- Thank you received: 22
huanyang vfd & linuxcnc 2.7
11 years 5 months ago #59146
by alan_3301
Replied by alan_3301 on topic huanyang vfd & linuxcnc 2.7
have you set up your vfd correctly?
PD001 = 2 (run commands to comm port)
PD002 = 2 (operating freq to comm port)
PD163 = 1 (slave address 1)
PD164 = 1 (baud rate to 9600 b/s)
PD165 = 3 (8N1 for RTU mode)
11 years 5 months ago #59147
by alan_3301
you can pick what you want for pd164 and pd165, just make sure they match what is specified in custom.hal
11 years 5 months ago #59148
by alan_3301
It is helpful to setup a loopback, and using a terminal program, make sure the rs485 is working.
I had to verify my stuff on a scope to make sure which wire was + and what was -. also I had to leave off the 120 ohm resistors, the waveform became unreadable with them installed.
once that side of everything is working, it's just a matter of making sure all the vfd settings match what the parameters for custom.hal
you can run hy-vfd in a terminal to see all the command line options.
11 years 5 months ago #59161
by vre
Replied by vre on topic huanyang vfd & linuxcnc 2.7
I have been set the parameters correctly to the vfd and code
but the output is: RTAPI error can't access shared memory and then segfault.
11 years 5 months ago #59163
Is RTAI running?
You need to start an RTAI session first:
halrun
loadrt hy_vfd
Replied by andypugh on topic huanyang vfd & linuxcnc 2.7
vre wrote: I have been set the parameters correctly to the vfd and code
Is RTAI running?
halrun
loadrt hy_vfd
11 years 5 months ago #59166
by alan_3301
Time to create page: 0.063 seconds
