Orient
- spumco
- Thank you received: 905
17 Jan 2023 20:38 #262312
by spumco
Replied by spumco on topic Orient
And another thing...
The remap.py might not be good-to-go. There've been some changes in LCNC remap files over the past year or two, and I still need to compare my 'old' remap.py - especially the stdglue.py - to the most current version.
Was planning on doing that later tonight or tomorrow.
- spumco
17 Jan 2023 20:41 #262313
by spumco
Amen.
I really, really want to understand his stuff, but the YT translator is horrible. I can get the gist, but that's not quite good enough for really understanding.
If only I would have a better understanding of German language...
Amen.
- JT
- Thank you received: 615
18 Jan 2023 07:12 #262336
by JT
Replied by JT on topic Orient
Thanks for all the info, it will take me a while to digest it all.
JT
JT
- spumco
18 Jan 2023 08:07 #262342
by spumco
I checked and my stdglue.py file is essentially identical to the latest version in the LCNC code under configs/examples/remap. Mine just has everything but the M6 remap sections commented out.
The Probe Basic sim version of stdglue.py is based on an older version; it's not in the zip file I sent but figured I'd mention it in case you go looking for it.
- alkabal
- Thank you received: 52
19 Jan 2023 17:57 #262446
by alkabal
Replied by alkabal on topic Orient
Hi
Some times ago i have start to work on something more powerfull for orient, this is really unperfect but work not so bad.
At same time i have write a component for help to configure spindle with relative/absolue drive for reverse direction that also make a more easy orient config.
forum.linuxcnc.org/10-advanced-configura...nent-revised?start=0
The code online is not up to date but if someone ask i can add to github colaborator.
I'm sure many things need review from more advanced coder.
function _ "Provide a way for wait spindle slow done before change direction or before stopping";
author "alkabal";
description """
This component have configurable pin for use speed as Absolue or Relative
Provide a way for use acceleration/deceleration and limit spindle max min rpm
Also include built in lowpass for speed filtering and near for spindle at speed for simpler hal config
Add a velocity feedback lowpass as absolue
Other benefit are for decrease "FW/REV relay" usage that stay in last position after stop
Include retarded enable output for waiting relay toggling before enable drive
Work with Analog/PWM "+-10V drive" or "0/10V drive" and other voltage off course.
Allow to use retarded relay for swapp motor wire or provide the output needed for direction setting for some drive
Now also add a way for preventing spindle to start if probe is conneced
author "alkabal";
description """
- alkabal
19 Jan 2023 18:04 #262447
by alkabal
A sim config is available here :
forum.linuxcnc.org/10-advanced-configura...ised?start=80#210991
The following user(s) said Thank You: spumco, JT
- JT
20 Jan 2023 07:41 #262489
by JT
That config has multiple errors and does not run
JT
JT
- alkabal
21 Jan 2023 06:10 #262572
by alkabal
- Benb
24 Jan 2023 15:17 #262834
by Benb
Replied by Benb on topic Orient
Hello John,
I have attached two files, a hal file and a Visual-LinuxCNC file to help you decipher the use of orient component. You would need to tune the orient PID loop, once that's done tweak the OFF time delay of timer parameter for smooth transition. You would also tweak the offset component offset parameter and the orient tolerance parameter for accurate positioning of the spindle. The rest is the usual spindle stuff ie: fwd, rvr, break, on, off, near and soft start.
Hope this will get you started on the right direction.
Ben
Ben
- Benb
24 Jan 2023 15:23 #262835
by Benb
oops I noticed a booboo in the hal file I have pid.0 and parameters set fort pid 5. They both should be pid.5 if you are using 7i77 if not set the pid number to correspond to your system. You probably have to change the component suffix to suit your system.
Time to create page: 0.162 seconds
