huanyang vfd & linuxcnc 2.7
11 years 5 months ago #59270 by vre
Replied by vre on topic huanyang vfd & linuxcnc 2.7
i have uncomment line 15 and now
custom_postgui.hal:15: Pin 'pyvcp.frequency-command' does not exist Shutting down and cleaning up LinuxCNC...
11 years 5 months ago #59271 by andypugh
vre wrote: i have uncomment line 15 and now
What that means is either that your PyVCP panel does not have a frequency display, or that it is called something other than pyvcp.frequency-command
As a quick test, just delete pyvcp.frequency-command from that HAL line
(That still might not work, I have no idea if the "hy-Freq-Cmd" signal is connected to anything at the other end.)
11 years 5 months ago #59272 by vre
i have added to pyvcp panel custompanel.xml this
<tablesticky sticky="w" /> <label> <text>"Frequency command: "</text> </label> <tablesticky sticky="e" /> <number> <halpin>"frequency-command"</halpin> <format>"4.0f"</format> </number> <tablerow/>
and now starts ok but the same problem can not set the rpm
11 years 5 months ago #59273 by andypugh
vre wrote: now starts ok but the same problem can not set the rpm
So, what else is the signal "hy-Freq-Cmd" connected to in the HAL?
(Or, to start at the other end, what is motion.spindle-speed-out connected to?)
11 years 5 months ago - 11 years 5 months ago #59274 by vre
is not connected anywhere.. How to connect ?
(i don't know anything about hal)
i have comment these lines from stepconf wizard
#net spindle-cmd-rpm => pwmgen.0.value #net spindle-on <= motion.spindle-on => pwmgen.0.enable #net spindle-pwm <= pwmgen.0.pwm #setp pwmgen.0.pwm-freq 100.0 #setp pwmgen.0.scale 24000.0 #setp pwmgen.0.offset -2.77555756156e-17 #setp pwmgen.0.dither-pwm true #net spindle-cmd-rpm <= motion.spindle-speed-out #net spindle-cmd-rpm-abs <= motion.spindle-speed-out-abs #net spindle-cmd-rps <= motion.spindle-speed-out-rps #net spindle-cmd-rps-abs <= motion.spindle-speed-out-rps-abs #net spindle-at-speed => motion.spindle-at-speed #net spindle-cw <= motion.spindle-forward #net spindle-ccw <= motion.spindle-reverse
Last edit: 11 years 5 months ago by vre.
11 years 5 months ago #59275 by andypugh
Generally speaking, commenting-out lines of HAL stops things working rather than makes them work.
Can I suggest that you take the time to read the basic HAL documentation?
linuxcnc.org/docs/html/hal/basic_hal.html
Even if you were to revert to relay and voltage control, you would still need to connect those to the spindle speed control in HAL.
Time to create page: 0.262 seconds
