- Thank you received: 2181
Axis Modifications
I personally don't think having spindle stats in EMC Stat is the way to go.
You can read spindle HAL pins directly in python - a much more flexible way.
- cakeslob
- Thank you received: 280
Have you tested other screens? glcannon is used in other screens.
yeah i wasnt sure why that was needed either,I agree, as i just connect mine to spindle.0.speed-out, and other existing motion pins
- D.L.
- Thank you received: 37
Only gmoccapy, mod does not affect it.cmorley post=227695 userid=482
How to read encoder position(for display spindle angle) hal pin directly in python, without python interface?
Need example.
It is necessary to transfer speed and angle values to the python interface.cakeslob post=227713 userid=25269
Signal source will select the user in the hal file(e.g. spindle.N.speed-out-abs => motion.spindle-display-speed or from spindle encoder).
I think this(dedicated hal pins) is a more flexible solution.
About another way i know: use speed(commanded, not real) from spindle dictionary and spindle num(select spindle to display speed) from ini file.
- cakeslob
- cakeslob
Axis loads the most recent file opened on startup, so what ever you closed with, it opens with.
Add one of these to your usercommand file or axisrc and under [DISPLAY] in ini, add
LOAD_LASTFILE = YES
- D.L.
