New component for keyboards and panels.
5 years 8 months ago #200558 by cmorley
Replied by cmorley on topic New component for keyboards and panels.
You can do this already. panelui was made with that in mind - though I'm sure there are some weaknesses.
Andy's work (as I understand it) allows projection of keyboard keystrokes to the system.
5 years 8 months ago #200561 by RotarySMP
Replied by RotarySMP on topic New component for keyboards and panels.
That is a major contribution to the community Andy. Good one.
Do you have an old keyboard from an industrial CNC to integrate? Shame I swapped my Maho panel to someone who needed it on their working Phillips.
It would be a big asset to new users (and even advanced users) to do a step by step video on how to identify a matrix key pad, how to wire it into a 7i73, and then how to integrate it into the HAL.
Mark
5 years 8 months ago - 5 years 8 months ago #200572 by andypugh
Replied by andypugh on topic New component for keyboards and panels.
Aciera wrote:
Ok, wikipedia just told me that in unicode there are a few different symbols:
There are at least eight different horizontal dash-like characters of varying lengths defined in Unicode
Pasting the URL above into (the very useful) hexed.it:
So something, somewhere, is converting the minus to a unicode hyphen.
It doesn't do it on my machine, which makes it hard to fix.
The toolchain takes the asciidoc-formatted linuxcnc-dev/docs/src/man/man1/sendkeys.1.txt and converts it into a troff manpage.
The manpage is then converted to HTML. (which is why the URL isn't rendered as a link). I imagine that it is the second phase that converts the minus to a hyphen.
Last edit: 5 years 8 months ago by andypugh.
5 years 8 months ago #200655 by andypugh
cmorley wrote: You can do this already. panelui was made with that in mind
Embarassingly, I had forgotten about panelui.
What sendkeys can do is either create a system keystroke from a scancode - not covered by panelui or send a keystroke when a HAL bit pin toggles - completely unrelated to panelui.
It is perfectly possible to take a 7i73 scancode into matrix_kb (to trigger bit pins) and to sendkeys (to send keystrokes) and also into panelui (to do all the things that panelui can do)
matrix_kb in matrix scan mode can output a hal-bit per key, and the scancode output can be connected to panelui (to toggle bits _and_ other things) and also to sendkeys to send keycodes.
It might make sense to add keystroke sending to panelui. This would lead to some redundancy, but having a baffling variety of ways to achieve any desired result seems to be the LinuxCNC Way.
5 years 8 months ago #200681 by Aciera
Replied by Aciera on topic New component for keyboards and panels.
This seems to be a known bug with UTF-8 conversions. Maybe the use of hyphen/minus should be avoided altogether.
5 years 7 months ago #200839 by andypugh
Aciera wrote: This seems to be a known bug with UTF-8 conversions. Maybe the use of hyphen/minus should be avoided altogether.
It's a bit late now, every HAL file out there is full of them.
Time to create page: 0.490 seconds
