VMC related HAL questions.
06 Jun 2015 00:06 #59503 by thewho
Replied by thewho on topic VMC related HAL questions.
Nice, thank you :)
Any tips on how to tune the spindle? Positioning should be easy, but I imagine that it's a bit more difficult to get it to handle different loads?
06 Jun 2015 00:16 #59504 by andypugh
Replied by andypugh on topic VMC related HAL questions.
It depends on your spindle, really. Mine is so slow and powerful that I haven't actually bothered making it closed-loop.
Also, it isn't like actual spindle speed is desperately critical.
Get the FF0 right and a bit of I to compensate for nonlinearity and you are probably as close as you need to be.
06 Jun 2015 11:24 - 06 Jun 2015 12:48 #59509 by thewho
Removed that line but now i can't get the spindle to move at all. M3 S(any number) does not turn it on.
EDIT: But it does turn if I remove line 29
net velocity-mode		motion.spindle-on pid.0.enable
Not as intended of course, but it reacts to M3.
Last edit: 06 Jun 2015 12:48 by thewho.
06 Jun 2015 13:22 #59510 by andypugh
It looks like we need to find a way to drive hm2_5i25.0.7i77.0.1.spinena
The thing is that that needs to be set in either velocity mode or orient mode, so you need an OR component.
loadrt or2 count=1
addf or2.0 servo-thread
net spindle-pos-cmd or2.0.in0
net spindle-vel-cmd or2.0.in1
net spindle-either-cmd or2.0.out hm2_5i25.0.7i77.0.1.spinena
06 Jun 2015 13:43 #59514 by thewho
It complains that "spindle-pos-cmd" is float and or2 wants bit.
06 Jun 2015 14:29 #59517 by andypugh
Sorry, yes.
I should have used the orient-mode and position-mode signals.
06 Jun 2015 15:37 #59524 by thewho
I just stood by the machine doing G33.1 over and over with my mouth wide open :woohoo:
I can't thank you enough Andy!
The spindle encoder was apparently not connected correct, but with a little hal-scoping i figured out that index and A was inverted. Quick fix and then it worked! :laugh:
A question though, when I write M19 in MDI mode nothing happens. Do i need to specify the R,Q,P parameters or is there something else?
06 Jun 2015 15:59 #59525 by andypugh
It should work.
Time to check things out with the HAL tools. Try opening "show hal config" and selecting the watch tab, then adding the motion.spindle-orient, the orient component pins, the angle, hm2_5i25.0.7i77.0.1.spinena, the PID inputs and outputs and enable, etc
06 Jun 2015 17:40 #59531 by thewho
I can't get pid.1 (position) to react.
"Motion.spindle-is-oriented" is always lit, that can't be right?
06 Jun 2015 17:55 #59533 by andypugh
No, that is likely to be the problem.
The issue here is one of calculation order. The near.0 calculation is happening before the orient component can calculate a new position, so the motion system gets the signal that orient is over before it even begins.
The best solution is to use a different version of "orient" that I have written which outputs a pin to drive motion.spindle-is-oriented.
For testing just comment-out the line
net spindle-in-pos 		near.0.out motion.spindle-is-oriented
But the best solution is to comp --install the modified orient component, remove all references to near.0 and have
net spindle-in-pos orient.0.is-oriented => motion.spindle-is-oriented
Time to create page: 1.392 seconds
