Toma/Proma HAL for Mesa Board -Basics
8 years 2 months ago - 8 years 2 months ago #115407 by snugglylovemuffin
I was able to get the table moving under it's own power. The output for the torch relay - hm2_7i96.0.ssr.00.out-00 doesn't work for tb3 pins 13&14.
The files that I've edited so far are: thc.hal, thc_co (not yet enabled), my custom Hal and Ini for the 7i96.
Last edit: 8 years 2 months ago by snugglylovemuffin.
8 years 2 months ago #115450 by snugglylovemuffin
I was having trouble adapting the thc.hal with the updated "joint" prefix. For example,the Toma thc.hal has a line: axis.2.joint-pos-cmd... Do I just need to replace "zxis" with "joint"?
8 years 2 months ago - 8 years 2 months ago #115453 by snugglylovemuffin
I found some 7i96 specific pin callouts on a different thread.
forum.linuxcnc.org/27-driver-boards/34663-mesa-7i96-inputs
I tried ...ssr.00.out-01
Since the pin i wrote in "does not exist" I'm not quite sure what's wrong.
In other news, I've since added in the .xml, and swapped all "axis" to "joint" in the thc.hal
8 years 2 months ago #115455 by tommylight
Was very busy and will be for the foreseeable future, but i will give it a try in next few days. I already have the 7i92/7i77 on the desk wired and working, and another 6i25/7i77 on the workshop desk.
8 years 2 months ago #115474 by snugglylovemuffin
Okay, I was able to fix the relay issue and am now encountering my previous concern. The error is now "joint.3.motor-pos-cmd was already linked to signal z-pos-cmd"
I was expecting an error, however this goes far beyond my already limited knowledge of the system.
8 years 2 months ago - 8 years 2 months ago #115475 by Grotius
Snuggly,
Can you make a clean copy of a good working machine without without any plasma relationships ?
The most bare config that works for you.
Has Tommy no existing working config available for you? I know he uses a stepper for z axis with Mesa.
But you don't want to i think.
Last edit: 8 years 2 months ago by Grotius.
The following user(s) said Thank You: snugglylovemuffin
