I would also like to know what would be the equivalent of
stepgen.2.position-cmd
stepgen.2.position-fb
so it can work with Mesa stepper and servo cards.
Good question.
1. It can be the equivalent as : position.in + postition.offset = position.out
That is the core function of making the up and down signal possible without following errors.
In my case axis 3 is z axis.
net zpos-cmd joint.3.motor-pos-cmd stepgen.3.position-cmd
net zpos-fb stepgen.3.position-fb => joint.3.motor-pos-fb
If i want to make a component myself for thc it would be connected something like this :
net zpos-cmd joint.3.motor-pos-cmd position.in
net zpos-in position.in stepgen.3.position-cmd
net zpos-fb stepgen.3.position-fb position.out
net zpos-out position.out joint.3.motor-pos-fb
Then the calculation would be like item.1
The orginal offset component to see at man page is calculating in different way.
The component name is here for example : position
The component signal names are for example : in, out
The component variable name is for example : offset. It can have a offset value of 0-100mm for example.
If you read it other way :
position.offset = 50 (input value from thc)
g-code position = 1050
net zpos-cmd joint.3.motor-pos-cmd 1050
net zpos-in 1050 stepgen.3.position-cmd
net zpos-fb stepgen.3.position-fb 1100
net zpos-out 1100 joint.3.motor-pos-fb
For Snuggly,
Hacking into the Toma code is not a good idea to start with.
Maybe ask PCW for advise, he knows what you need to start good with Mesa.
