Axis Modifications
7 years 1 month ago #144799
The same error?
Can you paste the terminal output while trying to jog from the Axis GUI do you see:
Replied by andypugh on topic Axis Modifications
pl7i92 wrote: this also happens in 2.9 master
The same error?
Exception in Tkinter callback
File "/usr/lib/python2.7/lib-tk/Tkinter.py", line 1545, in call
return self.func(*args)
File "/home/andypugh/linuxcnc-dev/bin/axis", line 2337, in jog_plus
a = "xyzabcuvw".index(a)
ValueError: substring not found
- probotix
6 years 2 weeks ago #186026
by probotix
Replied by probotix on topic Axis Modifications
Hope its okay to put this on this thread. I am trying to clear the live plotter after the machine is finished homing, but it appears that wait_complete() is not obeyed during homing. I use print statement to prove it.
Any ideas?
Any ideas?
- zack
- Thank you received: 47
5 years 6 months ago - 5 years 6 months ago #206096
by zack
Replied by zack on topic Axis Modifications
the def has completed once it tells the op to home
check ishomed : then clear_liveplot()
set a flag the first time as the interpreter will always report ishomed on updates
Last edit: 5 years 6 months ago by zack.
- D.L.
- Thank you received: 37
4 years 11 months ago #226595
by D.L.
Replied by D.L. on topic Axis Modifications
Axis mod: Spindle speed, cutting speed, feed per tooth|feed per rev, spindle angle in Axis display.
n: spindle speed
Vc: cutting speed
Fz: feed per tooth(for mill)
Fn: feed per rev(for lathe)
a: spindle angle
Hal connection:
=> motion.analog-in-00 (spindle speed, rpm, commanded or from encoder)
=> motion.analog-in-01 (spindle angle, 1.0 = 360deg, pos from encoder)
For storage tool tooth used Q-var in tool table(only for mill, not affected lathe version).
Files for 2.7.15:
Files for 2.8.2:
n: spindle speed
Vc: cutting speed
a: spindle angle
Hal connection:
Files for 2.7.15:
Files for 2.8.2:
The following user(s) said Thank You: BigJohnT, andypugh, arvidb, tommylight, besriworld, cakeslob
4 years 11 months ago #226793
I like that. In fact I can see an argument for it being a built-in.
In the same way as you get a feel for surface speed on a lathe, you can got a feel for chip load on your mill.
The following user(s) said Thank You: fully_defined
- D.L.
4 years 11 months ago #226856
by D.L.
Added correctly calculation of cutting speed for inch units display mode.
For inch display mode cutting speed in surface feet per minute (SFM) units.
For mm display mode cutting speed in surface meters per minute (SMM) units.
Files for 2.7.15:
Files for 2.8.2:
Files for 2.7.15:
Files for 2.8.2:
Time to create page: 0.272 seconds
