[ Vfdmod ] An easy VFD control over MODBUS RTU
- Zbysob1
5 years 7 months ago #202105
by Zbysob1
Replied by Zbysob1 on topic [ Vfdmod ] An easy VFD control over MODBUS RTU
ok, I disconnected the engine completely and the connection interruption problem disappeared. But I still can't change the rotation. Start and RUN forward and reverse works fine but RPM remains at the minimum setting
- aekhv
- Thank you received: 18
5 years 7 months ago #202178
by aekhv
Replied by aekhv on topic [ Vfdmod ] An easy VFD control over MODBUS RTU
If your custom.hal includes line below, all should work
If not, check command frequency register address. It's also may be an additional option in your vfd, like command frequency source - potentiometer, keyboard, or rs485 line.
net spindle-cmd-rpm => vfdmod.spindle.rpm-in
- aekhv
5 years 7 months ago #202179
by aekhv
Also try to play with Multiplier in [SpindleRpmIn] section, try 10, 100, 1000. Is something changes? Don't forget to remove ";" character in ini.
The following user(s) said Thank You: Zbysob1
- Zbysob1
5 years 7 months ago #202191
by Zbysob1
It works
Thanks a lot, you are great
Of course, it's my mistake because changing the entries in custom.hal according to what you gave above, I omitted the changes regarding the first line. There is an entry from the Github page, probably from version 2.7. These pin renaming are causing me problems. Now it's ok. I just have to deal with the shielding of the converter-motor cable and the noise filter. Will something like this be good?
www.conrad.pl/p/filtr-szumow-250-vac-1-a...affner-fn-2060-1-06- 1-pcs-398696? AdW = API & gclid = EAIaIQobChMI5rWIw_Ot7wIVk2DmCh1RPANsEAAYAyAAEgLJpPD_BwE
- Zbysob1
5 years 7 months ago #202192
by Zbysob1
Thank you again for your help and time
- aekhv
5 years 7 months ago #202215
by aekhv
You're welcome
Time to create page: 0.191 seconds
