New component for keyboards and panels.
5 years 3 months ago #216342 by andypugh
Replied by andypugh on topic New component for keyboards and panels.
It is probably possible to do it with two sendkeys components, wiring the pins to both and enabling one or the other.
5 years 3 months ago - 5 years 3 months ago #216343 by andypugh
I think that a better way would be to add a new code to the config string, (maybe a for alternate) "a2" would create two "shift bits" as pins, and then the scancode params would be:
setp sendkeys.0.pin-event-01
setp sendkeys.0.pin-event-01-1
setp sendkeys.0.pin-event-01-2
setp sendkeys.0.pin-event-01-3
(for no shift, shift 1, shift 2 and both shifts)
I would also add a scancode (negative?) to set the shift bits from the keyboard. (and bidirectional bits in HAL to show or set status)
Last edit: 5 years 3 months ago by andypugh.
5 years 1 month ago - 5 years 1 month ago #221483 by nkp
Replied by nkp on topic New component for keyboards and panels.
the process takes up a lot of resources
Maybe add a delay to the main loop  (nanosleep (&tw, &tr)?
ps
nanosleep((const struct timespec[]){{0, 5000L}}, NULL);
reduced CPU load to 3-4% (vs ~50% )
Last edit: 5 years 1 month ago by nkp.
5 years 1 month ago - 5 years 1 month ago #221685 by nkp
I am trying to use sendkeys with matrix_kb component. (No board 7i73)
Are there any restrictions on the number of rows in the component matrix_kb?
For example is a 9x7s  configuration possible ?
5 years 1 month ago #221686 by RotarySMP
Replied by RotarySMP on topic New component for keyboards and panels.
When I set up my martrix_kb, I got the impression that not many people use it, so it is possible no one has tested a matrix such as 9x7. Try it. LinuxCNC will soon tell you if it doesn't like a result.
If you need a worked example, my HAL has a 5x5 matrix, It gets created in my HAL, and then used in my Postgui Hal. Both can be found attached to the first couple of posts in this thread.
forum.linuxcnc.org/12-milling/33035-retr...-maho-mh400e?start=0
5 years 1 month ago #221688 by nkp
The fact of the matter is that I tried to use 9x7s. 8 rows Ok, and the ninth does not work.
Time to create page: 0.669 seconds
