[ Vfdmod ] An easy VFD control over MODBUS RTU
- Zbysob1
5 years 7 months ago #201927
by Zbysob1
Replied by Zbysob1 on topic [ Vfdmod ] An easy VFD control over MODBUS RTU
After increasing ProtocolDelay, ignored replies from random senders show "The responding slave 127 isn't the requested slave 1 , ...,
The responding slave 217 isn't the requested slave 1 "and after several such replies return to " ERROR Connection timed out: select. " Only the read request 8203 and write 8193 is sent. The minimum frequency is correct.
- Zbysob1
5 years 7 months ago #201928
by Zbysob1
I changed the converter to yours and now the debug out looks correct - next commands and the inverter answer, but the running program still shows connection errors and you can not control the direction or rotation
- Zbysob1
5 years 7 months ago #201929
by Zbysob1
Error code for RS485 is 112345679 and diode is RED
- aekhv
- Thank you received: 18
5 years 7 months ago #201930
by aekhv
No returned value after this block, it seems like my read coils function works wrong. Try to delete "user-coil-parameter" parameter from your ini.
Replied by aekhv on topic [ Vfdmod ] An easy VFD control over MODBUS RTU
vfdmod: reading 'parameters.user-coil-parameter' from address 8193 (0x2001)...
[01][01][20][01][00][01][A7][CA]
Waiting for a confirmation...
<01><81><01><81><90>
- Zbysob1
5 years 7 months ago #201931
by Zbysob1
You are genius
I deleted this fragment and made my-pyvcp-panel.xml file and postgui.hal file again. The connection is green and no errors
I'll check the rest in the evening because work is waiting. Thanks again Aekhv
- Zbysob1
5 years 7 months ago #202060
by Zbysob1
Communication is ok but no reaction to traffic commands. The "Spindle at speed" diode is red and there is no reaction to start and stop and RPM setting. Information about the minimum revolutions is sent to the inverter, but only the revolutions without a movement command - the display on the inverter blinks with value of minimum
Time to create page: 0.187 seconds
