.0.select net x-is-homed halui.joint.0.is-homed net jog-x-pos halui.jog.0.plus net jog-x-neg halui.jog.0.minus net jog-x-analog halui.jog.0.analog net joint-select-c halui.joint.2.select net z-is-homed halui.joint.2.is-homed net jog-z-pos halui.jog.2.plus net jog-z-neg halui.jog.2.minus net jog-z-analog halui.jog.2.analog net jog-selected-pos halui.jog.selected.plus net jog-selected-neg halui.jog.selected.minus net spindle-manual-cw halui.spindle.forward net spindle-manual-ccw halui.spindle.reverse net spindle-manual-stop halui.spindle.stop net machine-is-on halui.machine.is-on net jog-speed halui.jog-speed net MDI-mode halui.mode.is-mdi # ---coolant signals--- net coolant-mist <= iocontrol.0.coolant-mist net coolant-flood <= iocontrol.0.coolant-flood # ---probe signal--- net probe-in => motion.probe-input # ---motion control signals--- net in-position <= motion.in-position net machine-is-enabled <= motion.motion-enabled # ---digital in / out signals--- # ---estop signals--- net estop-out <= iocontrol.0.user-enable-out net estop-ext => iocontrol.0.emc-enable-in # ---manual tool change signals---
This is what i have in my custom.hal file:
# Include your custom HAL commands here # This file will not be overwritten when you run PNCconf again loadusr -W toolerator3000 net tool-change iocontrol.0.tool-change => toolerator3000.toolchange net tool-changed iocontrol.0.tool-changed <= toolerator3000.toolchanged net tool-number iocontrol.0.tool-prep-number => toolerator3000.toolnumber net tool-prepare-loopback iocontrol.0.tool-prepare => iocontrol.0.tool-prepared #loadrt scale count=1 #addf scale.0 servo-thread #setp scale.0.gain 0.002 #net spindle-speed-scale motion.spindle-speed-out => scale.0.in #net spindle-speed-DAC scale.0.out => <hm2_7i76e.0.7i76.0.0.spinout> # Disconnect motion.spindle-revs from the signal in the main HAL file unlinkp motion.spindle-revs #loadrt lowpass names=lowpass.0 addf lowpass.0 servo-thread setp lowpass.0.gain 0.05 # This signal needs to be the one from your main HAL file. # This is a guess... net spindle-revs lowpass.0.in net spindle-revs-filt lopass.0.out => motion.spindle-revs
This is what i have in my .ini file:
[HAL] HALUI = halui HALFILE = Emco-120P.hal HALFILE = custom.hal POSTGUI_HALFILE = postgui_call_list.hal SHUTDOWN = shutdown.hal TWOPASS=ON [HALUI]
This is the error message i get:
Print file information: RUN_IN_PLACE=no LINUXCNC_DIR= LINUXCNC_BIN_DIR=/usr/bin LINUXCNC_TCL_DIR=/usr/lib/tcltk/linuxcnc LINUXCNC_SCRIPT_DIR= LINUXCNC_RTLIB_DIR=/usr/lib/linuxcnc/modules LINUXCNC_CONFIG_DIR= LINUXCNC_LANG_DIR=/usr/share/linuxcnc/tcl/msgs INIVAR=inivar HALCMD=halcmd LINUXCNC_EMCSH=/usr/bin/wish8.5 LINUXCNC - 2.7.8 Machine configuration directory is '/home/victor/linuxcnc/configs/Emco-120P' Machine configuration file is 'Emco-120P.ini' INIFILE=/home/victor/linuxcnc/configs/Emco-120P/Emco-120P.ini PARAMETER_FILE=linuxcnc.var TASK=milltask HALUI=halui DISPLAY=axis Starting LinuxCNC... Starting LinuxCNC server program: linuxcncsvr Loading Real Time OS, RTAPI, and HAL_LIB modules Starting LinuxCNC IO program: io Starting HAL User Interface program: halui twopass:invoked with <> options twopass:found ./Emco-120P.hal twopass:found ./custom.hal hm2: loading Mesa HostMot2 driver version 0.15 Shutting down and cleaning up LinuxCNC... Running HAL shutdown script Killing task linuxcncsvr, PID=4107 hm2: unloading Removing HAL_LIB, RTAPI, and Real Time OS modules Removing NML shared memory segments Debug file information: Note: Using POSIX realtime Unknown parameter `num_encoders=1' waitpid failed /usr/bin/rtapi_app hm2_eth /usr/bin/rtapi_app exited without becoming ready insmod for hm2_eth failed, returned -1 while executing "hal loadrt hm2_eth board_ip=\"10.10.10.10\" config=\"firmware=hm2/7i76/7i76e.BIT num_encoders=1 num_pwmgens=0 num_stepgens=2 sserial_port_0=00xxxx\"" ("eval" body line 1) invoked from within "eval hal loadrt $args" (procedure "orig_loadrt" line 1) invoked from within "orig_loadrt hm2_eth board_ip=\"10.10.10.10\" config=\"firmware=hm2/7i76/7i76e.BIT num_encoders=1 num_pwmgens=0 num_stepgens=2 sserial_port_0=00xxxx\"" ("eval" body line 1) invoked from within "eval $cmd" (procedure "load_the_modules" line 22) invoked from within "load_the_modules" (procedure "::tp::pass0" line 11) invoked from within "::tp::pass0" (file "/usr/lib/tcltk/linuxcnc/twopass.tcl" line 556) invoked from within "source $filename" invoked from within "set result [source $filename]" (file "/usr/bin/haltcl" line 55) 4107 PID TTY STAT TIME COMMAND Stopping realtime threads Unloading hal components Note: Using POSIX realtime Kernel message information: [ 0.000000] Initializing cgroup subsys cpuset [ 0.000000] Initializing cgroup subsys cpu [ 0.000000] Linux version 3.2.0-4-rt-amd64 (debian-kernel@lists.debian.org) (gcc version 4.6.3 (Debian 4.6.3-14) ) #1 SMP PREEMPT RT Debian 3.2.96-2 [ 0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-3.2.0-4-rt-amd64 root=UUID=91c3399b-61f5-4d16-8a0d-e4b87d432e14 ro quiet [ 0.000000] BIOS-provided physical RAM map: [ 0.000000] BIOS-e820: 0000000000000000 - 000000000009c800 (usable) [ 0.000000] BIOS-e820: 000000000009c800 - 00000000000a0000 (reserved) [ 0.000000] BIOS-e820: 00000000000e0000 - 0000000000100000 (reserved) [ 0.000000] BIOS-e820: 0000000000100000 - 0000000020000000 (usable) [ 0.000000] BIOS-e820: 0000000020000000 - 0000000020100000 (reserved) [ 0.000000] BIOS-e820: 0000000020100000 - 00000000ad584000 (usable) [ 0.000000] BIOS-e820: 00000000ad584000 - 00000000ad5b4000 (reserved) [ 0.000000] BIOS-e820: 00000000ad5b4000 - 00000000ad608000 (usable) [ 0.000000] BIOS-e820: 00000000ad608000 - 00000000ad719000 (ACPI NVS) [ 0.000000] BIOS-e820: 00000000ad719000 - 00000000ada7d000 (reserved) [ 0.000000] BIOS-e820: 00000000ada7d000 - 00000000ada7e000 (usable) [ 0.000000] BIOS-e820: 00000000ada7e000 - 00000000adac0000 (reserved) [ 0.000000] BIOS-e820: 00000000adac0000 - 00000000adc2e000 (usable) [ 0.000000] BIOS-e820: 00000000adc2e000 - 00000000adffa000 (reserved) [ 0.000000] BIOS-e820: 00000000adffa000 - 00000000ae000000 (usable) [ 0.000000] BIOS-e820: 00000000e00f8000 - 00000000e00f9000 (reserved) [ 0.000000] BIOS-e820: 00000000fed01000 - 00000000fed02000 (reserved) [ 0.000000] BIOS-e820: 00000000ffb00000 - 0000000100000000 (reserved) [ 0.000000] BIOS-e820: 0000000100000000 - 0000000140000000 (usable) [ 0.000000] NX (Execute Disable) protection: active [ 0.000000] SMBIOS 2.8 present. [ 0.000000] DMI: To Be Filled By O.E.M. To Be Filled By O.E.M./Q1900B-ITX, BIOS P1.80 12/10/2015 [ 0.000000] e820 update range: 0000000000000000 - 0000000000010000 (usable) ==> (reserved) [ 0.000000] e820 remove range: 00000000000a0000 - 0000000000100000 (usable) [ 0.000000] No AGP bridge found [ 0.000000] last_pfn = 0x140000 max_arch_pfn = 0x400000000 [ 0.000000] MTRR default type: uncachable [ 0.000000] MTRR fixed ranges enabled: [ 0.000000] 00000-9FFFF write-back [ 0.000000] A0000-BFFFF uncachable [ 0.000000] C0000-E7FFF write-through [ 0.000000] E8000-FFFFF write-protect [ 0.000000] MTRR variable ranges enabled: [ 0.000000] 0 base 000000000 mask F80000000 write-back [ 0.000000] 1 base 080000000 mask FE0000000 write-back [ 0.000000] 2 base 0A0000000 mask FF0000000 write-back [ 0.000000] 3 base 0AE800000 mask FFF800000 uncachable [ 0.000000] 4 base 0AF000000 mask FFF000000 uncachable [ 0.000000] 5 base 100000000 mask FC0000000 write-back [ 0.000000] 6 disabled [ 0.000000] 7 disabled [ 0.000000] x86 PAT enabled: cpu 0, old 0x7040600070406, new 0x7010600070106 [ 0.000000] e820 update range: 00000000ae800000 - 0000000100000000 (usable) ==> (reserved) [ 0.000000] last_pfn = 0xae000 max_arch_pfn = 0x400000000 [ 0.000000] found SMP MP-table at [ffff8800000fd6b0] fd6b0 [ 0.000000] initial memory mapped : 0 - 20000000 [ 0.000000] Base memory trampoline at [ffff880000097000] 97000 size 20480 [ 0.000000] init_memory_mapping: 0000000000000000-00000000ae000000 [ 0.000000] 0000000000 - 00ae000000 page 2M [ 0.000000] kernel direct mapping tables up to ae000000 @ 1fffc000-20000000 [ 0.000000] init_memory_mapping: 0000000100000000-0000000140000000 [ 0.000000] 0100000000 - 0140000000 page 2M [ 0.000000] kernel direct mapping tables up to 140000000 @ adffe000-ae000000 [ 0.000000] RAMDISK: 36b9c000 - 375c6000 [ 0.000000] ACPI: RSDP 0x00000000000F04A0 00024 (v02 ALASKA) [ 0.000000] ACPI: XSDT 0x00000000AD68E080 0007C (v01 ALASKA A M I 01072009 AMI 00010013) [ 0.000000] ACPI: FACP 0x00000000AD6993C0 0010C (v05 ALASKA A M I 01072009 AMI 00010013) [ 0.000000] ACPI Warning: FADT (revision 5) is longer than ACPI 2.0 version, truncating length 268 to 244 (20110623/tbfadt-288) [ 0.000000] ACPI: DSDT 0x00000000AD68E190 0B229 (v02 ALASKA A M I 01072009 INTL 20120913) [ 0.000000] ACPI: FACS 0x00000000AD718F80 00040 [ 0.000000] ACPI: APIC 0x00000000AD6994D0 00084 (v03 ALASKA A M I 01072009 AMI 00010013) [ 0.000000] ACPI: FPDT 0x00000000AD699558 00044 (v01 ALASKA A M I 01072009 AMI 00010013) [ 0.000000] ACPI: MCFG 0x00000000AD6995A0 0003C (v01 ALASKA A M I 01072009 MSFT 00000097) [ 0.000000] ACPI: LPIT 0x00000000AD6995E0 00104 (v01 ALASKA A M I 00000003 VLV2 0100000D) [ 0.000000] ACPI: AAFT 0x00000000AD6996E8 000D7 (v01 ALASKA OEMAAFT 01072009 MSFT 00000097) [ 0.000000] ACPI: HPET 0x00000000AD6997C0 00038 (v01 ALASKA A M I 01072009 AMI. 00000005) [ 0.000000] ACPI: SSDT 0x00000000AD6997F8 00763 (v01 PmRef CpuPm 00003000 INTL 20061109) [ 0.000000] ACPI: SSDT 0x00000000AD699F60 00290 (v01 PmRef Cpu0Tst 00003000 INTL 20061109) [ 0.000000] ACPI: SSDT 0x00000000AD69A1F0 0017A (v01 PmRef ApTst 00003000 INTL 20061109) [ 0.000000] ACPI: UEFI 0x00000000AD69A370 00042 (v01 ALASKA A M I 00000000 00000000) [ 0.000000] ACPI: Local APIC address 0xfee00000 [ 0.000000] No NUMA configuration found [ 0.000000] Faking a node at 0000000000000000-0000000140000000 [ 0.000000] Initmem setup node 0 0000000000000000-0000000140000000 [ 0.000000] NODE_DATA [000000013fffb000 - 000000013fffffff] [ 0.000000] [ffffea0000000000-ffffea00045fffff] PMD -> [ffff88013ba00000-ffff88013effffff] on node 0 [ 0.000000] Zone PFN ranges: [ 0.000000] DMA 0x00000010 -> 0x00001000 [ 0.000000] DMA32 0x00001000 -> 0x00100000 [ 0.000000] Normal 0x00100000 -> 0x00140000 [ 0.000000] Movable zone start PFN for each node [ 0.000000] early_node_map[8] active PFN ranges [ 0.000000] 0: 0x00000010 -> 0x0000009c [ 0.000000] 0: 0x00000100 -> 0x00020000 [ 0.000000] 0: 0x00020100 -> 0x000ad584 [ 0.000000] 0: 0x000ad5b4 -> 0x000ad608 [ 0.000000] 0: 0x000ada7d -> 0x000ada7e [ 0.000000] 0: 0x000adac0 -> 0x000adc2e [ 0.000000] 0: 0x000adffa -> 0x000ae000 [ 0.000000] 0: 0x00100000 -> 0x00140000 [ 0.000000] On node 0 totalpages: 972249 [ 0.000000] DMA zone: 56 pages used for memmap [ 0.000000] DMA zone: 5 pages reserved [ 0.000000] DMA zone: 3919 pages, LIFO batch:0 [ 0.000000] DMA32 zone: 14280 pages used for memmap [ 0.000000] DMA32 zone: 691845 pages, LIFO batch:31 [ 0.000000] Normal zone: 3584 pages used for memmap [ 0.000000] Normal zone: 258560 pages, LIFO batch:31 [ 0.000000] ACPI: PM-Timer IO Port: 0x408 [ 0.000000] ACPI: Local APIC address 0xfee00000 [ 0.000000] ACPI: LAPIC (acpi_id[0x01] lapic_id[0x00] enabled) [ 0.000000] ACPI: LAPIC (acpi_id[0x02] lapic_id[0x02] enabled) [ 0.000000] ACPI: LAPIC (acpi_id[0x03] lapic_id[0x04] enabled) [ 0.000000] ACPI: LAPIC (acpi_id[0x04] lapic_id[0x06] enabled) [ 0.000000] ACPI: LAPIC_NMI (acpi_id[0x01] high dfl lint[0x7d]) [ 0.000000] ACPI: NMI not connected to LINT 1! [ 0.000000] ACPI: LAPIC_NMI (acpi_id[0x02] res edge lint[0xbe]) [ 0.000000] ACPI: NMI not connected to LINT 1! [ 0.000000] ACPI: LAPIC_NMI (acpi_id[0x03] dfl dfl lint[0x77]) [ 0.000000] ACPI: NMI not connected to LINT 1! [ 0.000000] ACPI: LAPIC_NMI (acpi_id[0x04] low level lint[0x15]) [ 0.000000] ACPI: NMI not connected to LINT 1! [ 0.000000] ACPI: IOAPIC (id[0x01] address[0xfec00000] gsi_base[0]) [ 0.000000] IOAPIC[0]: apic_id 1, version 32, address 0xfec00000, GSI 0-86 [ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl) [ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level) [ 0.000000] ACPI: IRQ0 used by override. [ 0.000000] ACPI: IRQ2 used by override. [ 0.000000] ACPI: IRQ9 used by override. [ 0.000000] Using ACPI (MADT) for SMP configuration information [ 0.000000] ACPI: HPET id: 0x8086a201 base: 0xfed00000 [ 0.000000] SMP: Allowing 4 CPUs, 0 hotplug CPUs [ 0.000000] nr_irqs_gsi: 103 [ 0.000000] PM: Registered nosave memory: 000000000009c000 - 000000000009d000 [ 0.000000] PM: Registered nosave memory: 000000000009d000 - 00000000000a0000 [ 0.000000] PM: Registered nosave memory: 00000000000a0000 - 00000000000e0000 [ 0.000000] PM: Registered nosave memory: 00000000000e0000 - 0000000000100000 [ 0.000000] PM: Registered nosave memory: 0000000020000000 - 0000000020100000 [ 0.000000] PM: Registered nosave memory: 00000000ad584000 - 00000000ad5b4000 [ 0.000000] PM: Registered nosave memory: 00000000ad608000 - 00000000ad719000 [ 0.000000] PM: Registered nosave memory: 00000000ad719000 - 00000000ada7d000 [ 0.000000] PM: Registered nosave memory: 00000000ada7e000 - 00000000adac0000 [ 0.000000] PM: Registered nosave memory: 00000000adc2e000 - 00000000adffa000 [ 0.000000] PM: Registered nosave memory: 00000000ae000000 - 00000000e00f8000 [ 0.000000] PM: Registered nosave memory: 00000000e00f8000 - 00000000e00f9000 [ 0.000000] PM: Registered nosave memory: 00000000e00f9000 - 00000000fed01000 [ 0.000000] PM: Registered nosave memory: 00000000fed01000 - 00000000fed02000 [ 0.000000] PM: Registered nosave memory: 00000000fed02000 - 00000000ffb00000 [ 0.000000] PM: Registered nosave memory: 00000000ffb00000 - 0000000100000000 [ 0.000000] Allocating PCI resources starting at ae000000 (gap: ae000000:320f8000) [ 0.000000] Booting paravirtualized kernel on bare hardware [ 0.000000] setup_percpu: NR_CPUS:512 nr_cpumask_bits:512 nr_cpu_ids:4 nr_node_ids:1 [ 0.000000] PERCPU: Embedded 107 pages/cpu @ffff88013fc00000 s409408 r8192 d20672 u524288 [ 0.000000] pcpu-alloc: s409408 r8192 d20672 u524288 alloc=1*2097152 [ 0.000000] pcpu-alloc: [0] 0 1 2 3 [ 0.000000] Built 1 zonelists in Node order, mobility grouping on. Total pages: 954324 [ 0.000000] Policy zone: Normal [ 0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-3.2.0-4-rt-amd64 root=UUID=91c3399b-61f5-4d16-8a0d-e4b87d432e14 ro quiet [ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes) [ 0.000000] Checking aperture... [ 0.000000] No AGP bridge found [ 0.000000] Calgary: detecting Calgary via BIOS EBDA area [ 0.000000] Calgary: Unable to locate Rio Grande table in EBDA - bailing! [ 0.000000] Memory: 3746092k/5242880k available (3535k kernel code, 1353884k absent, 142904k reserved, 3237k data, 916k init) [ 0.000000] Preemptible hierarchical RCU implementation. [ 0.000000] NR_IRQS:33024 nr_irqs:1024 16 [ 0.000000] Extended CMOS year: 2000 [ 0.000000] spurious 8259A interrupt: IRQ7. [ 0.000000] Console: colour VGA+ 80x25 [ 0.000000] console [tty0] enabled [ 0.000000] hpet clockevent registered [ 0.000000] Fast TSC calibration failed [ 0.008000] TSC: PIT calibration matches HPET. 1 loops [ 0.008000] Detected 1999.994 MHz processor. [ 0.000005] Calibrating delay loop (skipped), value calculated using timer frequency.. 3999.98 BogoMIPS (lpj=7999976) [ 0.000011] pid_max: default: 32768 minimum: 301 [ 0.000121] Security Framework initialized [ 0.000127] AppArmor: AppArmor disabled by boot time parameter [ 0.001410] Dentry cache hash table entries: 524288 (order: 11, 8388608 bytes) [ 0.004382] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes) [ 0.005232] Mount-cache hash table entries: 256 [ 0.005458] Initializing cgroup subsys cpuacct [ 0.005466] Initializing cgroup subsys memory [ 0.005484] Initializing cgroup subsys devices [ 0.005488] Initializing cgroup subsys freezer [ 0.005491] Initializing cgroup subsys net_cls [ 0.005494] Initializing cgroup subsys blkio [ 0.005992] Initializing cgroup subsys perf_event [ 0.006044] CPU: Physical Processor ID: 0 [ 0.006047] CPU: Processor Core ID: 0 [ 0.006052] ENERGY_PERF_BIAS: Set to 'normal', was 'performance' [ 0.006054] ENERGY_PERF_BIAS: View and update with x86_energy_perf_policy(8) [ 0.010812] mce: CPU supports 6 MCE banks [ 0.010824] CPU0: Thermal monitoring enabled (TM1) [ 0.010830] using mwait in idle threads. [ 0.011259] ACPI: Core revision 20110623 [ 0.030208] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=0 pin2=0 [ 0.069896] CPU0: Intel(R) Celeron(R) CPU J1900 @ 1.99GHz stepping 03 [ 0.173955] Performance Events: no PEBS fmt2+, generic architected perfmon, Intel PMU driver. [ 0.173979] ... version: 3 [ 0.173983] ... bit width: 40 [ 0.173987] ... generic registers: 2 [ 0.173990] ... value mask: 000000ffffffffff [ 0.173994] ... max period: 000000007fffffff [ 0.173997] ... fixed-purpose events: 3 [ 0.174001] ... event mask: 0000000700000003 [ 0.194349] NMI watchdog enabled, takes one hw-pmu counter. [ 0.214010] Booting Node 0, Processors #1 [ 0.214017] smpboot cpu 1: start_ip = 97000 [ 0.326833] NMI watchdog enabled, takes one hw-pmu counter. [ 0.342034] #2 [ 0.342039] smpboot cpu 2: start_ip = 97000 [ 0.454814] NMI watchdog enabled, takes one hw-pmu counter. [ 0.470023] #3 Ok. [ 0.470027] smpboot cpu 3: start_ip = 97000 [ 0.582815] NMI watchdog enabled, takes one hw-pmu counter. [ 0.585967] Brought up 4 CPUs [ 0.585973] Total of 4 processors activated (15999.98 BogoMIPS). [ 0.587291] devtmpfs: initialized [ 0.591078] PM: Registering ACPI NVS region at ad608000 (1118208 bytes) [ 0.591742] print_constraints: dummy: [ 0.591946] NET: Registered protocol family 16 [ 0.592311] ACPI: bus type pci registered [ 0.592514] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xe0000000-0xefffffff] (base 0xe0000000) [ 0.592520] PCI: not using MMCONFIG [ 0.592525] PCI: Using configuration type 1 for base access [ 0.595645] bio: create slab <bio-0> at 0 [ 0.595979] ACPI: Added _OSI(Module Device) [ 0.595987] ACPI: Added _OSI(Processor Device) [ 0.595993] ACPI: Added _OSI(3.0 _SCP Extensions) [ 0.595999] ACPI: Added _OSI(Processor Aggregator Device) [ 0.601471] ACPI: EC: Look up EC in DSDT [ 0.657432] ACPI: SSDT 0x00000000AD5ACC18 003D7 (v01 PmRef Cpu0Ist 00003000 INTL 20061109) [ 0.658868] ACPI: Dynamic OEM Table Load: [ 0.658876] ACPI: SSDT 0x0000000000000000 003D7 (v01 PmRef Cpu0Ist 00003000 INTL 20061109) [ 0.659583] ACPI: SSDT 0x00000000AD5AB918 003DE (v01 PmRef Cpu0Cst 00003001 INTL 20061109) [ 0.660924] ACPI: Dynamic OEM Table Load: [ 0.660932] ACPI: SSDT 0x0000000000000000 003DE (v01 PmRef Cpu0Cst 00003001 INTL 20061109) [ 0.692485] ACPI: SSDT 0x00000000AD5B1C18 0015F (v01 PmRef ApIst 00003000 INTL 20061109) [ 0.694045] ACPI: Dynamic OEM Table Load: [ 0.694053] ACPI: SSDT 0x0000000000000000 0015F (v01 PmRef ApIst 00003000 INTL 20061109) [ 0.714626] ACPI: SSDT 0x00000000AD5ADF18 0008D (v01 PmRef ApCst 00003000 INTL 20061109) [ 0.716021] ACPI: Dynamic OEM Table Load: [ 0.716030] ACPI: SSDT 0x0000000000000000 0008D (v01 PmRef ApCst 00003000 INTL 20061109) [ 0.744303] ACPI: Interpreter enabled [ 0.744312] ACPI: (supports S0 S3 S4 S5) [ 0.744423] ACPI: Using IOAPIC for interrupt routing [ 0.744746] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xe0000000-0xefffffff] (base 0xe0000000) [ 0.749133] PCI: MMCONFIG at [mem 0xe0000000-0xefffffff] reserved in ACPI motherboard resources [ 0.826387] ACPI: Power Resource [USBC] (on) [ 0.832326] ACPI: Power Resource [FN00] (off) [ 0.834491] ACPI: No dock devices found. [ 0.834497] HEST: Table not found. [ 0.834504] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug [ 0.835688] \_SB_.PCI0:_OSC invalid UUID [ 0.835694] _OSC request data:1 8 0 [ 0.835707] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff]) [ 0.837244] pci_root PNP0A08:00: host bridge window [io 0x0000-0x006f] [ 0.837251] pci_root PNP0A08:00: host bridge window [io 0x0078-0x0cf7] [ 0.837256] pci_root PNP0A08:00: host bridge window [io 0x0d00-0xffff] [ 0.837261] pci_root PNP0A08:00: host bridge window [mem 0x000a0000-0x000bffff] [ 0.837267] pci_root PNP0A08:00: host bridge window [mem 0x000c0000-0x000dffff] [ 0.837272] pci_root PNP0A08:00: host bridge window [mem 0x000e0000-0x000fffff] [ 0.837277] pci_root PNP0A08:00: host bridge window [mem 0xc0000000-0xd0716ffe] [ 0.837307] pci 0000:00:00.0: [8086:0f00] type 0 class 0x000600 [ 0.837375] pci 0000:00:02.0: [8086:0f31] type 0 class 0x000300 [ 0.837393] pci 0000:00:02.0: reg 10: [mem 0xd0000000-0xd03fffff] [ 0.837408] pci 0000:00:02.0: reg 18: [mem 0xc0000000-0xcfffffff pref] [ 0.837423] pci 0000:00:02.0: reg 20: [io 0xf080-0xf087] [ 0.837508] pci 0000:00:13.0: [8086:0f23] type 0 class 0x000106 [ 0.837533] pci 0000:00:13.0: reg 10: [io 0xf070-0xf077] [ 0.837545] pci 0000:00:13.0: reg 14: [io 0xf060-0xf063] [ 0.837558] pci 0000:00:13.0: reg 18: [io 0xf050-0xf057] [ 0.837570] pci 0000:00:13.0: reg 1c: [io 0xf040-0xf043] [ 0.837583] pci 0000:00:13.0: reg 20: [io 0xf020-0xf03f] [ 0.837596] pci 0000:00:13.0: reg 24: [mem 0xd0716000-0xd07167ff] [ 0.837650] pci 0000:00:13.0: PME# supported from D3hot [ 0.837686] pci 0000:00:14.0: [8086:0f35] type 0 class 0x000c03 [ 0.837710] pci 0000:00:14.0: reg 10: [mem 0xd0700000-0xd070ffff 64bit] [ 0.837777] pci 0000:00:14.0: PME# supported from D3hot D3cold [ 0.837820] pci 0000:00:1a.0: [8086:0f18] type 0 class 0x001080 [ 0.837850] pci 0000:00:1a.0: reg 10: [mem 0xd0500000-0xd05fffff] [ 0.837867] pci 0000:00:1a.0: reg 14: [mem 0xd0400000-0xd04fffff] [ 0.837998] pci 0000:00:1a.0: PME# supported from D0 D3hot [ 0.838039] pci 0000:00:1b.0: [8086:0f04] type 0 class 0x000403 [ 0.838067] pci 0000:00:1b.0: reg 10: [mem 0xd0710000-0xd0713fff 64bit] [ 0.838147] pci 0000:00:1b.0: PME# supported from D0 D3hot D3cold [ 0.838179] pci 0000:00:1c.0: [8086:0f48] type 1 class 0x000604 [ 0.838251] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold [ 0.838285] pci 0000:00:1c.1: [8086:0f4a] type 1 class 0x000604 [ 0.838356] pci 0000:00:1c.1: PME# supported from D0 D3hot D3cold [ 0.838389] pci 0000:00:1c.2: [8086:0f4c] type 1 class 0x000604 [ 0.838460] pci 0000:00:1c.2: PME# supported from D0 D3hot D3cold [ 0.838494] pci 0000:00:1c.3: [8086:0f4e] type 1 class 0x000604 [ 0.838564] pci 0000:00:1c.3: PME# supported from D0 D3hot D3cold [ 0.838611] pci 0000:00:1d.0: [8086:0f34] type 0 class 0x000c03 [ 0.838643] pci 0000:00:1d.0: reg 10: [mem 0xd0715000-0xd07153ff] [ 0.838771] pci 0000:00:1d.0: PME# supported from D0 D3hot D3cold [ 0.838811] pci 0000:00:1f.0: [8086:0f1c] type 0 class 0x000601 [ 0.838925] pci 0000:00:1f.3: [8086:0f12] type 0 class 0x000c05 [ 0.838964] pci 0000:00:1f.3: reg 10: [mem 0xd0714000-0xd071401f] [ 0.839040] pci 0000:00:1f.3: reg 20: [io 0xf000-0xf01f] [ 0.839191] pci 0000:00:1c.0: PCI bridge to [bus 01-01] [ 0.839272] pci 0000:02:00.0: [10ec:8168] type 0 class 0x000200 [ 0.839293] pci 0000:02:00.0: reg 10: [io 0xe000-0xe0ff] [ 0.839324] pci 0000:02:00.0: reg 18: [mem 0xd0604000-0xd0604fff 64bit] [ 0.839346] pci 0000:02:00.0: reg 20: [mem 0xd0600000-0xd0603fff 64bit pref] [ 0.839427] pci 0000:02:00.0: supports D1 D2 [ 0.839432] pci 0000:02:00.0: PME# supported from D0 D1 D2 D3hot D3cold [ 0.845977] pci 0000:00:1c.1: PCI bridge to [bus 02-02] [ 0.845986] pci 0000:00:1c.1: bridge window [io 0xe000-0xefff] [ 0.845993] pci 0000:00:1c.1: bridge window [mem 0xd0600000-0xd06fffff] [ 0.846049] pci 0000:00:1c.2: PCI bridge to [bus 03-03] [ 0.846100] pci 0000:00:1c.3: PCI bridge to [bus 04-04] [ 0.846132] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT] [ 0.847269] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.RP01._PRT] [ 0.847552] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.RP02._PRT] [ 0.847839] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.RP03._PRT] [ 0.848114] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.RP04._PRT] [ 0.848743] \_SB_.PCI0:_OSC invalid UUID [ 0.848748] _OSC request data:1 1f 0 [ 0.848760] pci0000:00: Requesting ACPI _OSC control (0x1d) [ 0.849117] \_SB_.PCI0:_OSC invalid UUID [ 0.849122] _OSC request data:1 0 1d [ 0.849134] pci0000:00: ACPI _OSC request failed (AE_ERROR), returned control mask: 0x1d [ 0.849138] ACPI _OSC control for PCIe not granted, disabling ASPM [ 0.884943] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 10 *11 12 14 15) [ 0.885244] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 6 10 *11 12 14 15) [ 0.885530] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 6 *10 11 12 14 15) [ 0.885815] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 6 *10 11 12 14 15) [ 0.886100] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 6 10 *11 12 14 15) [ 0.886385] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 10 11 12 14 15) *0, disabled. [ 0.886674] ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 5 6 *10 11 12 14 15) [ 0.886983] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 6 10 *11 12 14 15) [ 0.887372] vgaarb: device added: PCI:0000:00:02.0,decodes=io+mem,owns=io+mem,locks=none [ 0.887413] vgaarb: loaded [ 0.887416] vgaarb: bridge control possible 0000:00:02.0 [ 0.887609] PCI: Using ACPI for IRQ routing [ 0.893945] PCI: pci_cache_line_size set to 64 bytes [ 0.894089] reserve RAM buffer: 000000000009c800 - 000000000009ffff [ 0.894097] reserve RAM buffer: 00000000ad584000 - 00000000afffffff [ 0.894103] reserve RAM buffer: 00000000ad608000 - 00000000afffffff [ 0.894110] reserve RAM buffer: 00000000ada7e000 - 00000000afffffff [ 0.894116] reserve RAM buffer: 00000000adc2e000 - 00000000afffffff [ 0.894123] reserve RAM buffer: 00000000ae000000 - 00000000afffffff [ 0.894480] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0 [ 0.894492] hpet0: 3 comparators, 64-bit 14.318180 MHz counter [ 0.896562] AMD NB: Cannot enumerate AMD northbridges. [ 0.896568] Switching to clocksource hpet [ 0.906244] pnp: PnP ACPI init [ 0.906287] ACPI: bus type pnp registered [ 0.906365] pnp 00:00: [io 0x0070-0x0077] [ 0.906456] pnp 00:00: Plug and Play ACPI device, IDs PNP0b00 (active) [ 0.906595] pnp 00:01: [mem 0xfed00000-0xfed003ff] [ 0.906603] pnp 00:01: IRQ 8 override to edge, high [ 0.906620] pnp 00:01: [irq 8] [ 0.906700] pnp 00:01: Plug and Play ACPI device, IDs PNP0103 (active) [ 0.907452] pnp 00:02: [bus 00-ff] [ 0.907459] pnp 00:02: [io 0x0070-0x0077] [ 0.907465] pnp 00:02: [io 0x0cf8-0x0cff] [ 0.907471] pnp 00:02: [io 0x0000-0x006f window] [ 0.907476] pnp 00:02: [io 0x0078-0x0cf7 window] [ 0.907482] pnp 00:02: [io 0x0d00-0xffff window] [ 0.907488] pnp 00:02: [mem 0x000a0000-0x000bffff window] [ 0.907494] pnp 00:02: [mem 0x000c0000-0x000dffff window] [ 0.907500] pnp 00:02: [mem 0x000e0000-0x000fffff window] [ 0.907506] pnp 00:02: [mem 0x00000000 window] [ 0.907512] pnp 00:02: [mem 0x00000000-0xffffffff window] [ 0.907518] pnp 00:02: [mem 0xc0000000-0xd0716ffe window] [ 0.907665] pnp 00:02: Plug and Play ACPI device, IDs PNP0a08 PNP0a03 (active) [ 0.907964] pnp 00:03: [mem 0xff000000-0xffffffff] [ 0.908058] pnp 00:03: Plug and Play ACPI device, IDs INT0800 (active) [ 0.908115] pnp 00:04: [io 0x002e-0x002f] [ 0.908121] pnp 00:04: [io 0x004e-0x004f] [ 0.908127] pnp 00:04: [io 0x0061] [ 0.908132] pnp 00:04: [io 0x0063] [ 0.908137] pnp 00:04: [io 0x0065] [ 0.908142] pnp 00:04: [io 0x0067] [ 0.908147] pnp 00:04: [io 0x0070] [ 0.908152] pnp 00:04: [io 0x0080-0x008f] [ 0.908158] pnp 00:04: [io 0x0092] [ 0.908163] pnp 00:04: [io 0x00b2-0x00b3] [ 0.908168] pnp 00:04: [io 0x0680-0x069f] [ 0.908174] pnp 00:04: [io 0x0400-0x047f] [ 0.908179] pnp 00:04: [io 0x0500-0x05fe] [ 0.908341] system 00:04: [io 0x0680-0x069f] has been reserved [ 0.908351] system 00:04: [io 0x0400-0x047f] could not be reserved [ 0.908359] system 00:04: [io 0x0500-0x05fe] has been reserved [ 0.908367] system 00:04: Plug and Play ACPI device, IDs PNP0c02 (active) [ 0.908769] pnp 00:05: [io 0x0000-0xffffffffffffffff disabled] [ 0.908777] pnp 00:05: [io 0x0000-0xffffffffffffffff disabled] [ 0.908783] pnp 00:05: [io 0x0290-0x029f] [ 0.908788] pnp 00:05: [io 0x0000-0xffffffffffffffff disabled] [ 0.908938] system 00:05: [io 0x0290-0x029f] has been reserved [ 0.908946] system 00:05: Plug and Play ACPI device, IDs PNP0c02 (active) [ 0.911170] pnp 00:06: [io 0x0378-0x037f] [ 0.911177] pnp 00:06: [io 0x0778-0x077f] [ 0.911191] pnp 00:06: [irq 5] [ 0.911197] pnp 00:06: [dma 3] [ 0.911931] pnp 00:06: Plug and Play ACPI device, IDs PNP0400 PNP0401 (active) [ 0.913076] pnp 00:07: [io 0x03f8-0x03ff] [ 0.913089] pnp 00:07: [irq 4] [ 0.913095] pnp 00:07: [dma 0 disabled] [ 0.913288] pnp 00:07: Plug and Play ACPI device, IDs PNP0501 (active) [ 0.914747] pnp 00:08: [io 0x02f8-0x02ff] [ 0.914760] pnp 00:08: [irq 3] [ 0.914767] pnp 00:08: [dma 0 disabled] [ 0.914957] pnp 00:08: Plug and Play ACPI device, IDs PNP0501 (active) [ 0.916009] pnp 00:09: [mem 0xe0000000-0xefffffff] [ 0.916016] pnp 00:09: [mem 0xfed01000-0xfed01fff] [ 0.916022] pnp 00:09: [mem 0xfed03000-0xfed03fff] [ 0.916028] pnp 00:09: [mem 0xfed04000-0xfed04fff] [ 0.916033] pnp 00:09: [mem 0xfed0c000-0xfed0ffff] [ 0.916039] pnp 00:09: [mem 0xfed08000-0xfed08fff] [ 0.916045] pnp 00:09: [mem 0xfed1c000-0xfed1cfff] [ 0.916050] pnp 00:09: [mem 0xfee00000-0xfeefffff] [ 0.916056] pnp 00:09: [mem 0xfef00000-0xfeffffff] [ 0.916243] system 00:09: [mem 0xe0000000-0xefffffff] could not be reserved [ 0.916252] system 00:09: [mem 0xfed01000-0xfed01fff] has been reserved [ 0.916260] system 00:09: [mem 0xfed03000-0xfed03fff] has been reserved [ 0.916268] system 00:09: [mem 0xfed04000-0xfed04fff] has been reserved [ 0.916276] system 00:09: [mem 0xfed0c000-0xfed0ffff] has been reserved [ 0.916283] system 00:09: [mem 0xfed08000-0xfed08fff] has been reserved [ 0.916291] system 00:09: [mem 0xfed1c000-0xfed1cfff] has been reserved [ 0.916299] system 00:09: [mem 0xfee00000-0xfeefffff] has been reserved [ 0.916311] system 00:09: [mem 0xfef00000-0xfeffffff] has been reserved [ 0.916319] system 00:09: Plug and Play ACPI device, IDs PNP0c02 (active) [ 0.921725] pnp: PnP ACPI: found 10 devices [ 0.921730] ACPI: ACPI bus type pnp unregistered [ 0.934219] PCI: max bus depth: 1 pci_try_num: 2 [ 0.934281] pci 0000:00:1c.3: BAR 14: can't assign mem (size 0x200000) [ 0.934291] pci 0000:00:1c.3: BAR 15: can't assign mem pref (size 0x200000) [ 0.934302] pci 0000:00:1c.3: BAR 13: assigned [io 0x1000-0x1fff] [ 0.934311] pci 0000:00:1c.2: BAR 14: can't assign mem (size 0x200000) [ 0.934320] pci 0000:00:1c.2: BAR 15: can't assign mem pref (size 0x200000) [ 0.934329] pci 0000:00:1c.2: BAR 13: assigned [io 0x2000-0x2fff] [ 0.934338] pci 0000:00:1c.1: BAR 15: can't assign mem pref (size 0x200000) [ 0.934347] pci 0000:00:1c.0: BAR 14: can't assign mem (size 0x200000) [ 0.934356] pci 0000:00:1c.0: BAR 15: can't assign mem pref (size 0x200000) [ 0.934364] pci 0000:00:1c.0: BAR 13: assigned [io 0x3000-0x3fff] [ 0.934379] pci 0000:00:1c.0: PCI bridge to [bus 01-01] [ 0.934384] pci 0000:00:1c.0: bridge window [io 0x3000-0x3fff] [ 0.934398] pci 0000:00:1c.1: PCI bridge to [bus 02-02] [ 0.934403] pci 0000:00:1c.1: bridge window [io 0xe000-0xefff] [ 0.934411] pci 0000:00:1c.1: bridge window [mem 0xd0600000-0xd06fffff] [ 0.934421] pci 0000:00:1c.2: PCI bridge to [bus 03-03] [ 0.934426] pci 0000:00:1c.2: bridge window [io 0x2000-0x2fff] [ 0.934439] pci 0000:00:1c.3: PCI bridge to [bus 04-04] [ 0.934444] pci 0000:00:1c.3: bridge window [io 0x1000-0x1fff] [ 0.934484] pci 0000:00:1c.0: setting latency timer to 64 [ 0.934514] pci 0000:00:1c.1: setting latency timer to 64 [ 0.934536] pci 0000:00:1c.2: setting latency timer to 64 [ 0.934558] pci 0000:00:1c.3: setting latency timer to 64 [ 0.934565] pci_bus 0000:00: resource 4 [io 0x0000-0x006f] [ 0.934570] pci_bus 0000:00: resource 5 [io 0x0078-0x0cf7] [ 0.934575] pci_bus 0000:00: resource 6 [io 0x0d00-0xffff] [ 0.934580] pci_bus 0000:00: resource 7 [mem 0x000a0000-0x000bffff] [ 0.934585] pci_bus 0000:00: resource 8 [mem 0x000c0000-0x000dffff] [ 0.934590] pci_bus 0000:00: resource 9 [mem 0x000e0000-0x000fffff] [ 0.934595] pci_bus 0000:00: resource 10 [mem 0xc0000000-0xd0716ffe] [ 0.934601] pci_bus 0000:01: resource 0 [io 0x3000-0x3fff] [ 0.934606] pci_bus 0000:02: resource 0 [io 0xe000-0xefff] [ 0.934611] pci_bus 0000:02: resource 1 [mem 0xd0600000-0xd06fffff] [ 0.934616] pci_bus 0000:03: resource 0 [io 0x2000-0x2fff] [ 0.934621] pci_bus 0000:04: resource 0 [io 0x1000-0x1fff] [ 0.934784] NET: Registered protocol family 2 [ 0.940770] IP route cache hash table entries: 131072 (order: 8, 1048576 bytes) [ 0.944352] TCP established hash table entries: 524288 (order: 11, 8388608 bytes) [ 0.948306] TCP bind hash table entries: 65536 (order: 9, 3670016 bytes) [ 0.949591] TCP: Hash tables configured (established 524288 bind 65536) [ 0.949598] TCP reno registered [ 0.949699] UDP hash table entries: 2048 (order: 6, 262144 bytes) [ 0.949885] UDP-Lite hash table entries: 2048 (order: 6, 262144 bytes) [ 0.950237] NET: Registered protocol family 1 [ 0.950285] pci 0000:00:02.0: Boot video device [ 0.964643] PCI: CLS 64 bytes, default 64 [ 0.964817] Unpacking initramfs... [ 1.354067] Freeing initrd memory: 10408k freed [ 1.359807] PCI-DMA: Using software bounce buffering for IO (SWIOTLB) [ 1.359816] Placing 64MB software IO TLB between ffff8800a9584000 - ffff8800ad584000 [ 1.359821] software IO TLB at phys 0xa9584000 - 0xad584000 [ 1.361423] audit: initializing netlink socket (disabled) [ 1.361455] type=2000 audit(1540930868.204:1): initialized [ 1.381798] HugeTLB registered 2 MB page size, pre-allocated 0 pages [ 1.382412] VFS: Disk quotas dquot_6.5.2 [ 1.382503] Dquot-cache hash table entries: 512 (order 0, 4096 bytes) [ 1.382711] msgmni has been set to 7336 [ 1.383141] alg: No test for stdrng (krng) [ 1.383218] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253) [ 1.383226] io scheduler noop registered [ 1.383230] io scheduler deadline registered [ 1.383282] io scheduler cfq registered (default) [ 1.383789] pci_hotplug: PCI Hot Plug PCI Core version: 0.5 [ 1.383870] pciehp: PCI Express Hot Plug Controller Driver version: 0.4 [ 1.383875] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5 [ 1.385585] intel_idle: does not run on family 6 model 55 [ 1.385643] ERST: Table is not found! [ 1.385647] GHES: HEST is not enabled! [ 1.385793] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled [ 1.406391] serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A [ 1.489120] serial8250: ttyS1 at I/O 0x2f8 (irq = 3) is a 16550A [ 1.685401] 00:07: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A [ 1.753258] 00:08: ttyS1 at I/O 0x2f8 (irq = 3) is a 16550A [ 1.801110] Linux agpgart interface v0.103 [ 1.801520] i8042: PNP: No PS/2 controller found. Probing ports directly. [ 1.804358] serio: i8042 KBD port at 0x60,0x64 irq 1 [ 1.804404] serio: i8042 AUX port at 0x60,0x64 irq 12 [ 1.804919] mousedev: PS/2 mouse device common for all mice [ 1.805028] rtc_cmos 00:00: RTC can wake from S4 [ 1.805262] rtc_cmos 00:00: rtc core: registered rtc_cmos as rtc0 [ 1.805360] rtc0: alarms up to one month, y3k, 242 bytes nvram, hpet irqs [ 1.805396] cpuidle: using governor ladder [ 1.805401] cpuidle: using governor menu [ 1.806171] TCP cubic registered [ 1.806290] NET: Registered protocol family 10 [ 1.808042] Mobile IPv6 [ 1.808049] NET: Registered protocol family 17 [ 1.808061] Registering the dns_resolver key type [ 1.808464] PM: Hibernation image not present or could not be loaded. [ 1.808499] registered taskstats version 1 [ 1.809236] rtc_cmos 00:00: setting system clock to 2018-10-30 20:21:09 UTC (1540930869) [ 1.809481] Initializing network drop monitor service [ 1.813444] Freeing unused kernel memory: 916k freed [ 1.813859] Write protecting the kernel read-only data: 6144k [ 1.818207] Freeing unused kernel memory: 544k freed [ 1.823475] Freeing unused kernel memory: 652k freed [ 1.851919] udevd[77]: starting version 175 [ 1.936885] SCSI subsystem initialized [ 1.948981] usbcore: registered new interface driver usbfs [ 1.953736] usbcore: registered new interface driver hub [ 1.955888] usbcore: registered new device driver usb [ 1.959440] libata version 3.00 loaded. [ 1.962507] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver [ 1.962799] ehci_hcd 0000:00:1d.0: setting latency timer to 64 [ 1.962809] ehci_hcd 0000:00:1d.0: EHCI Host Controller [ 1.962961] ehci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 1 [ 1.963035] ehci_hcd 0000:00:1d.0: debug port 2 [ 1.966938] ehci_hcd 0000:00:1d.0: cache line size of 64 is not supported [ 1.967085] ehci_hcd 0000:00:1d.0: irq 23, io mem 0xd0715000 [ 1.975882] ACPI: Fan [FAN0] (off) [ 1.980701] ehci_hcd 0000:00:1d.0: USB 2.0 started, EHCI 1.00 [ 1.981055] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002 [ 1.981075] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 1.981082] usb usb1: Product: EHCI Host Controller [ 1.981087] usb usb1: Manufacturer: Linux 3.2.0-4-rt-amd64 ehci_hcd [ 1.981094] usb usb1: SerialNumber: 0000:00:1d.0 [ 1.982848] r8169 Gigabit Ethernet driver 2.3LK-NAPI loaded [ 1.982924] r8169 0000:02:00.0: (unregistered net_device): unknown MAC, using family default [ 1.982948] r8169 0000:02:00.0: setting latency timer to 64 [ 1.983044] r8169 0000:02:00.0: irq 103 for MSI/MSI-X [ 1.983697] thermal LNXTHERM:00: registered as thermal_zone0 [ 1.983705] ACPI: Thermal Zone [TZ01] (27 C) [ 1.988038] hub 1-0:1.0: USB hub found [ 1.988096] hub 1-0:1.0: 8 ports detected [ 1.990472] r8169 0000:02:00.0: eth0: RTL8168b/8111b at 0xffffc90000a78000, d0:50:99:a6:d7:74, XID 0c000800 IRQ 103 [ 1.990480] r8169 0000:02:00.0: eth0: jumbo features [frames: 4080 bytes, tx checksumming: ko] [ 1.992307] xhci_hcd 0000:00:14.0: setting latency timer to 64 [ 1.992316] xhci_hcd 0000:00:14.0: xHCI Host Controller [ 1.992416] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 2 [ 1.993562] xhci_hcd 0000:00:14.0: cache line size of 64 is not supported [ 1.993623] xhci_hcd 0000:00:14.0: irq 104 for MSI/MSI-X [ 1.994008] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002 [ 1.994017] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 1.994022] usb usb2: Product: xHCI Host Controller [ 1.994027] usb usb2: Manufacturer: Linux 3.2.0-4-rt-amd64 xhci_hcd [ 1.994032] usb usb2: SerialNumber: 0000:00:14.0 [ 1.997200] xHCI xhci_add_endpoint called for root hub [ 1.997207] xHCI xhci_check_bandwidth called for root hub [ 1.998270] hub 2-0:1.0: USB hub found [ 1.998292] hub 2-0:1.0: 6 ports detected [ 2.000762] xhci_hcd 0000:00:14.0: xHCI Host Controller [ 2.000786] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 3 [ 2.000877] usb usb3: New USB device found, idVendor=1d6b, idProduct=0003 [ 2.000884] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 2.000891] usb usb3: Product: xHCI Host Controller [ 2.000896] usb usb3: Manufacturer: Linux 3.2.0-4-rt-amd64 xhci_hcd [ 2.000901] usb usb3: SerialNumber: 0000:00:14.0 [ 2.004125] xHCI xhci_add_endpoint called for root hub [ 2.004132] xHCI xhci_check_bandwidth called for root hub [ 2.005322] hub 3-0:1.0: USB hub found [ 2.005358] hub 3-0:1.0: 1 port detected [ 2.021437] ahci 0000:00:13.0: version 3.0 [ 2.021557] ahci 0000:00:13.0: irq 105 for MSI/MSI-X [ 2.036623] ahci 0000:00:13.0: AHCI 0001.0300 32 slots 2 ports 3 Gbps 0x1 impl SATA mode [ 2.036634] ahci 0000:00:13.0: flags: 64bit ncq led clo pio slum part [ 2.036645] ahci 0000:00:13.0: setting latency timer to 64 [ 2.042999] scsi0 : ahci [ 2.043451] scsi1 : ahci [ 2.043870] ata1: SATA max UDMA/133 abar m2048@0xd0716000 port 0xd0716100 irq 105 [ 2.043879] ata2: DUMMY [ 2.296608] usb 1-1: new high-speed USB device number 2 using ehci_hcd [ 2.356606] Refined TSC clocksource calibration: 1999.999 MHz. [ 2.356616] Switching to clocksource tsc [ 2.368607] ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 300) [ 2.369544] ata1.00: ATA-9: TS16GHSD370, O0918B, max UDMA/133 [ 2.369550] ata1.00: 31277232 sectors, multi 2: LBA48 NCQ (depth 31/32), AA [ 2.369765] ata1.00: configured for UDMA/133 [ 2.370005] scsi 0:0:0:0: Direct-Access ATA TS16GHSD370 O091 PQ: 0 ANSI: 5 [ 2.380495] sd 0:0:0:0: [sda] 31277232 512-byte logical blocks: (16.0 GB/14.9 GiB) [ 2.380786] sd 0:0:0:0: [sda] Write Protect is off [ 2.380794] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00 [ 2.380879] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA [ 2.381912] sda: sda1 sda2 < sda5 > [ 2.382968] sd 0:0:0:0: [sda] Attached SCSI disk [ 2.387156] sd 0:0:0:0: Attached scsi generic sg0 type 0 [ 2.429151] usb 1-1: New USB device found, idVendor=8087, idProduct=07e6 [ 2.429162] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0 [ 2.429652] hub 1-1:1.0: USB hub found [ 2.429776] hub 1-1:1.0: 4 ports detected [ 2.700595] usb 1-1.1: new low-speed USB device number 3 using ehci_hcd [ 2.812525] usb 1-1.1: New USB device found, idVendor=03f0, idProduct=034a [ 2.812532] usb 1-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0 [ 2.812537] usb 1-1.1: Product: HP Elite USB Keyboard [ 2.812541] usb 1-1.1: Manufacturer: Chicony [ 2.830150] input: Chicony HP Elite USB Keyboard as /devices/pci0000:00/0000:00:1d.0/usb1/1-1/1-1.1/1-1.1:1.0/input/input0 [ 2.830318] generic-usb 0003:03F0:034A.0001: input,hidraw0: USB HID v1.10 Keyboard [Chicony HP Elite USB Keyboard] on usb-0000:00:1d.0-1.1/input0 [ 2.840625] input: Chicony HP Elite USB Keyboard as /devices/pci0000:00/0000:00:1d.0/usb1/1-1/1-1.1/1-1.1:1.1/input/input1 [ 2.840778] generic-usb 0003:03F0:034A.0002: input,hidraw1: USB HID v1.10 Device [Chicony HP Elite USB Keyboard] on usb-0000:00:1d.0-1.1/input1 [ 2.840827] usbcore: registered new interface driver usbhid [ 2.840832] usbhid: USB HID core driver [ 2.884612] usb 1-1.2: new high-speed USB device number 4 using ehci_hcd [ 2.895317] PM: Starting manual resume from disk [ 2.895325] PM: Hibernation image partition 8:5 present [ 2.895328] PM: Looking for hibernation image. [ 2.895638] PM: Image not found (code -22) [ 2.895643] PM: Hibernation image not present or could not be loaded. [ 2.921749] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null) [ 2.978272] usb 1-1.2: New USB device found, idVendor=05e3, idProduct=0608 [ 2.978280] usb 1-1.2: New USB device strings: Mfr=0, Product=1, SerialNumber=0 [ 2.978285] usb 1-1.2: Product: USB2.0 Hub [ 2.978858] hub 1-1.2:1.0: USB hub found [ 2.979140] hub 1-1.2:1.0: 3 ports detected [ 3.052600] usb 1-1.3: new full-speed USB device number 5 using ehci_hcd [ 3.145780] usb 1-1.3: New USB device found, idVendor=1a86, idProduct=7523 [ 3.145788] usb 1-1.3: New USB device strings: Mfr=0, Product=2, SerialNumber=0 [ 3.145793] usb 1-1.3: Product: USB2.0-Serial [ 3.216602] usb 1-1.4: new high-speed USB device number 6 using ehci_hcd [ 3.309523] usb 1-1.4: New USB device found, idVendor=0b05, idProduct=17d2 [ 3.309530] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3 [ 3.309536] usb 1-1.4: Product: 802.11n NIC [ 3.309540] usb 1-1.4: Manufacturer: Realtek [ 3.309544] usb 1-1.4: SerialNumber: 123456 [ 3.380616] usb 1-1.2.3: new low-speed USB device number 7 using ehci_hcd [ 3.458280] udevd[364]: starting version 175 [ 3.480153] usb 1-1.2.3: New USB device found, idVendor=03f0, idProduct=1198 [ 3.480163] usb 1-1.2.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0 [ 3.480169] usb 1-1.2.3: Product: HP USB 1000dpi Laser Mouse [ 3.480174] usb 1-1.2.3: Manufacturer: HP [ 3.484671] input: HP HP USB 1000dpi Laser Mouse as /devices/pci0000:00/0000:00:1d.0/usb1/1-1/1-1.2/1-1.2.3/1-1.2.3:1.0/input/input2 [ 3.484912] generic-usb 0003:03F0:1198.0003: input,hidraw2: USB HID v2.00 Mouse [HP HP USB 1000dpi Laser Mouse] on usb-0000:00:1d.0-1.2.3/input0 [ 3.488146] generic-usb 0003:03F0:1198.0004: hiddev0,hidraw3: USB HID v2.00 Device [HP HP USB 1000dpi Laser Mouse] on usb-0000:00:1d.0-1.2.3/input1 [ 3.686124] ACPI: Requesting acpi_cpufreq [ 3.707169] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input3 [ 3.707187] ACPI: Power Button [PWRB] [ 3.712146] Monitor-Mwait will be used to enter C-1 state [ 3.712175] Monitor-Mwait will be used to enter C-2 state [ 3.712221] ACPI: acpi_idle registered with cpuidle [ 3.728300] input: PC Speaker as /devices/platform/pcspkr/input/input4 [ 3.732490] input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input5 [ 3.732557] ACPI: Sleep Button [SLPB] [ 3.739893] ACPI: resource 0000:00:1f.3 [io 0xf000-0xf01f] conflicts with ACPI region SMBI [io 0xf000-0xf00f] [ 3.739901] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver [ 3.755128] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input6 [ 3.755141] ACPI: Power Button [PWRF] [ 3.864198] snd_hda_intel 0000:00:1b.0: irq 106 for MSI/MSI-X [ 3.864939] snd_hda_intel 0000:00:1b.0: setting latency timer to 64 [ 4.011978] input: HDA Intel Headphone as /devices/pci0000:00/0000:00:1b.0/sound/card0/input7 [ 4.045835] parport_pc 00:06: reported by Plug and Play ACPI [ 4.045926] parport0: PC-style at 0x378 (0x778), irq 5 [PCSPP,TRISTATE] [ 4.599990] usbcore: registered new interface driver usbserial [ 4.600896] USB Serial support registered for generic [ 4.602765] usbcore: registered new interface driver usbserial_generic [ 4.602773] usbserial: USB Serial Driver core [ 4.609990] USB Serial support registered for ch341-uart [ 4.610478] ch341 1-1.3:1.0: ch341-uart converter detected [ 4.617411] usb 1-1.3: ch341-uart converter now attached to ttyUSB0 [ 4.618150] usbcore: registered new interface driver ch341 [ 4.654683] RTL871X: module init start [ 4.654692] RTL871X: rtl8812au v4.3.13_14061.20150505 [ 4.654702] RTL871X: build time: Mar 7 2017 18:35:59 [ 4.655268] RTL871X: [ 4.655271] usb_endpoint_descriptor(0): [ 4.655279] RTL871X: bLength=7 [ 4.655285] RTL871X: bDescriptorType=5 [ 4.655290] RTL871X: bEndpointAddress=81 [ 4.655295] RTL871X: wMaxPacketSize=512 [ 4.655300] RTL871X: bInterval=0 [ 4.655305] RTL871X: RT_usb_endpoint_is_bulk_in = 1 [ 4.655311] RTL871X: [ 4.655312] usb_endpoint_descriptor(1): [ 4.655317] RTL871X: bLength=7 [ 4.655322] RTL871X: bDescriptorType=5 [ 4.655327] RTL871X: bEndpointAddress=2 [ 4.655332] RTL871X: wMaxPacketSize=512 [ 4.655337] RTL871X: bInterval=0 [ 4.655341] RTL871X: RT_usb_endpoint_is_bulk_out = 2 [ 4.655347] RTL871X: [ 4.655348] usb_endpoint_descriptor(2): [ 4.655353] RTL871X: bLength=7 [ 4.655358] RTL871X: bDescriptorType=5 [ 4.655362] RTL871X: bEndpointAddress=3 [ 4.655367] RTL871X: wMaxPacketSize=512 [ 4.655372] RTL871X: bInterval=0 [ 4.655377] RTL871X: RT_usb_endpoint_is_bulk_out = 3 [ 4.655382] RTL871X: [ 4.655384] usb_endpoint_descriptor(3): [ 4.655388] RTL871X: bLength=7 [ 4.655393] RTL871X: bDescriptorType=5 [ 4.655398] RTL871X: bEndpointAddress=4 [ 4.655402] RTL871X: wMaxPacketSize=512 [ 4.655407] RTL871X: bInterval=0 [ 4.655412] RTL871X: RT_usb_endpoint_is_bulk_out = 4 [ 4.655417] RTL871X: [ 4.655419] usb_endpoint_descriptor(4): [ 4.655424] RTL871X: bLength=7 [ 4.655428] RTL871X: bDescriptorType=5 [ 4.655433] RTL871X: bEndpointAddress=85 [ 4.655438] RTL871X: wMaxPacketSize=64 [ 4.655443] RTL871X: bInterval=1 [ 4.655448] RTL871X: RT_usb_endpoint_is_int_in = 5, Interval = 1 [ 4.655454] RTL871X: nr_endpoint=5, in_num=2, out_num=3 [ 4.655456] [ 4.655460] RTL871X: USB_SPEED_HIGH [ 4.655496] RTL871X: CHIP TYPE: RTL8812 [ 4.655518] RTL871X: register rtw_netdev_ops to netdev_ops [ 4.655801] RTL871X: ReadChipVersion8812A SYS_CFG(0xF0)=0x04411137 [ 4.655908] RTL871X: Chip Version Info: CHIP_8812_Normal_Chip_TSMC_C_CUT_2T2R_RomVer(0) [ 4.655918] RTL871X: RF_Type is 2!! [ 4.655926] RTL871X: _ConfigChipOutEP_8812 OutEpQueueSel(0x07), OutEpNumber(3) [ 4.655934] RTL871X: ====> ReadAdapterInfo8812AU [ 4.656039] RTL871X: Boot from EFUSE, Autoload OK ! [ 4.961907] RTL871X: EEPROM ID=0x8129 [ 4.961917] RTL871X: VID = 0x0B05, PID = 0x17D2 [ 4.961923] RTL871X: Customer ID: 0x00, SubCustomer ID: 0xCD [ 4.961931] RTL871X: hal_ReadMACAddress_8812AU MAC Address from EFUSE = 9c:5c:8e:b2:b5:a9 [ 4.961945] RTL871X: ==>mpt_GetChnlGroup8812A in 5G, but Channel 163 in Group not found [ 4.961955] RTL871X: ==>mpt_GetChnlGroup8812A in 5G, but Channel 163 in Group not found [ 4.961964] RTL871X: ==>mpt_GetChnlGroup8812A in 5G, but Channel 163 in Group not found [ 4.961973] RTL871X: ==>mpt_GetChnlGroup8812A in 5G, but Channel 163 in Group not found [ 4.961980] RTL871X: EEPROMRegulatory = 0x1 TxPwrCalibrateRate=0x0 [ 4.961986] RTL871X: Board Type: 0x 0 [ 4.961991] RTL871X: mlmepriv.ChannelPlan = 0x26 [ 4.961997] RTL871X: CrystalCap: 0x2e [ 4.962002] RTL871X: ThermalMeter = 0x1b [ 4.962007] RTL871X: Hal_ReadRemoteWakeup_8812A...bSupportRemoteWakeup(0) [ 4.962013] RTL871X: SWAS: bHwAntDiv = 0, TRxAntDivType = 3 [ 4.962020] RTL871X: pHalData->PAType_2G is 0x33, pHalData->ExternalPA_2G = 1 [ 4.962026] RTL871X: pHalData->PAType_5G is 0x33, pHalData->ExternalPA_5G = 1 [ 4.962032] RTL871X: pHalData->LNAType_2G is 0x88, pHalData->ExternalLNA_2G = 1 [ 4.962038] RTL871X: pHalData->LNAType_5G is 0x88, pHalData->ExternalLNA_5G = 1 [ 4.962044] RTL871X: pHalData->TypeGPA = 0x0 [ 4.962049] RTL871X: pHalData->TypeAPA = 0x0 [ 4.962054] RTL871X: pHalData->TypeGLNA = 0x0 [ 4.962059] RTL871X: pHalData->TypeALNA = 0x0 [ 4.962064] RTL871X: RFE Type: 0x 3 [ 4.962069] RTL871X: PID= 0x17d2, VID= b05 [ 4.962075] RTL871X: PID= 0x17d2, VID= b05 [ 4.962080] RTL871X: Customer ID: 0x23 [ 4.963905] RTL871X: hal_ReadUsbType_8812AU: antenna=2, wmode=3 [ 4.963912] RTL871X: hal_ReadUsbType_8812AU(): EFUSE_HIDDEN_812AU [ 4.963917] RTL871X: ReadAdapterInfo8812AU <==== [ 4.964044] RTL871X: Hal_ChannelPlanToRegulation ChannelPlan:0x26,Regulation(2_4G/5G):0x00,0x02 [ 4.964053] RTL871X: init_channel_set ChannelPlan ID 26 Chan num:32 [ 4.964878] RTL871X: NR_RECVBUFF: 8 [ 4.964884] RTL871X: MAX_RECVBUF_SZ: 32768 [ 4.964912] RTL871X: NR_PREALLOC_RECV_SKB: 8 [ 4.965128] RTL871X: rtw_alloc_macid(eth%d) if1, hwaddr:ff:ff:ff:ff:ff:ff macid:1 [ 4.965151] RTL871X: rtw_macaddr_cfg mac addr:9c:5c:8e:b2:b5:a9 [ 4.965159] RTL871X: bDriverStopped:1, bSurpriseRemoved:0, bup:0, hw_init_completed:0 [ 4.965180] RTL871X: rtw_ndev_init(wlan0) [ 4.968078] RTL871X: _rtw_drv_register_netdev, MAC Address (if1) = 9c:5c:8e:b2:b5:a9 [ 4.968170] usbcore: registered new interface driver rtl8812au [ 4.968178] RTL871X: module init ret=0 [ 5.767280] Adding 686076k swap on /dev/sda5. Priority:-1 extents:1 across:686076k SS [ 5.813738] EXT4-fs (sda1): re-mounted. Opts: (null) [ 5.894624] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro [ 5.985554] loop: module loaded [ 7.872334] RPC: Registered named UNIX socket transport module. [ 7.872343] RPC: Registered udp transport module. [ 7.872349] RPC: Registered tcp transport module. [ 7.872355] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 7.887130] FS-Cache: Loaded [ 7.901538] FS-Cache: Netfs 'nfs' registered for caching [ 7.911463] Installing knfsd (copyright (C) 1996 okir@monad.swb.de). [ 9.250465] Bluetooth: Core ver 2.16 [ 9.250508] NET: Registered protocol family 31 [ 9.250513] Bluetooth: HCI device and connection manager initialized [ 9.250519] Bluetooth: HCI socket layer initialized [ 9.250525] Bluetooth: L2CAP socket layer initialized [ 9.250542] Bluetooth: SCO socket layer initialized [ 9.258289] Bluetooth: RFCOMM TTY layer initialized [ 9.258303] Bluetooth: RFCOMM socket layer initialized [ 9.258309] Bluetooth: RFCOMM ver 1.11 [ 9.264291] Bluetooth: BNEP (Ethernet Emulation) ver 1.3 [ 9.264298] Bluetooth: BNEP filters: protocol multicast [ 9.425266] r8169 0000:02:00.0: eth0: link down [ 9.425284] r8169 0000:02:00.0: eth0: link down [ 9.426576] ADDRCONF(NETDEV_UP): eth0: link is not ready [ 9.433959] RTL871X: LeaveAllPowerSaveMode(wlan0): bup=0 Skip! [ 9.433966] RTL871X: rtw_wx_set_scan: bDriverStopped=1, bup=0, hw_init_completed=0 [ 9.435343] RTL871X: +871x_drv - drv_open, bup=0 [ 9.435650] RTL871X: power-on :REG_SYS_CLKR 0x09=0xfc. REG_CR 0x100=0xff. [ 9.435655] RTL871X: MAC has already power on. [ 9.438580] RTL871X: =====> _8051Reset8812(): 8051 reset success . [ 9.444904] RTL871X: SetHwReg8812A: bMacPwrCtrlOn=1 [ 9.509779] RTL871X: FirmwareDownload8812 fw source from Header [ 9.509793] RTL871X: FirmwareDownload8812 fw:NIC, size: 31936 [ 9.509801] RTL871X: FirmwareDownload8812: fw_ver=38 fw_subver=0 sig=0x9501 [ 9.553034] RTL871X: polling_fwdl_chksum: Checksum report OK! (1, 0ms), REG_MCUFWDL:0x00070705 [ 9.554901] RTL871X: =====> _8051Reset8812(): 8051 reset success . [ 9.582907] RTL871X: _FWFreeToGo8812: Polling FW ready OK! (224, 28ms), REG_MCUFWDL:0x000707c6 [ 9.582917] RTL871X: FWDL success. write_fw:1, 72ms [ 9.582926] RTL871X: rtl8812au_hal_init: Download Firmware Success!! [ 9.607904] RTL871X: ===> phy_BB8812_Config_ParaFile() EEPROMRegulatory 1 [ 9.929290] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f [ 10.643779] RTL871X: pDM_Odm TxPowerTrackControl = 1 [ 10.645780] RTL871X: MAC Address from REG_MACID = 9c:5c:8e:b2:b5:a9 [ 10.645791] RTL871X: rtl8812au_hal_init in 1212ms [ 10.646279] RTL871X: hw_var_set_opmode()-4935 mode = 2 [ 10.646779] RTL871X: MAC Address = 9c:5c:8e:b2:b5:a9 [ 10.646947] RTL871X: -871x_drv - drv_open, bup=1 [ 10.648055] ADDRCONF(NETDEV_UP): wlan0: link is not ready [ 10.730133] RTL871X: [rtw_wx_set_pmkid] IW_PMKSA_FLUSH! [ 10.730147] RTL871X: set_mode = IW_MODE_INFRA [ 10.730225] RTL871X: set bssid:00:00:00:00:00:00 [ 10.730299] RTL871X: =>rtw_wx_set_essid [ 10.730303] RTL871X: ssid=g\xffffffc6isQ\xffffffffJ\xffffffec)\xffffffcd\xffffffba\xffffffba\xffffffab\xfffffff2\xfffffffb\xffffffe3F|\xffffffc2T\xfffffff8\x1b\xffffffe8\xffffffe7\xffffff8dvZ.c3\xffffff9f\xffffffc9\xffffff9a\xffffff9a, len=32 [ 10.730310] RTL871X: set ssid [g\xffffffc6isQ\xffffffffJ\xffffffec)\xffffffcd\xffffffba\xffffffba\xffffffab\xfffffff2\xfffffffb\xffffffe3F|\xffffffc2T\xfffffff8\x1b\xffffffe8\xffffffe7\xffffff8dvZ.c3\xffffff9f\xffffffc9\xffffff9a\xffffff9a\x13;z\x0f] fw_state=0x00000008 [ 10.730314] RTL871X: Set SSID under fw_state=0x00000008 [ 10.730324] RTL871X: <=rtw_wx_set_essid, ret 0 [ 10.730646] RTL871X: hw_var_set_opmode()-4935 mode = 2 [ 10.749151] RTL871X: [rtw_wx_set_pmkid] IW_PMKSA_FLUSH! [ 11.078158] r8169 0000:02:00.0: eth0: link up [ 11.079149] ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready [ 12.388784] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150 [ 14.787782] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f [ 14.822411] RTL871X: survey done event(3) band:0 for wlan0 [ 14.822432] RTL871X: rtw_select_and_join_from_scanned_queue: return _FAIL(candidate == NULL) [ 14.822440] RTL871X: try_to_join, but select scanning queue fail, to_roam:0 [ 14.822447] RTL871X: indicate disassoc [ 14.822605] RTL871X: rtw_indicate_scan_done(wlan0) [ 14.822715] RTL871X: rtl8812_set_FwJoinBssReport_cmd mstatus(0) [ 14.822728] RTL871X: beamforming_deinit_entry Idx 0 [ 14.822736] RTL871X: beamforming_notify BeamformState 0 bSounding 0 [ 14.830130] RTL871X: ==>rtw_ps_processor .fw_state(8) [ 14.830141] RTL871X: ==>ips_enter cnts:1 [ 14.830146] RTL871X: nolinked power save enter [ 14.830153] RTL871X: ===> rtw_ips_pwr_down................... [ 14.830160] RTL871X: ====> rtw_ips_dev_unload... [ 14.841199] RTL871X: usb_read_port_cancel [ 14.841274] RTL871X: usb_read_port_complete() RX Warning! bDriverStopped(0) OR bSurpriseRemoved(0) [ 14.841393] RTL871X: usb_read_port_complete() RX Warning! bDriverStopped(0) OR bSurpriseRemoved(0) [ 14.841517] RTL871X: usb_read_port_complete() RX Warning! bDriverStopped(0) OR bSurpriseRemoved(0) [ 14.841640] RTL871X: usb_read_port_complete() RX Warning! bDriverStopped(0) OR bSurpriseRemoved(0) [ 14.841766] RTL871X: usb_read_port_complete() RX Warning! bDriverStopped(0) OR bSurpriseRemoved(0) [ 14.841892] RTL871X: usb_read_port_complete() RX Warning! bDriverStopped(0) OR bSurpriseRemoved(0) [ 14.842019] RTL871X: usb_read_port_complete() RX Warning! bDriverStopped(0) OR bSurpriseRemoved(0) [ 14.842143] RTL871X: usb_read_port_complete() RX Warning! bDriverStopped(0) OR bSurpriseRemoved(0) [ 14.842155] RTL871X: usb_write_port_cancel [ 14.842178] RTL871X: ==> rtl8812au_hal_deinit [ 14.843136] RTL871X: hal_poweroff_8812au [ 14.847765] RTL871X: =====> _8051Reset8812(): 8051 reset success . [ 14.854015] RTL871X: SetHwReg8812A: bMacPwrCtrlOn=0 [ 14.854262] RTL871X: <=== rtw_ips_pwr_down..................... in 24ms [ 14.922999] RTL871X: _rtw_pwr_wakeup call ips_leave.... [ 14.923009] RTL871X: ==>ips_leave cnts:1 [ 14.923015] RTL871X: ===> rtw_ips_pwr_up.............. [ 14.923026] RTL871X: ===> ips_netdrv_open......... [ 14.923485] RTL871X: power-on :REG_SYS_CLKR 0x09=0xb0. REG_CR 0x100=0xea. [ 14.923493] RTL871X: MAC has not been powered on yet. [ 14.929407] RTL871X: SetHwReg8812A: bMacPwrCtrlOn=1 [ 14.993781] RTL871X: FirmwareDownload8812 fw source from Header [ 14.993790] RTL871X: FirmwareDownload8812 fw:NIC, size: 31936 [ 14.993798] RTL871X: FirmwareDownload8812: fw_ver=38 fw_subver=0 sig=0x9501 [ 15.037657] RTL871X: polling_fwdl_chksum: Checksum report OK! (1, 0ms), REG_MCUFWDL:0x00070705 [ 15.039526] RTL871X: =====> _8051Reset8812(): 8051 reset success . [ 15.067646] RTL871X: _FWFreeToGo8812: Polling FW ready OK! (219, 28ms), REG_MCUFWDL:0x000707c6 [ 15.067651] RTL871X: FWDL success. write_fw:1, 72ms [ 15.067656] RTL871X: rtl8812au_hal_init: Download Firmware Success!! [ 15.092893] RTL871X: ===> phy_BB8812_Config_ParaFile() EEPROMRegulatory 1 [ 15.412285] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f [ 16.129410] RTL871X: pDM_Odm TxPowerTrackControl = 1 [ 16.131405] RTL871X: MAC Address from REG_MACID = 9c:5c:8e:b2:b5:a9 [ 16.131414] RTL871X: rtl8812au_hal_init in 1208ms [ 16.131903] RTL871X: hw_var_set_opmode()-4935 mode = 2 [ 16.132438] RTL871X: <=== rtw_ips_pwr_up.............. in 1208ms [ 16.132445] RTL871X: nolinked power save leave [ 16.132530] RTL871X: ==> ips_leave.....LED(0x00028228)... [ 16.132539] RTL871X: IW_SCAN_THIS_ESSID, ssid=Shadownetwork 2.4Ghz, len=20 [ 17.784899] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150 [ 20.187278] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f [ 20.221897] RTL871X: survey done event(4) band:0 for wlan0 [ 20.221912] RTL871X: rtw_indicate_scan_done(wlan0) [ 20.222346] RTL871X: wpa_set_auth_algs, AUTH_ALG_OPEN_SYSTEM [ 20.222354] RTL871X: set_mode = IW_MODE_INFRA [ 20.222381] RTL871X: [ 20.222382] wpa_ie(length:22): [ 20.222387] RTL871X: 0x30 0x14 0x01 0x00 0x00 0x0f 0xac 0x04 [ 20.222392] RTL871X: 0x01 0x00 0x00 0x0f 0xac 0x04 0x01 0x00 [ 20.222396] RTL871X: 0x00 0x0f 0xac 0x02 0x00 0x00 0x00 0x00 [ 20.222897] RTL871X: SetHwReg8812A, 5710, RCR= f40060ca [ 20.223019] RTL871X: rtw_wx_set_freq: set to channel 10 [ 20.223046] RTL871X: =>rtw_wx_set_essid [ 20.223050] RTL871X: ssid=Shadownetwork 2.4Ghz, len=20 [ 20.223059] RTL871X: set ssid [Shadownetwork 2.4Ghz] fw_state=0x00000008 [ 20.223063] RTL871X: Set SSID under fw_state=0x00000008 [ 20.223071] RTL871X: [by_bssid:0][assoc_ssid:Shadownetwork 2.4Ghz][to_roam:0] new candidate: Shadownetwork 2.4Ghz(08:60:6e:be:f2:60, ch10) rssi:-56 [ 20.223077] RTL871X: rtw_select_and_join_from_scanned_queue: candidate: Shadownetwork 2.4Ghz(08:60:6e:be:f2:60, ch:10) [ 20.223085] RTL871X: link to Broadcom AP [ 20.223092] RTL871X: [HT] HAL Support STBC = 0x01 [ 20.223096] RTL871X: [HT] Declare supporting RX STBC_2R [ 20.223101] RTL871X: [VHT] Support STBC = 0x03 [ 20.223105] RTL871X: [VHT] Support Beamformee [ 20.223111] RTL871X: <=rtw_wx_set_essid, ret 0 [ 20.223137] RTL871X: set bssid:08:60:6e:be:f2:60 [ 20.223140] RTL871X: Set BSSID under fw_state=0x00000088 [ 20.223290] RTL871X: hw_var_set_opmode()-4935 mode = 2 [ 20.223906] RTL871X: start_join_set_ch_bw: ch=10, bwmode=0, ch_offset=0 [ 20.463228] RTL871X: OnBeacon: beacon keys ready [ 20.463238] RTL871X: link to Broadcom AP [ 20.463242] RTL871X: start auth [ 20.463249] RTL871X: issue_auth [ 20.466074] RTL871X: OnAuthClient [ 20.466079] RTL871X: auth success, start assoc [ 20.466091] RTL871X: network.SupportedRates[0]=82 [ 20.466094] RTL871X: network.SupportedRates[1]=84 [ 20.466097] RTL871X: network.SupportedRates[2]=8B [ 20.466100] RTL871X: network.SupportedRates[3]=96 [ 20.466103] RTL871X: network.SupportedRates[4]=24 [ 20.466106] RTL871X: network.SupportedRates[5]=30 [ 20.466109] RTL871X: network.SupportedRates[6]=48 [ 20.466112] RTL871X: network.SupportedRates[7]=6C [ 20.466115] RTL871X: network.SupportedRates[8]=0C [ 20.466118] RTL871X: network.SupportedRates[9]=12 [ 20.466121] RTL871X: network.SupportedRates[10]=18 [ 20.466124] RTL871X: network.SupportedRates[11]=60 [ 20.466127] RTL871X: bssrate_len = 12 [ 20.470705] RTL871X: OnAssocRsp [ 20.470719] RTL871X: report_join_res(8) [ 20.470724] RTL871X: rtw_joinbss_update_network [ 20.470729] RTL871X: +rtw_update_ht_cap() [ 20.470741] RTL871X: rtw_alloc_macid(wlan0) if1, hwaddr:08:60:6e:be:f2:60 macid:0 [ 20.470745] RTL871X: rtw_joinbss_update_stainfo [ 20.470752] RTL871X: supp_mcs_set = ff, ff, 00, rf_type=2, tx_ra_bitmap=000000000fffffff [ 20.470756] RTL871X: ### Set STA_(0) info ### [ 20.470763] RTL871X: assoc success [ 20.471377] ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready [ 20.471522] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f [ 20.472523] RTL871X: WMM(0): 0, a42b [ 20.472644] RTL871X: WMM(1): 0, a44f [ 20.472949] RTL871X: WMM(2): 0, 5e4322 [ 20.473159] RTL871X: WMM(3): 0, 2f3222 [ 20.473164] RTL871X: wmm_para_seq(0): 0 [ 20.473167] RTL871X: wmm_para_seq(1): 1 [ 20.473170] RTL871X: wmm_para_seq(2): 2 [ 20.473173] RTL871X: wmm_para_seq(3): 3 [ 20.473176] RTL871X: HTOnAssocRsp [ 20.473271] RTL871X: VHTOnAssocRsp [ 20.473281] RTL871X: ODM_Get_Rate_Bitmap ==> rssi_level:0x00, WirelessMode:0x0b, rate_bitmap:0x0f8ff005 [ 20.473286] RTL871X: UpdateHalRAMask8812A => mac_id:0, networkType:0x0b, mask:0x0fffffff [ 20.473288] ==> rssi_level:0, rate_bitmap:0x0f8ff005, psta->raid=2 [ 20.474399] RTL871X: [MacId], Set MacId Ctrl(original) = 0x10000 [ 20.475521] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000 [ 20.476663] RTL871X: rtl8812_set_FwJoinBssReport_cmd mstatus(1) [ 20.477897] RTL871X: rtw_hal_set_fw_rsvd_page PageSize: 512, RsvdPageNUm: 7 [ 20.477906] RTL871X: LocPsPoll: 2 [ 20.477910] RTL871X: LocNullData: 3 [ 20.477914] RTL871X: LocQosNull: 4 [ 20.478144] RTL871X: rtw_hal_set_fw_rsvd_page: Set RSVD page location to Fw ,TotalPacketLen(2634), TotalPageNum(5) [ 20.478149] RTL871X: RsvdPageLoc: ProbeRsp=0 PsPoll=2 Null=3 QoSNull=4 BTNull=0 [ 20.478193] RTL871X: OnAction_back [ 20.478198] RTL871X: OnAction_back, action=0 [ 20.478213] RTL871X: issue_addba_rsp(wlan0) ra=08:60:6e:be:f2:60 status=0, tid=0, size=64 [ 20.479142] RTL871X: wlan0: 1 DL RSVD page success! DLBcnCount:1, poll:1 [ 20.479889] RTL871X: Set RSVD page location to Fw. [ 20.480049] RTL871X: =>mlmeext_joinbss_event_callback [ 20.480065] RTL871X: recv eapol packet [ 20.482167] RTL871X: send eapol packet [ 20.489207] RTL871X: recv eapol packet [ 20.489398] RTL871X: send eapol packet [ 20.489438] RTL871X: ~~~~set sta key:unicastkey [ 20.489543] RTL871X: ~~~~set sta key:groupkey [ 20.489549] RTL871X: ==> rtw_set_key algorithm(4),keyid(2),key_mask(0) [ 20.491467] RTL871X: set pairwise key camid:4, addr:08:60:6e:be:f2:60, kid:0, type:AES [ 20.494520] RTL871X: set group key camid:5, addr:08:60:6e:be:f2:60, kid:2, type:AES [ 20.497246] RTL871X: SetHwReg8812A, 5703, RCR= f40060ce [ 21.116584] eth0: no IPv6 routers present [ 22.232653] RTL871X: ODM_Get_Rate_Bitmap ==> rssi_level:0x02, WirelessMode:0x0b, rate_bitmap:0x0f8ff000 [ 22.232660] RTL871X: UpdateHalRAMask8812A => mac_id:0, networkType:0x0b, mask:0x0fffffff [ 22.232662] ==> rssi_level:2, rate_bitmap:0x0f8ff000, psta->raid=2 [ 24.067077] RTL871X: rtw_issue_addbareq_cmd, p=0 [ 24.067127] RTL871X: BA_starting_seqctrl = 132 for TID=0 [ 24.067162] RTL871X: issue_addba_req(wlan0) ra=08:60:6e:be:f2:60 tid=0 [ 24.074885] RTL871X: OnAction_back [ 24.074892] RTL871X: OnAction_back, action=1 [ 24.074895] RTL871X: agg_enable for TID=0 [ 31.336861] wlan0: no IPv6 routers present [ 32.155614] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_SLEEP] macid=0, org reg_0x4d4=0x00000000 [ 33.906285] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150 [ 34.258287] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f [ 34.290907] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150 [ 36.265905] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f [ 36.298663] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150 [ 36.366913] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f [ 36.402663] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000001 [ 36.405035] RTL871X: survey done event(7) band:0 for wlan0 [ 36.405129] RTL871X: rtw_indicate_scan_done(wlan0) [ 44.273706] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE [ 44.277343] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0 [ 48.281772] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY [ 48.281785] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0 [ 50.285847] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE [ 50.285861] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0 [ 72.155200] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-LPS_CTRL_LEAVE [ 72.155214] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0 [ 72.157541] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_SLEEP] macid=0, org reg_0x4d4=0x00000000 [ 73.937660] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150 [ 74.352037] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f [ 74.386037] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150 [ 76.340662] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f [ 76.376042] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000001 [ 76.383285] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150 [ 76.415535] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f [ 76.449161] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000 [ 76.451158] RTL871X: survey done event(4) band:0 for wlan0 [ 76.451268] RTL871X: rtw_indicate_scan_done(wlan0) [ 80.345576] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE [ 80.345590] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0 [ 84.353046] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY [ 84.353059] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0 [ 88.363392] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE [ 88.363407] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0 [ 89.981873] ip_tables: (C) 2000-2006 Netfilter Core Team [ 132.154779] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-LPS_CTRL_LEAVE [ 132.154793] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0 [ 132.159947] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_SLEEP] macid=0, org reg_0x4d4=0x00000000 [ 133.948028] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150 [ 134.474907] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f [ 134.507779] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150 [ 136.315153] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f [ 136.348900] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000001 [ 136.351152] RTL871X: survey done event(2) band:0 for wlan0 [ 136.351207] RTL871X: rtw_indicate_scan_done(wlan0) [ 136.456789] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE [ 136.456798] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0 [ 140.469772] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY [ 140.469786] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0 [ 142.475051] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE [ 142.475065] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0 [ 166.521958] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000 [ 174.537878] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY [ 174.537891] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0 [ 178.547644] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE [ 178.547658] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0 [ 180.549550] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY [ 180.549564] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0 [ 182.554492] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE [ 182.554506] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0 [ 198.586169] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000 [ 212.157511] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-LPS_CTRL_LEAVE [ 212.157525] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0 [ 212.160543] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_SLEEP] macid=0, org reg_0x4d4=0x00000000 [ 213.903161] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150 [ 214.620540] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f [ 214.653158] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150 [ 216.353659] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f [ 216.387160] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000001 [ 216.389660] RTL871X: survey done event(4) band:0 for wlan0 [ 216.389721] RTL871X: rtw_indicate_scan_done(wlan0) [ 216.624122] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000 [ 216.628649] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE [ 216.628661] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0 [ 232.654020] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000 [ 238.697044] RTL871X: issue_probereq_ex(wlan0) to 08:60:6e:be:f2:60, ch:10, 3/3 in 32 ms [ 238.697218] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000 [ 252.718816] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000 [ 254.717721] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000 [ 256.721041] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000 [ 258.732702] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000 [ 259.468476] RTL871X: not match packet_index=1, install_index=2 [ 259.532793] RTL871X: recv eapol packet [ 259.533168] RTL871X: ~~~~set sta key:groupkey [ 259.533180] RTL871X: ==> rtw_set_key algorithm(4),keyid(1),key_mask(0) [ 259.533250] RTL871X: send eapol packet [ 259.536657] RTL871X: set group key camid:6, addr:08:60:6e:be:f2:60, kid:1, type:AES [ 259.537251] RTL871X: SetHwReg8812A, 5703, RCR= f40760ce [ 260.391192] RTL871X: OnDeAuth(wlan0) reason=16, ta=08:60:6e:be:f2:60, ignore=0 [ 260.391201] RTL871X: receive_disconnect [ 260.391213] RTL871X: report_del_sta_event: delete STA, mac_id=0 [ 260.391308] RTL871X: rtw_stadel_event_callback(mac_id=0)=08:60:6e:be:f2:60 [ 260.391318] RTL871X: [MacId], Set MacId Ctrl(original) = 0x0 [ 260.393993] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000 [ 260.397827] RTL871X: ### Clean STA_(0) info ### [ 260.397839] RTL871X: free disconnecting network [ 260.397857] RTL871X: indicate disassoc [ 260.397916] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-LPS_CTRL_DISCONNECT [ 260.397925] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0 [ 260.399405] RTL871X: rtl8812_set_FwJoinBssReport_cmd mstatus(0) [ 260.399418] RTL871X: beamforming_deinit_entry Idx 0 [ 260.399426] RTL871X: beamforming_notify BeamformState 0 bSounding 0 [ 262.229535] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150 [ 264.671785] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f [ 264.705784] RTL871X: survey done event(2) band:0 for wlan0 [ 264.705804] RTL871X: rtw_indicate_scan_done(wlan0) [ 264.706436] RTL871X: wpa_set_auth_algs, AUTH_ALG_OPEN_SYSTEM [ 264.706450] RTL871X: set_mode = IW_MODE_INFRA [ 264.706490] RTL871X: [ 264.706492] wpa_ie(length:22): [ 264.706500] RTL871X: 0x30 0x14 0x01 0x00 0x00 0x0f 0xac 0x04 [ 264.706507] RTL871X: 0x01 0x00 0x00 0x0f 0xac 0x04 0x01 0x00 [ 264.706514] RTL871X: 0x00 0x0f 0xac 0x02 0x00 0x00 0x00 0x00 [ 264.707539] RTL871X: SetHwReg8812A, 5710, RCR= f40060ca [ 264.707700] RTL871X: hw_var_set_opmode()-4935 mode = 2 [ 264.707723] RTL871X: rtw_wx_set_freq: set to channel 10 [ 264.707755] RTL871X: =>rtw_wx_set_essid [ 264.707762] RTL871X: ssid=Shadownetwork 2.4Ghz, len=20 [ 264.707776] RTL871X: set ssid [Shadownetwork 2.4Ghz] fw_state=0x00000008 [ 264.707782] RTL871X: Set SSID under fw_state=0x00000008 [ 264.707795] RTL871X: [by_bssid:0][assoc_ssid:Shadownetwork 2.4Ghz][to_roam:0] new candidate: Shadownetwork 2.4Ghz(08:60:6e:be:f2:60, ch10) rssi:-58 [ 264.707805] RTL871X: rtw_select_and_join_from_scanned_queue: candidate: Shadownetwork 2.4Ghz(08:60:6e:be:f2:60, ch:10) [ 264.707818] RTL871X: link to Broadcom AP [ 264.707827] RTL871X: [HT] HAL Support STBC = 0x01 [ 264.707834] RTL871X: [HT] Declare supporting RX STBC_2R [ 264.707841] RTL871X: [VHT] Support STBC = 0x03 [ 264.707846] RTL871X: [VHT] Support Beamformee [ 264.707857] RTL871X: <=rtw_wx_set_essid, ret 0 [ 264.707899] RTL871X: set bssid:08:60:6e:be:f2:60 [ 264.707906] RTL871X: Set BSSID under fw_state=0x00000088 [ 264.708562] RTL871X: start_join_set_ch_bw: ch=10, bwmode=0, ch_offset=0 [ 265.098741] RTL871X: OnBeacon: beacon keys ready [ 265.098760] RTL871X: link to Broadcom AP [ 265.098768] RTL871X: start auth [ 265.098778] RTL871X: issue_auth [ 265.102008] RTL871X: OnAuthClient [ 265.102016] RTL871X: auth success, start assoc [ 265.102030] RTL871X: network.SupportedRates[0]=82 [ 265.102036] RTL871X: network.SupportedRates[1]=84 [ 265.102041] RTL871X: network.SupportedRates[2]=8B [ 265.102047] RTL871X: network.SupportedRates[3]=96 [ 265.102052] RTL871X: network.SupportedRates[4]=24 [ 265.102058] RTL871X: network.SupportedRates[5]=30 [ 265.102063] RTL871X: network.SupportedRates[6]=48 [ 265.102069] RTL871X: network.SupportedRates[7]=6C [ 265.102074] RTL871X: network.SupportedRates[8]=0C [ 265.102080] RTL871X: network.SupportedRates[9]=12 [ 265.102085] RTL871X: network.SupportedRates[10]=18 [ 265.102091] RTL871X: network.SupportedRates[11]=60 [ 265.102097] RTL871X: bssrate_len = 12 [ 265.103754] RTL871X: OnAuthClient [ 265.106385] RTL871X: OnAuthClient [ 265.114637] RTL871X: OnAssocRsp [ 265.114655] RTL871X: report_join_res(8) [ 265.114664] RTL871X: rtw_joinbss_update_network [ 265.114672] RTL871X: +rtw_update_ht_cap() [ 265.114690] RTL871X: rtw_alloc_macid(wlan0) if1, hwaddr:08:60:6e:be:f2:60 macid:0 [ 265.114696] RTL871X: rtw_joinbss_update_stainfo [ 265.114732] RTL871X: supp_mcs_set = ff, ff, 00, rf_type=2, tx_ra_bitmap=000000000fffffff [ 265.114740] RTL871X: ### Set STA_(0) info ### [ 265.114751] RTL871X: assoc success [ 265.114813] RTL871X: OnAction_back [ 265.114820] RTL871X: OnAction_back, action=0 [ 265.114842] RTL871X: issue_addba_rsp(wlan0) ra=08:60:6e:be:f2:60 status=0, tid=0, size=64 [ 265.114868] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f [ 265.115899] RTL871X: WMM(0): 0, a42b [ 265.116021] RTL871X: WMM(1): 0, a44f [ 265.116153] RTL871X: WMM(2): 0, 5e4322 [ 265.116791] RTL871X: WMM(3): 0, 2f3222 [ 265.116799] RTL871X: wmm_para_seq(0): 0 [ 265.116805] RTL871X: wmm_para_seq(1): 1 [ 265.116811] RTL871X: wmm_para_seq(2): 2 [ 265.116819] RTL871X: wmm_para_seq(3): 3 [ 265.116825] RTL871X: HTOnAssocRsp [ 265.117153] RTL871X: VHTOnAssocRsp [ 265.117168] RTL871X: ODM_Get_Rate_Bitmap ==> rssi_level:0x00, WirelessMode:0x0b, rate_bitmap:0x0f8ff005 [ 265.117178] RTL871X: UpdateHalRAMask8812A => mac_id:0, networkType:0x0b, mask:0x0fffffff [ 265.117181] ==> rssi_level:0, rate_bitmap:0x0f8ff005, psta->raid=2 [ 265.120114] RTL871X: [MacId], Set MacId Ctrl(original) = 0x10000 [ 265.121660] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000 [ 265.123156] RTL871X: rtl8812_set_FwJoinBssReport_cmd mstatus(1) [ 265.124280] RTL871X: rtw_hal_set_fw_rsvd_page PageSize: 512, RsvdPageNUm: 7 [ 265.124292] RTL871X: LocPsPoll: 2 [ 265.124298] RTL871X: LocNullData: 3 [ 265.124304] RTL871X: LocQosNull: 4 [ 265.124531] RTL871X: rtw_hal_set_fw_rsvd_page: Set RSVD page location to Fw ,TotalPacketLen(2634), TotalPageNum(5) [ 265.124542] RTL871X: RsvdPageLoc: ProbeRsp=0 PsPoll=2 Null=3 QoSNull=4 BTNull=0 [ 265.125532] RTL871X: wlan0: 1 DL RSVD page success! DLBcnCount:1, poll:1 [ 265.126278] RTL871X: Set RSVD page location to Fw. [ 265.126403] RTL871X: =>mlmeext_joinbss_event_callback [ 265.130080] RTL871X: recv eapol packet [ 265.132541] RTL871X: send eapol packet [ 265.150708] RTL871X: recv eapol packet [ 265.150939] RTL871X: send eapol packet [ 265.150993] RTL871X: ~~~~set sta key:unicastkey [ 265.151072] RTL871X: set pairwise key camid:4, addr:08:60:6e:be:f2:60, kid:0, type:AES [ 265.151140] RTL871X: ~~~~set sta key:groupkey [ 265.151150] RTL871X: ==> rtw_set_key algorithm(4),keyid(1),key_mask(0) [ 265.154660] RTL871X: set group key camid:5, addr:08:60:6e:be:f2:60, kid:1, type:AES [ 265.155026] RTL871X: SetHwReg8812A, 5703, RCR= f40060ce [ 266.716533] RTL871X: ODM_Get_Rate_Bitmap ==> rssi_level:0x02, WirelessMode:0x0b, rate_bitmap:0x0f8ff000 [ 266.716541] RTL871X: UpdateHalRAMask8812A => mac_id:0, networkType:0x0b, mask:0x0fffffff [ 266.716543] ==> rssi_level:2, rate_bitmap:0x0f8ff000, psta->raid=2 [ 274.728978] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE [ 274.728992] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0 [ 284.750474] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY [ 284.750483] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0 [ 288.757273] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE [ 288.757287] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0 [ 292.765919] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY [ 292.765933] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0 [ 298.777930] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE [ 298.777945] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0 [ 300.781237] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY [ 300.781251] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0 [ 304.790004] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE [ 304.790019] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0 [ 308.828453] RTL871X: issue_probereq_ex(wlan0) to 08:60:6e:be:f2:60, ch:10, 3/3 in 32 ms [ 308.828831] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000 [ 312.153530] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-LPS_CTRL_LEAVE [ 312.153540] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0 [ 312.158146] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_SLEEP] macid=0, org reg_0x4d4=0x00000000 [ 313.984660] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150 [ 314.814035] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f [ 314.848034] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150 [ 316.403534] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f [ 316.438399] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000001 [ 316.440902] RTL871X: survey done event(1) band:0 for wlan0 [ 316.440951] RTL871X: rtw_indicate_scan_done(wlan0) [ 316.813099] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE [ 316.813116] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0 [ 336.853989] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000 [ 352.886160] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000 [ 368.918123] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000 [ 384.950276] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000 [ 400.982142] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000 [ 417.014125] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000 [ 432.155154] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-LPS_CTRL_LEAVE [ 432.155167] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0 [ 432.161422] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_SLEEP] macid=0, org reg_0x4d4=0x00000000 [ 433.881288] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150 [ 435.056659] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f [ 435.089282] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150 [ 436.292907] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f [ 436.326783] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000001 [ 436.328911] RTL871X: survey done event(4) band:0 for wlan0 [ 436.328931] RTL871X: rtw_indicate_scan_done(wlan0) [ 437.053428] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE [ 437.053442] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0 [ 447.074034] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000 [ 463.106107] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000 [ 479.138422] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000 [ 495.173854] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000 [ 511.206080] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000 [ 551.286462] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000 [ 552.155139] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-LPS_CTRL_LEAVE [ 552.155153] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0 [ 552.157811] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_SLEEP] macid=0, org reg_0x4d4=0x00000000 [ 553.881284] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150 [ 555.308910] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f [ 555.341533] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150 [ 556.285032] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f [ 556.318787] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000001 [ 556.321410] RTL871X: survey done event(8) band:0 for wlan0 [ 556.321431] RTL871X: rtw_indicate_scan_done(wlan0) [ 557.297796] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE [ 557.297810] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0 [ 567.317590] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000 [ 583.350096] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000 [ 599.382104] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000 [ 615.414192] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000 [ 647.478216] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000 [ 663.644885] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-LPS_CTRL_LEAVE [ 663.644900] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0 [ 665.513799] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE [ 665.513813] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0 [ 672.153352] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-LPS_CTRL_LEAVE [ 672.153365] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0 [ 672.156360] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_SLEEP] macid=0, org reg_0x4d4=0x00000000 [ 673.876293] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150 [ 675.558413] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f [ 675.590162] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000001 [ 675.597410] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150 [ 676.292163] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f [ 676.325660] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000 [ 676.327659] RTL871X: survey done event(6) band:0 for wlan0 [ 676.327679] RTL871X: rtw_indicate_scan_done(wlan0) [ 677.537660] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE [ 677.537675] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0 [ 691.566095] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000 [ 707.597968] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000 [ 723.630047] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000 [ 745.674005] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000 [ 761.706024] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000 [ 777.738214] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000 [ 792.154195] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-LPS_CTRL_LEAVE [ 792.154208] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0 [ 792.156437] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_SLEEP] macid=0, org reg_0x4d4=0x00000000 [ 793.803914] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000001 [ 793.876663] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150 [ 795.776665] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f [ 795.809410] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150 [ 796.349039] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f [ 796.382536] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000 [ 796.384912] RTL871X: survey done event(6) band:0 for wlan0 [ 796.384932] RTL871X: rtw_indicate_scan_done(wlan0) [ 797.777644] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE [ 797.777658] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0 [ 809.801980] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000 [ 825.833866] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000 [ 847.878017] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000 [ 863.909839] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000 [ 879.942169] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000 [ 895.974088] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000 [ 912.005952] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000 [ 912.154731] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-LPS_CTRL_LEAVE [ 912.154743] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0 [ 912.158325] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_SLEEP] macid=0, org reg_0x4d4=0x00000000 [ 913.276694] RTL871X: Drop duplicate management frame with seq_num = 1187. [ 913.280444] RTL871X: Drop duplicate management frame with seq_num = 1187. [ 913.876179] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150 [ 914.031913] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f [ 914.064535] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150 [ 916.017040] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f [ 916.049911] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150 [ 916.337539] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f [ 916.371410] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000001 [ 916.373537] RTL871X: survey done event(8) band:0 for wlan0 [ 916.373558] RTL871X: rtw_indicate_scan_done(wlan0) [ 918.017645] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE [ 918.017659] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0 [ 928.037793] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000 [ 946.073667] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000 [ 962.106371] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000 [ 978.138020] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000 [ 994.169843] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000 [ 1010.201655] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000 [ 1026.233694] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000 [ 1032.154563] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-LPS_CTRL_LEAVE [ 1032.154576] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0 [ 1032.158704] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_SLEEP] macid=0, org reg_0x4d4=0x00000000 [ 1033.884535] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150 [ 1034.252411] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f [ 1034.285287] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150 [ 1036.255161] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f [ 1036.287038] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000001 [ 1036.294282] RTL871X: HW_VAR_BASIC_RATE: 0x150 -> 0x150 -> 0x150 [ 1036.352410] RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f [ 1036.385911] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000 [ 1036.388157] RTL871X: survey done event(9) band:0 for wlan0 [ 1036.388178] RTL871X: rtw_indicate_scan_done(wlan0) [ 1038.257877] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE [ 1038.257892] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0 [ 1050.280669] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY [ 1050.280682] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0 [ 1052.038641] RTL871X: rtw_issue_addbareq_cmd, p=0 [ 1052.038739] RTL871X: BA_starting_seqctrl = 319 for TID=0 [ 1052.038769] RTL871X: issue_addba_req(wlan0) ra=08:60:6e:be:f2:60 tid=0 [ 1052.042076] RTL871X: OnAction_back [ 1052.042086] RTL871X: OnAction_back, action=1 [ 1052.042092] RTL871X: agg_enable for TID=0 [ 1056.293459] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE [ 1056.293474] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0 [ 1058.296643] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY [ 1058.296652] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0 [ 1062.305361] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE [ 1062.305375] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0 [ 1064.308611] RTL871X: rtw_set_ps_mode(wlan0) Leave 802.11 power save - WIFI-TRAFFIC_BUSY [ 1064.308625] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=0 SmartPS=2 UAPSD=0 [ 1066.313499] RTL871X: rtw_set_ps_mode(wlan0) Enter 802.11 power save - WIFI-TRAFFIC_IDLE [ 1066.313514] RTL871X: rtl8812_set_FwPwrMode_cmd: Mode=1 SmartPS=2 UAPSD=0 [ 1082.345711] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000 [ 1098.377733] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000 [ 1114.410176] RTL871X: SetHwReg8812A(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x4d4=0x00000000
Br Victor
8 years 1 day ago #119664 by andypugh
Replied by andypugh on topic G76, Troubleshooting needed!
Turn twopass off. And have only _one_ loadrt lowpass in the main HAL file. (both names on the same line, ie
loadrt lowpass names=lowpass.spindle,lowpass.0
The following user(s) said Thank You: Victor
Time to create page: 0.154 seconds
