- Thank you received: 3
tommy wrote: And there is another thing, as I need to run my machine in World mode, which disables incremental steps, so the only possibility to jog is in continuous mode, where jog wheel has no function for now ... any solution?
f1oat wrote: I do not know world mode: how can I activate it to investigate the issue on my setup ?
f1oat wrote: Now, there is a configuration file to define the layout and associated HAL pins.
f1oat wrote: Thank you for the table about buttons mapping, that helps a lot.
I have uploaded the V03 to the wiki.
New command line options, see first line of xhc-hb04.hal.
There is no more xhc-hb04.simu executable. The xhc-hb04 can run both in simulation mode or as a HAL module (-H flag).
The xhc-hb04-layout2.ini should be ok for you.
g++ is used instead of gcc: hope there is no compilation issue on your side.
Frederic.
