XHC-HB04 wireless MPG pendant HAL module
13 years 3 months ago #36784 by f1oat
I run 2.6.0-pre without problem.
Have you tried to recompile the xhc-hb04 module ?
Use
make clean
make
make install
13 years 3 months ago #36785 by tommy
f1oat wrote: make clean
make
make install
I did exactly that on first time error showed up.
For installing Run In Place Linuxcnc I followed this steps ... wiki.linuxcnc.org/cgi-bin/wiki.pl?Instal..._or_8_04_from_source
Or maybe 2.6.0-pre could be installed any other way? Because I also have had to copy kinematics file from "standard" installation to folder where I have run in place "installation" to make it run...
If it helps, here are debug and print files:
linuxcnc_debug.txt
Can not find -sec MOT -var MOT -num 1
Can not find -sec IO -var IO -num 1
Can not find -sec LINUXCNC -var NML_FILE -num 1
Can not find -sec EMC -var NML_FILE -num 1
2938
PID TTY STAT TIME COMMAND
Stopping realtime threads
Unloading hal components
linuxcnc_print.txt
RUN_IN_PLACE=yes
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/home/tomaz/linuxcnc-dev/bin
LINUXCNC_TCL_DIR=/home/tomaz/linuxcnc-dev/tcl
LINUXCNC_SCRIPT_DIR=
LINUXCNC_RTLIB_DIR=/home/tomaz/linuxcnc-dev/rtlib
LINUXCNC_CONFIG_DIR=
LINUXCNC_LANG_DIR=/home/tomaz/linuxcnc-dev/src/objects
INIVAR=inivar
HALCMD=halcmd
LINUXCNC_EMCSH=/usr/bin/wish8.5
INIFILE=/home/tomaz/linuxcnc-dev/configs/univpwmv/univpwm.ini
PARAMETER_FILE=univpwm.var
TASK=milltask
HALUI=halui
DISPLAY=axis
Killing task linuxcncsvr, PID=2938
13 years 3 months ago #36786 by f1oat
Try the ldd command to see what lib are used by xhc-hb04.
Here is what it prints on my machine
$ ldd /usr/local/bin/xhc-hb04
linux-gate.so.1 => (0x00355000)
libusb-1.0.so.0 => /lib/libusb-1.0.so.0 (0x00b8b000)
liblinuxcnchal.so.0 => /usr/lib/liblinuxcnchal.so.0 (0x00603000)
liblinuxcncini.so.0 => /usr/lib/liblinuxcncini.so.0 (0x001ff000)
libstdc++.so.6 => /usr/lib/libstdc++.so.6 (0x00204000)
libm.so.6 => /lib/tls/i686/cmov/libm.so.6 (0x00cf4000)
libgcc_s.so.1 => /lib/libgcc_s.so.1 (0x004d3000)
libc.so.6 => /lib/tls/i686/cmov/libc.so.6 (0x00356000)
librt.so.1 => /lib/tls/i686/cmov/librt.so.1 (0x0073b000)
libpthread.so.0 => /lib/tls/i686/cmov/libpthread.so.0 (0x00110000)
/lib/ld-linux.so.2 (0x008bf000)
I suspect issue with liblinuxcncini.so.0 on your machine.
I do not know how "run in place" works.
I use buildbot packages ( buildbot.linuxcnc.org/ ) but the upgrade from 2.5.2 was painful because of remaining python modules on my setup. May be some mistake during upgrade phase on my side.
13 years 3 months ago #36789 by tommy
f1oat wrote: Try the ldd command to see what lib are used by xhc-hb04.
This is what I get:
linux-gate.so.1 => (0x0025c000)
libusb-1.0.so.0 => /lib/libusb-1.0.so.0 (0x006f0000)
liblinuxcnchal.so.0 => /home/tomaz/linuxcnc-dev/lib/liblinuxcnchal.so.0 (0x00c5f000)
liblinuxcncini.so.0 => /home/tomaz/linuxcnc-dev/lib/liblinuxcncini.so.0 (0x0084d000)
libstdc++.so.6 => /usr/lib/libstdc++.so.6 (0x00110000)
libm.so.6 => /lib/tls/i686/cmov/libm.so.6 (0x00c29000)
libgcc_s.so.1 => /lib/libgcc_s.so.1 (0x00798000)
libc.so.6 => /lib/tls/i686/cmov/libc.so.6 (0x0090e000)
librt.so.1 => /lib/tls/i686/cmov/librt.so.1 (0x00207000)
libpthread.so.0 => /lib/tls/i686/cmov/libpthread.so.0 (0x00529000)
/lib/ld-linux.so.2 (0x00e3a000)
13 years 3 months ago #36849 by langarod
I would first say, thank you for sharing this component. It was easy to set up and get it to work.
It works very well.
Only two small problems found.
First, if running spindle very slow there is quite big rounding error in rpm on display. Changing code row to
p += xhc_encode_s16((int)60.0 * *(xhc->hal->spindle_rps), p);
solves that problem.
Second problem is, sometimes, DRO can show 1 number off.
For example, zero x-axis and move exact 1mm it still show 0.000. If move 1 more it shows 1.000. This up to 5, there it was correct.
If running in oposite direction, it showed correct.
If moving 1/10mm from zero, it showed correct 0.1, 0.2, 0.3 etc up to 0.9. Then when it is 1.0, dro show 0.0000. 1.1 was OK again.
When looking at hal pin, position wasn't 1.000, it was 0.9999999...
I changed in xhc_encode_float function to this
unsigned int int_v = round(fabs(v) * 10000.0); unsigned short int_part = int_v / 10000; unsigned short fract_part = int_v % 10000; if (v < 0) fract_part = fract_part | 0x8000; *(short *)buf = int_part; *((short *)buf+1) = fract_part; return 4;
and now it looks like it shows correct values.
One other good thing to now is that some versions of LinuxCNC halui.axis.0.pos-relative dosn't apply tool offset. I had that problem first running on a quite old version of 2.6.0-pre. Pulled latest from git and it worked correct.
I just wanted to share my findings.
Thanks again for sharing this component to us. It helped me a lot!
The following user(s) said Thank You: f1oat
13 years 3 months ago #36850 by f1oat
Everything looks ok
if xhc-hb04 runs in test mode (launched from the shell), then there may be something wrong in path used by linuxcnc. You can search in your filesystem if there is another liblinuxcncini and remove it, or fix linuxcnc path.
This is what I get:
