huanyang vfd & linuxcnc 2.7
11 years 5 months ago - 11 years 5 months ago #59226 by vre
Replied by vre on topic huanyang vfd & linuxcnc 2.7
i have added my user to dialout group and now starts but configs from hy_vfd repository don't work out the box.
My configs are generated by stepconf wizard.
Have anyone working configs ?
Last edit: 11 years 5 months ago by vre.
11 years 5 months ago #59227 by alan_3301
You are not giving very much info to go on. It starts but doesnt work?
Can you explain?
You have to merge the files with what you already have.
There is not much happening in the files, and they have comments.
I'd read through them just to familiarize yourself with what is happening.
It's not mentioned anywhere, but if you are getting an error that "motion.spindle-forward was already linked to signal spindle-cw",
then you need to edit your main ini file, and find the line that has motion.spindle-forward and spindle-cw on the same line.
Comment this line out (what this means is put a # as the first character on the line)
11 years 5 months ago - 11 years 5 months ago #59231 by vre
alan_3301 wrote: It's not mentioned anywhere, but if you are getting an error that "motion.spindle-forward was already linked to signal spindle-cw",
I have exactly that problem you described i have commented this line in my main hal file
but there and other errors in custom_postui.hal file.
The reason iam not giving enough infos is that i have not internet on linuxcnc pc.
11 years 5 months ago #59232 by alan_3301
If you have a usb drive, you can take a screenshot, or cut and paste the error text., then bring it to your internet computer.
Or use a camera and just take pictures..
Without the errors, no one can help.
11 years 5 months ago - 11 years 5 months ago #59233 by vre
$ linuxcnc LINUXCNC - 2.7.0-pre6 Machine configuration directory is '/home/user/linuxcnc/configs/6040-parallel' Machine configuration file is '6040-parallel.ini' Starting LinuxCNC... . Found file:./6040-parallel.hal Found file:./custom.hal spindle-vfd: device='/dev/ttyUSB0', baud=19200, bits=8, parity='even', stopbits=1, address=1, verbose=1, PID=11317 Opening /dev/ttyUSB0 at 19200 bauds (even) custom_postgui.hal:6: Pin 'pyvcp.amp-meter' does not exist Shutting down and cleaning up LinuxCNC...
Iam using hy_vfd and configs from here
github.com/bebro/linuxcnc-huanyang-vfd/tree/linuxcnc
I renamed panel.xml to custompanel.xml and works
but now gui doesn't fit to 1024x768 resolution.
Modbus connection is green and when start vfd manual in screen shows me infos correctly.
All work now thank you all.Great support!
11 years 5 months ago #59258 by alan_3301
I removed all the XYZ DRO's from my panel.
It gives more space.
Not sure why they are there, I think leftover from the scotta's original version.
Time to create page: 0.378 seconds
