[ Vfdmod ] An easy VFD control over MODBUS RTU
6 years 6 months ago #164192 by COFHAL
Does this userspace component work with linuxcnc version 2.9?
6 years 6 months ago #164213 by aekhv
COFHAL wrote: Does this userspace component work with linuxcnc version 2.9?
My CNC machine works on LinuxCNC 2.7, so I can test Vfdmod with this version only.
The following user(s) said Thank You: strahlensauger
6 years 6 months ago #164215 by aekhv
COFHAL wrote: Excellent work, could you post your hal file? I have questions about how you control your spindle.
Thanks a lot! About HAL file see user guide above or ask free here :)
6 years 6 months ago #164341 by COFHAL
Replied by COFHAL on topic [ Vfdmod ] not control
I have a problem with the userspace component vdfmod vdfmod. I installed it to control my VDF Fuling DZB280, when I run linuxcnc, the VDF automatically receives the minimum RPM command, in this case 300 RPM, but it is not possible to control the VDF, it cannot RUN, STOP or change frequency. And on the control panel, the RS245 connection LED is always red. When seeing the HAL configuration, I see that all the vdfmod.parameters are connected to the panel but not to any input as it appears in its picture. The same goes for all vdfmod rs485 commands.
6 years 6 months ago #164349 by aekhv
Replied by aekhv on topic [ Vfdmod ] not control
It seems communication settings wrong (error code 110), check parameters in RS485 group. And please show your ini file here.
6 years 6 months ago #164351 by COFHAL
Attachment m INI file and the DEBUG serial USB
Time to create page: 0.136 seconds
