REMAP M6 FOR GENEVA ATC
8 years 5 days ago #119496
Replied by andypugh on topic REMAP M6 FOR GENEVA ATC
I seem to say this a lot, but take a look at the sim/axis/vismach/VMC_toolchange configs. (You can run this on your current machine, it won't touch hardware, but has a 3D model of the machine).
I think that all you need is probably in there.
- COlger81
- Thank you received: 6
8 years 3 days ago #119602
by COlger81
Replied by COlger81 on topic REMAP M6 FOR GENEVA ATC
I have the bulk of my ATC process done but i'm struggling with applying the carousel component "counter" to my changer. I have a fadal random 21 pocket changer. The sensor for counting tools is a single hall sensor connected to a BIT "true or false" input with magnets half way between each pocket.
8 years 2 days ago #119612
Is there an additional home sensor so that the machine knows where pin 1 is?
How did the original system know when to turn off the motor if the sensor is between positions?
- COlger81
8 years 2 days ago #119613
by COlger81
It does not have a home sensor on the turret. There's a detent at each pocket, the motor is shutoff at the halfway point when the magnets hit the sensor, the turret glides the other half and is grabbed by detent.
8 years 2 days ago #119614
So how does it know when it is at position 1?
(And what is the exact problem that you have?)
- COlger81
8 years 2 days ago #119615
by COlger81
I was able to use "updown" hal component to create tool counter. It seems to be working well. My thought is to export the saved current tool on startup to the "updown" turret value.
Time to create page: 0.269 seconds
