- Thank you received: 37
Axis Modifications
- D.L.
4 years 8 months ago #234792
by D.L.
Replied by D.L. on topic Axis Modifications
If you only need to display the angle value, without any processing, replace in glcanon.py:
posstrs.append(angformat % ("a", math.fmod(hal.get_value("axisui.display-spindle-angle"),1.0)*360.0))
to
posstrs.append(angformat % ("a", hal.get_value("axisui.display-spindle-angle")))
The following user(s) said Thank You: Arbiwei
- Arbiwei
4 years 8 months ago #234793
by Arbiwei
Replied by Arbiwei on topic Axis Modifications
Many Thanks. We'll see when I get to it
3 children there's always something going on.
- D.L.
4 years 8 months ago #234965
by D.L.
The following user(s) said Thank You: zack, radom
- D.L.
4 years 28 minutes ago #255662
by D.L.
LinuxCNC 2.8.4 with Axis mod and Mesa driver from 2.9:
github.com/ddotldot/linuxcnc/tree/2.8-ax...-updated-mesa-driver
- jpa
- Thank you received: 10
3 years 9 months ago #262759
by jpa
Replied by jpa on topic Axis Modifications - Remaining time
Here is a snippet to add G-code progress & remaining time estimate to the Axis status bar:
github.com/HacklabJKL/sergei_cnc2/commit...7983c7956d92219af00f
Like the estimate in File -> Properties this does not take acceleration into account, so it will typically estimate a bit shorter time and run negative at the end of the G-code. It does take into account the current feedrate overrides, and updates in real time even if they are changed in the middle of the job.
The following user(s) said Thank You: tommylight, aparecido, RobC, Arbiwei, hmnijp
- Arbiwei
3 years 9 months ago #262772
by Arbiwei
Replied by Arbiwei on topic Axis Modifications - Remaining time
Nice Feature
Time to create page: 0.578 seconds
