Probe panel for Axis GUI
06 Aug 2024 11:38 #307073 by juliankoenig87
Replied by juliankoenig87 on topic Probe panel for Axis GUI
Maybe another line ending story?
Did you copy it with a windows machine or something like that?
I would type the VEL_FAST... separately with the keyboard. Just in case...
06 Aug 2024 11:58 #307074 by Aciera
Replied by Aciera on topic Probe panel for Axis GUI
I notice that there are inline-comments_
VEL_FAST = 5    [200 was the original value]
I know it has already been suggested to use '#' instead. IIRC there should not be any inline comments in the ini file.
So maybe try:
VEL_FAST = 5
If that works for VEL_FAST then do the same with all the inline comments.
06 Aug 2024 12:17 #307075 by juliankoenig87
Ah. You are right..He did not mentioned that he deleted the "[...]".
06 Aug 2024 12:47 #307079 by TucsonSean
Replied by TucsonSean on topic Probe panel for Axis GUI
I have tried using other commands, find center, find edge, etc... and I get the same error message: Named Parameter #<_ini[probe]vel_fast> not defined
Is there a difference with version 2.8.4 for declaring variables in the ini file versus newer 2.9 versions?
-Sean
06 Aug 2024 12:48 #307080 by Aciera
can you please post your current hal and ini files?
06 Aug 2024 12:59 #307081 by TucsonSean
IT WORKS!
I deleted the offending lines of text (supposed to be comments but I forgot the # ) from the ini file and it worked. My mill is calibrating my probe as I type this.
Thank you for your assistance in getting this working. Really appreciate the help.
-Sean
  • Moderator
  • Moderator
06 Aug 2024 13:00 #307082 by tommylight
Replied by tommylight on topic Probe panel for Axis GUI
[EMC]
MACHINE = MAZAK_Micro_Slant_15
DEBUG = 0
VERSION = 1.1
[DISPLAY]
DISPLAY = axis
POSITION_OFFSET = RELATIVE
POSITION_FEEDBACK = ACTUAL
MAX_FEED_OVERRIDE = 2.000000
Square brackets are used to separate sections of the ini file so they can not be used as comments.
# <<< this should be OK, most probably
The following user(s) said Thank You: TucsonSean
06 Aug 2024 13:25 #307084 by juliankoenig87
Easyprobe should work from 2.6 on (valutransformations in the messages) if I am right.
I wrote the most parts with 2.8.4 an finally with 2.9.2.
Julian
06 Aug 2024 14:44 #307094 by TucsonSean
I tried using 2.7 and I kept getting dbounce error and LinuxCNC would not load. I upgraded to 2.8.4 and I did not get the dbounce error any longer.
06 Aug 2024 14:56 - 06 Aug 2024 15:22 #307095 by TucsonSean
Ok, two more questions:
First, what is the procedure for using this with a machine set to inches for the units?  I have converted the mm values to inches in the ini files but are there other values that need to be adjusted in other files?
Second, the calibration completes and enters the data into the tool table (I checked the file and there are now X, Y, I and J values added to Tool 99). When I try to do any other probing operatoin, i get the following error: No calibration data found in tool table. Please do a calibration. aborting
I re-ran calibration and now it is working.
So, my first question still stands.
-Sean
Last edit: 06 Aug 2024 15:22 by TucsonSean.
