- Thank you received: 39
New component for keyboards and panels.
- nkp
5 years 3 months ago - 5 years 3 months ago #215395
by nkp
now does not see these files:
Replied by nkp on topic New component for keyboards and panels.
#include "rtapi.h"
#include "hal.h"
#include <linux/uinput.h>
#include <asm/unistd.h>
#include <asm/fcntl.h>
#include <string.h>
#include <stdio.h>
#include <stdlib.h>
#define MAX_NAME 12
#include <string.h>
#include <stdio.h>
#include <stdlib.h>
Last edit: 5 years 3 months ago by nkp.
5 years 3 months ago #215399
Replied by andypugh on topic New component for keyboards and panels.
Do you have the headers for the actual kernel you are running?
uname -a then look in /usr/src for a match.
- nkp
5 years 3 months ago #215400
by nkp
I have installed Debian10 (lcnc 2.
tried making a switch for a button with two values
// Copyright (C) 2021 Andy Pugh
// This program is free software; you can redistribute it and/or modify
// it under the terms of the GNU General Public License as published by
// the Free Software Foundation; either version 2 of the License, or
// (at your option) any later version.
// This program is distributed in the hope that it will be useful,
// but WITHOUT ANY WARRANTY; without even the implied warranty of
// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
// GNU General Public License for more details.
// You should have received a copy of the GNU General Public License
// along with this program; if not, write to the Free Software
// Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA
#include "rtapi.h"
#include "hal.h"
#include <unistd.h>
#include <fcntl.h>
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#define MAX_NAME 12
static int comp_id;
typedef struct{
hal_u32_t *keycode;
hal_s32_t *current_event;
hal_bit_t *toggle;
hal_bit_t *init;
hal_bit_t **trigger;
hal_u32_t *event;
} sendkeys_hal;
typedef struct {
int num_codes;
int num_togglecodes;
int num_events;
int num_triggers;
bool inited;
int fd;
bool *prev;
hal_u32_t oldcode;
} sendkeys_param;
typedef struct {
sendkeys_hal *hal;
sendkeys_param *param;
int num_insts;
} sendkeys ;
static sendkeys *me;
void emit(int fd, int type, int code, int val)
struct input_event ie;
ie.type = type;
ie.code = code;
ie.value = val;
write(fd, &ie, sizeof(ie));
static void exit_handler(int sig) {
printf("sendkeys: exiting\n");
exit(0);
static void call_hal_exit(void) {
hal_exit(comp_id);
int init(int argc, char* argv[]){
int *codes;
int *pins;
int i, j;
comp_id = hal_init("sendkeys");
if (comp_id < 0) {
rtapi_print_msg(RTAPI_MSG_ERR, "sendkeys: ERROR: hal_init() failed\n");
return -1;
me = hal_malloc(sizeof(sendkeys));
codes = malloc(sizeof(int));
pins = malloc(sizeof(int));
// This is all because RTAPI_MP_ARRAY_** macros do not appear to work in usersapce
for (i = 1; i < argc; i++){
static int index = -1;
static int type = -1;
int ptr = 0;
bool toggle = 0;
if (strncmp(argv[i], "config=", 7) == 0) type = 1, ptr = 6;
if (strncmp(argv[i], "names=", 6) == 0) type = 2, ptr = 5;
switch (type) {
case 1: // config
while (argv[i][ptr]){
switch (argv[i][ptr]){
case '=':
case ' ':
case ',':
index++;
codes = realloc(codes, (index + 1) * sizeof(int));
pins = realloc(pins, (index + 1) * sizeof(int));
codes[index] = 0;
pins[index] = 0;
toggle = 0;
break;
case 's':
case 'S':
toggle = 0;
break;
case 't':
case 'T':
toggle = 1;
break;
case '0':
case '1':
case '2':
case '3':
case '4':
case '5':
case '6':
case '7':
case '8':
case '9':
if (toggle){
pins[index] = pins[index] * 10 + argv[i][ptr] - '0';
} else {
codes[index] = codes[index] * 10 + argv[i][ptr] - '0';
break;
ptr++;;
me->num_insts = index + 1;
break;
case 2: // Parsing of "names" would be here, but is not enabled yet
ptr++;
break;
me->hal = (sendkeys_hal*)hal_malloc(me->num_insts * sizeof(sendkeys_hal));
me->param = malloc(me->num_insts * sizeof(sendkeys_param));
for (i = 0; i < me->num_insts; i++){
sendkeys_hal* hal = &(me->hal[i]);
sendkeys_param* param = &(me->param[i]);
if (hal_pin_u32_newf(HAL_IN, &(hal->keycode), comp_id,
"sendkeys.%i.keycode", i) < 0) {
rtapi_print_msg(RTAPI_MSG_ERR, "sendkeys.N.keycode error\n");
return -ENOMEM;}
if (hal_pin_s32_newf(HAL_OUT, &(hal->current_event), comp_id,
"sendkeys.%i.current-event", i) < 0) {
rtapi_print_msg(RTAPI_MSG_ERR, "sendkeys.N.current-event error\n");
return -ENOMEM;}
if (hal_pin_bit_newf(HAL_IN, &(hal->init), comp_id,
"sendkeys.%i.init", i) < 0) {
rtapi_print_msg(RTAPI_MSG_ERR, "sendkeys.N.init error\n");
return -ENOMEM;}
if (hal_pin_bit_newf(HAL_IN, &(hal->toggle), comp_id,
"sendkeys.%i.toggle", i) < 0) {
rtapi_print_msg(RTAPI_MSG_ERR, "sendkeys.N.toggle error\n");
return -ENOMEM;}
// event params
rtapi_print_msg(RTAPI_MSG_DBG, "instance %i events %i triggers %i\n", i, codes[i], pins[i]);
param->num_triggers = pins[i];
param->num_codes = codes[i];
param->num_events = codes[i] + pins[i];
hal->event = hal_malloc(param->num_events * sizeof(hal_u32_t*));
for (j = 0; j < param->num_codes; j++){
if (hal_param_u32_newf(HAL_RW, &(hal->event[j]), comp_id,
"sendkeys.%i.scan-event-%02i", i, j) < 0) {
rtapi_print_msg(RTAPI_MSG_ERR, "sendkeys.N.scan-event-%02i error\n", j);
return -ENOMEM;}
for (j = 0; j < param->num_triggers; j++){
if (hal_param_u32_newf(HAL_RW, &(hal->event[j + param->num_codes]), comp_id,
"sendkeys.%i.pin-event-%02i", i, j) < 0) {
rtapi_print_msg(RTAPI_MSG_ERR, "sendkeys.N.pin-event-%02i error\n", j);
return -ENOMEM;}
if (hal_param_u32_newf(HAL_RW, &(hal->event[j + param->num_togglecodes]), comp_id,
"sendkeys.%i.togglepin-event-%02i", i, j) < 0) {
rtapi_print_msg(RTAPI_MSG_ERR, "sendkeys.N.togglepin-event-%02i error\n", j);
return -ENOMEM;}
// trigger pins
hal->trigger = hal_malloc(param->num_triggers * sizeof(hal_bit_t*));
param->prev = malloc(param->num_triggers * sizeof(hal_bit_t));
if (hal_pin_bit_newf(HAL_IN, &(hal->trigger[j]), comp_id,
"sendkeys.%i.trigger-%02i", i, j) < 0) {
rtapi_print_msg(RTAPI_MSG_ERR, "sendkeys.N.trigger-%02i error\n",j);
return -ENOMEM;}
param->prev[j] = 0;
return 0;
int main(int argc, char* argv[]) {
struct uinput_user_dev uidev;
int i, j;
signal(SIGINT, exit_handler);
signal(SIGTERM, exit_handler);
atexit(call_hal_exit);
//parse configs and create pins
init(argc, argv);
hal_ready(comp_id);
while (1) {
if ((*hal->keycode & 0xC0) == 0x80){
*hal->current_event = (*hal->keycode & 0x3f);
} else {
*hal->current_event = -1;
// The event codes are written to pins in HAL after the
// component is loaded.
// We need to set up the keyboard based on the events selected
// so there is a secondary init here.
if (! *hal->init) continue;
if (*hal->init && ! param->inited) {
param->fd = open("/dev/uinput", O_WRONLY | O_NONBLOCK);
if (param->fd < 0) rtapi_print_msg(RTAPI_MSG_ERR,
"Cannot open /dev/uinput. Suggest chmod 666 /dev/uinput\n");
ioctl(param->fd, UI_SET_EVBIT, EV_KEY);
for (j = 0; j < param->num_events; j++){
if (hal->event[j] > 0 && hal->event[j] < KEY_MAX){
ioctl(param->fd, UI_SET_KEYBIT, hal->event[j]);
rtapi_print("SET_EVBIT %i\n", hal->event[j]);
memset(&uidev, 0, sizeof(uidev));
strcpy(uidev.name, "linuxcnc-hal");
uidev.id.bustype = BUS_USB;
uidev.id.vendor = 0x1;
uidev.id.product = 0x1;
uidev.id.version = 1;
write(param->fd, &uidev, sizeof(uidev));
ioctl(param->fd, UI_DEV_CREATE);
param->inited = 1;
if (*hal->keycode != param->oldcode) {
/* Key press, report the event, send key release, and report again*/
if ((*hal->keycode & 0x3F) > param->num_events) continue;
if (hal->event[*hal->keycode & 0x3F] == 0) continue;
if ((*hal->keycode & 0xC0) == 0xC0){ // keydown
emit(param->fd, EV_KEY, hal->event[*hal->keycode & 0x3F], 1);
emit(param->fd, EV_SYN, SYN_REPORT, 0);
} else if ((*hal->keycode & 0xC0) == 0x80){ // keyup
emit(param->fd, EV_KEY, hal->event[*hal->keycode & 0x3F], 0);
param->oldcode = *hal->keycode;
if (param->prev[j] != *hal->trigger[j]){
if (*hal->trigger[j]){ // keydown
if (*hal->toggle){
emit(param->fd, EV_KEY, hal->event[param->num_togglecodes + j], 1);
} else {
emit(param->fd, EV_KEY, hal->event[param->num_codes + j], 1);
} else { // keyup
if (*hal->toggle){
emit(param->fd, EV_KEY, hal->event[param->num_togglecodes + j], 0);
} else {
emit(param->fd, EV_KEY, hal->event[param->num_codes + j], 0);
param->prev[j] = *hal->trigger[j];
5 years 3 months ago #215401
- nkp
5 years 3 months ago #215408
by nkp
5 years 3 months ago #215412
Probably..
How do you plan to select the alternate function?
Time to create page: 0.759 seconds
