- Thank you received: 595
New component for keyboards and panels.
- RotarySMP
5 years 1 month ago - 5 years 1 month ago #221707
by RotarySMP
Replied by RotarySMP on topic New component for keyboards and panels.
8x8=64
9x7=63
Does an 8x8 work for you? you dont have to populate every switch. I have a 5x5 but only use about 21.
Mark
9x7=63
Mark
Last edit: 5 years 1 month ago by RotarySMP.
- nkp
- Thank you received: 39
5 years 1 month ago - 5 years 1 month ago #221761
by nkp
Replied by nkp on topic New component for keyboards and panels.
Del
Last edit: 5 years 1 month ago by nkp.
- COFHAL
- Thank you received: 62
3 years 2 months ago #277448
by COFHAL
Replied by COFHAL on topic New component for keyboards and panels.
I have my 7i73 configured for a 4x8 keyboard with LCD. From what I've read I can use the SENDKEYS component both to generate a virtual keyboard and to generate HAL pins. In the example of the SENDKEYS component, what is not clear to me is how they are physically connected to the Keys inputs in /i73 and if the Matrix_Kb function must also be defined.
- Thank you received: 5334
3 years 2 months ago #277451
Replied by PCW on topic New component for keyboards and panels.
If you want to directly control hal pins in real time with the 7I73
you would use the matrix_kb component. If you want 7i73 key events
to send normal keystroke events you can just use the sendkeys.
If you want both (real time hal pins from 7I73 in addition to normal keystroke
events) you can use both matrix_kb plus sendkeys
- COFHAL
3 years 2 months ago #277452
by COFHAL
Thank you for your prompt response, could you help me with a simple configuration, using both.
- COFHAL
3 years 2 months ago #277453
by COFHAL
I use the example:
Loadusr -W sendkeys config=16t2
net scancodes hm2_7i73.0.0.keycode => sendkeys.0.keycode
setp sendkeys.0.scan-event-00 34 # Key G
setp sendkeys.0.scan-event-01 2 # Key 1
setp sendkeys.0.scan-event-02 3 # Key 2
setp sendkeys.0.scan-event-03 4 # Key 3
setp sendkeys.0.scan-event-04 50 # Key M
setp sendkeys.0.scan-event-05 05 # Key 4
setp sendkeys.0.scan-event-06 06 # Key 5
setp sendkeys.0.scan-event-07 07 # Key 6
setp sendkeys.0.scan-event-08 31 # Key S
setp sendkeys.0.scan-event-09 8 # Key 7
setp sendkeys.0.scan-event-10 9 # Key 8
setp sendkeys.0.scan-event-11 10 # Key 9
setp sendkeys.0.scan-event-12 20 # Key T
setp sendkeys.0.scan-event-13 11 # Key 0
setp sendkeys.0.scan-event-14 52 # Key Dot
setp sendkeys.0.scan-event-15 14 # Backspace
setp sendkeys.0.pin-event-00 29 # Left Ctrl
setp sendkeys.0.pin-event-01 57 # Space
setp sendkeys.0.init 1
but I don't get any response when I press any of the keypad buttons, which doesn't happen to me when I use the Matrix_kb component, where with the halmeter you can verify the activation of the buttons.
Time to create page: 0.328 seconds
