- GCode and Part Programs
- G&M Codes
- Anyone with succesful Rack Type Tool Changer with Auto Tool length probe ?
03 May 2020 11:35 #166503
This is automatic with the standard M6, the tool-change - tool-changed handshake is skipped.
So whether you actually need to do anything depends on how the toolchange is being handled.
Is this handled by a mechanical stop or by encoder?
Replied by andypugh on topic Anyone with succesful Rack Type Tool Changer with Auto Tool length probe ?
1. how to do new tool = current tool ignore tool replacement.
2. my machine requires tool orientation
- aluplastvz
- Thank you received: 9
03 May 2020 12:27 #166504
by aluplastvz
Replied by aluplastvz on topic Anyone with succesful Rack Type Tool Changer with Auto Tool length probe ?
Sorry for the lost translation
My machine has 10 + 10 tools set to Y0 10 tools and Y4100 10 tools
i have sensor in atc and encoder
My problem with the code is when I restart
program from the beginning and if I worked with T1
the machine again goes into position T1 leave the tool and then take it again
thanks for the bry response
- aluplastvz
03 May 2020 13:27 #166506
by aluplastvz
03 May 2020 13:43 #166507
It is hard to speculate about what needs to change without knowing how your system is controlled.
It can't be identical to sim/axis/remap/rack-toolchange as that has no measurement phase.
Do you have this file: github.com/LinuxCNC/linuxcnc/blob/master...ines/rack_change.ngc
Maybe change it to
Maybe change it to
o<rack_change> sub
M73 (auto-restore modal settings on return)
O111 IF [#<_current_tool> EQ #<_selected_tool>]
O<rack_change> RETURN [1]
O111 ENDIF
;(print, rack_change: loaded tool=#<_current_tool> current pocket: #<_current_pocket>)
;(print, rack_change: selected tool=#<_selected_tool> selected pocket: #<_selected_pocket>)
The following user(s) said Thank You: aluplastvz, tommylight
- aluplastvz
03 May 2020 14:32 #166509
by aluplastvz
Thank you Andy is doing it well.
I used a github link
Hello also for Pec.
Hello also for Pec.
- udoS
- Thank you received: 25
23 Nov 2023 12:24 #286325
by udoS
Replied by udoS on topic Anyone with succesful Rack Type Tool Changer with Auto Tool length probe ?
@aluplastvz
what git did you use ?
L.G. udoS
L.G. udoS
- aluplastvz
11 Jun 2025 21:15 #330175
by aluplastvz
I get this error when the same tool is in the machine and I start the program. If I use another tool, the machine normally changes and measures the height of the tool.
anyone have any idea what the problem isOperator Error : Operator Error : M6 / change epilog : Python argument types in emccanon.CHANGE_TOOL ( ) did not match C ++ signature : CHANGE_TOOL ( int )
- SebastianM
- Thank you received: 3
18 Jul 2025 03:56 #331970
by SebastianM
Replied by SebastianM on topic Anyone with succesful Rack Type Tool Changer with Auto Tool length probe ?
Not sure if this still is relevant, but I have a rack type ATC with probe basic and tool-touch-off.
Regards !!
Regards !!
- aluplastvz
28 Jul 2025 09:12 #332462
by aluplastvz
Hello Sebastjan, I haven't completely solved the problem yet, do you have the code?
How do you send it?
How do you send it?
- G&M Codes
