REMAP M6 FOR GENEVA ATC
7 years 11 months ago #119818 by andypugh
Replied by andypugh on topic REMAP M6 FOR GENEVA ATC
Why are you using "carousel"?
The fragment of G-code I gave you a number of posts back does all that carousel is doing in this case, and it should store the carousel position too.
7 years 11 months ago #119819 by COlger81
Replied by COlger81 on topic REMAP M6 FOR GENEVA ATC
Using carousel component seemed like a nice and clean approach. It has everything i need built in, such as turret jogging and bidirectional mode. It works like a charm other than not saving and recalling the selected pocket. What is the benefit of not using the carousel?
7 years 11 months ago #119820 by andypugh
I admit I had forgotten about the jogging, if that is useful then carousel might be useful.
I normally think of "carousel" being mainly about decoding various types of carousel position encoders. (I wrote "carousel" but have never had a machine that needed it)
What I would suggest you do is to save the position from G-code after every tool change into a persistent variable (such as #5490). Then you need to subtract the number stored in #5490 from the required pocket position before sending it out to the carousel component. (In effect #5490 becomes a "home offset" for the carousel.)
I can think of neater ways, but most of those involve modifications to "carousel"
The following user(s) said Thank You: akb1212
7 years 11 months ago #119823 by COlger81
Where can i find the carousel source code?
7 years 11 months ago #119825 by andypugh
7 years 11 months ago #119827 by COlger81
I'm definitely not scared of diving in and learning some code but by chance is there a line or 2 i could add to pull value from #5400 parameter (current tool) at startup?
Time to create page: 0.734 seconds
