- Thank you received: 10
tommy wrote: Thank you for your effort!
I might need some help or just for checking if I did right ...
for compilation, I did same as for previous version (make, make install), no errors there ... what I did change is in hal to xhc-hb04-layout2.ini, but when I run linuxcnc I get error on:
Debug file information:
Can not find -sec MOT -var MOT -num 1
Can not find -sec IO -var IO -num 1
Can not find -sec LINUXCNC -var NML_FILE -num 1
Can not find -sec EMC -var NML_FILE -num 1
xhc-hb04.hal:45: Pin 'xhc-hb04.button-x0' does not exist
xhc-hb04-layout2.ini file is placed in same folder as rest of hal and ini files for my machine config.
I was checking wrong ini... :blush:f1oat wrote: You will need to delete erroneous lines in xhc-hb04.hal because there are no X=0, Y=0 and Z=0 buttons on your MPG.
Frederic.
tommy wrote: I was checking wrong ini... :blush:
So, I ran trough all buttons, if they have correct addresses and noticed that for Macro-2 is not 08 but 0B, probably my attached picture was a bit to small and hard to read ... all the rest is OK! So this version of device should be now fully functional under linuxcnc!
andypugh wrote:
This might be over-elaborate. I would not be at all surprised to find that the button mapping changes randomly as they bring out different versions.
I would be tempted to simply call the buttons button-01, button-02 and so on, and then leave it to the integrator to figure out which physical button is which, and which function they want to give it in HAL.
f1oat wrote: @andypugh: thanks, puma config has been useful for solving the issue
@tommy: I have uploaded V04 with support for world mode. You will find a dedicated .hal file. Please, be careful with this new release because I have not been able to test on a real machine !
Frederic.
