Axis Modifications
9 years 1 month ago - 9 years 1 month ago #99336 by clunc
Replied by clunc on topic Axis Modifications
I would like to know which user coordinate system (UCS) is in effect at a glance from the F3 window without having to parse it out of a list of all other G-code states.
Has anyone done this? Thank you.
Originally, I thought I might have a separate 'linuxcnctop' window open, but it too requires the UCS 'G5n' to be fished out of a list of 'g-codes.'
Last edit: 9 years 1 month ago by clunc.
9 years 1 month ago #99340 by clunc
"How hard would it be" :^) to change the color of the Live Plot from red (in my case) to "transparent?"
That way I could still see progress as lines disappeared, but also have a clearer view of the remaining work to be done.
Thank you.
9 years 4 weeks ago #99819 by andypugh
Replied by andypugh on topic Axis Modifications
I think that the drawing happens in glcanon.py, so you could try changing colours there.
github.com/LinuxCNC/linuxcnc/blob/master...hon/rs274/glcanon.py
7 years 6 months ago #130722 by pl7i92
Replied by pl7i92 on topic Axis Modifications
@cuno
you can use AXIS Alpha Blending in the menue under View
7 years 1 month ago #144749 by andypugh
In version 2.7.14, using the Stretch Linux distro, Axis can not jog joint 1 of a non-trivkins machine in Joint mode.
This is due to the value "y" in Tk being converted to the string "True" in Python....
A solution is to put the following in a .axisrc file:
widgets.axis_c.configure(value="c") widgets.joint_1.configure(value="y") widgets.joint_5.configure(value="c")
(There is some evidence of a similar problem with "c" and that is even harder to understand. All this code does is give the button data the values that it ought to have been given in the Tcl file.
7 years 1 month ago #144787 by pl7i92
this also happens in 2.9 master
as i got a XYZAC setup joint_0 - Joint_4 but joint_5 is C while jopint 4 is B internal
it is the same as on AXIS = ((0-X 1-Y 2-Z 3-A 4-B 5-C 6-U 7-V 8-W)
joints Number Axis letter
AXIS = Virtual Count starting 1 Semireal+1
Joints = real joints count so 5 for XYZAC not the 6 UPGREATERS woudt guess
this is a issue New Users wont come up with
and it somtiomes complains B axis following error while B isent in any config at all
then if you use MESA with hardware stepgens you come up with stepgen numbers to ports as well
somtimes i need a real smooth time to overcome this in manuelll setup <- Non pncconf user
Time to create page: 1.100 seconds
