- Thank you received: 4
huanyang vfd & linuxcnc 2.7
11 years 1 month ago - 11 years 1 month ago #63174
by russtuff
Thank you. I assumed I would need something like this, however, no matter how I try and implement your code I get errors. I think it's because of the scale/lowpass stuff in the postgui.hal, plus, I'm terrible at this stuff and don't know what should be put in place of your "..." lines to make it work.
For now I'll just multiply the RPM I really want by 1.7
Replied by russtuff on topic huanyang vfd & linuxcnc 2.7
andypugh wrote:
rusmannx wrote: I just did some more testing and realized that it doesn't matter what I set PD144 to be, any time I S1250 the I get 39.24hz on the VFD.
In that case it looks like you need to use a "scale" component
www.linuxcnc.org/docs/html/man/man9/scale.9.html
Unless you have two gears, in which case "gearchange" might be more appropriate
www.linuxcnc.org/docs/html/man/man9/gearchange.9.html
Code:loadrt scale ... addf scale.0 servo-thread ... net spindle-speed motion.spindle-speed-out => scale.0.in net motor-speed scale.0.out => hy_vfd..... setp scale.0.gain 1.623
Last edit: 11 years 1 month ago by russtuff.
11 years 1 month ago #63185
Yes, you need to integrate the scale into your existing HAL. That is going to mean combining any loadrt scale commands and taking out incompatible nets.
It's like an electrical circuit, if you are inserting an amplifier in a signal path you need to cut the original wires.
One thing that might be useful, when the system is loaded open a terminal and type
That will give you two text files that you can open in a text editor and get a full list of all the pins and parameters that you can use in your HAL file. (every HAL component you add will add some more, too)
Replied by andypugh on topic huanyang vfd & linuxcnc 2.7
rusmannx wrote: Thank you. I assumed I would need something like this, however, no matter how I try and implement your code I get errors. I think it's because of the scale/lowpass stuff in the postgui.hal,
halcmd show pin > pins.txt
halcmd show param params.txt
- daninaustin
10 years 8 months ago #69666
by daninaustin
Replied by daninaustin on topic huanyang vfd & linuxcnc 2.7
Thanks for this! There were a couple of errors on you directions for my version (loaduser rather than loadusr and some of the pins were incorrect), but this helped me tremendously. I can finally get my Spindle under control! Now i just have to figure out the servo's and encoders.
10 years 8 months ago #70089
by vre
Replied by vre on topic huanyang vfd & linuxcnc 2.7
I have linuxcnc 2.7.4 and installed hy_vfd from here
github.com/bebro/linuxcnc-huanyang-vfd/tree/linuxcnc
How can install hy_vfd version included with linuxcnc and not from external repository?
- cncnoob1979
- Thank you received: 75
10 years 8 months ago - 10 years 8 months ago #70093
by cncnoob1979
Replied by cncnoob1979 on topic huanyang vfd & linuxcnc 2.7
vre,
Its already part of linuxcnc distribution. As a matter of fact I used your glade.panel for the VFD and your questions helped me install my system.
There are a few changes from the source code version vs the included version in linuxcnc, namely some pin names were change/removed (September 2015~)
Ill attach a copy of my configuration files so you can see them. When you created your hy_vfd from source did you then place it into you /bin directory?
Ill edit this post in a bit so I can post them from my machine.
EDIT: These should get you where you want to be. Im still in the process of finalizing my settings so there are some items commented out. But the VFD works well via MODBUS, well at least their version of it. Also with PD 165 I had to use 4 and even parity to connect. You can read it in my custom hal file.
Do take note that some pins were renamed and or removed in the distributed linuxcnc version of hy_vfd.
Last edit: 10 years 8 months ago by cncnoob1979.
10 years 8 months ago - 10 years 8 months ago #70095
by vre
solved!
I found the pins changed and updated my hal config & gladevcp panel.
here are the pins changed & removed
linuxcnc.org/docs/html/getting-started/u...c.html#_huanyang_vfd
thanks.
thanks.
Last edit: 10 years 8 months ago by vre.
Time to create page: 0.169 seconds
