- Thank you received: 52
Orient component revised
5 years 4 months ago #211443
by alkabal
Replied by alkabal on topic Orient component revised
desolé ce n'etais pas du tout mon but : au contraire j'ai besoin de retour et d'aide pour finaliser ce projet,
Je suis loin d'etre expert je me torture juste le cerveau avec ça et moi aussi j'ai besoin d'info, je viens dailleur de poser une question en anglais pour plus de visilbilitée.
5 years 4 months ago #211445
by alkabal
nous pourrions meme echanger nos skype si vous voulez
5 years 4 months ago - 5 years 4 months ago #211548
by jpg
Replied by jpg on topic Orient component revised
Bonsoir , oui , il faut juste que je reactive mon compte ,je vois ça demain, à bientot
je vous ai laissé un message sur votre profil
cdt
cdt
Last edit: 5 years 4 months ago by jpg.
4 years 11 months ago #225576
by Pro_El
Replied by Pro_El on topic Orient component revised
Hello
I want to include this component in this machine. Can someone (or Alkabel ) guide me try process of setting this component to my machine. I use LCNC 2.8 and 5i25 with 7i77. I start include hal section from version 3 with my hal but i am not sure where should i include Function () section and how.
Please for some help. Thanks in advanced
3 years 9 months ago #262488
by JT
Replied by JT on topic Orient component revised
I get an error trying to compile orientv2.comp
Opening the file with pluma and save as to change the encoding to utf8 and the compile is successful.
JT
john@cave:~/linuxcnc/configs/my_Lathe_and_Mill_sim_2021-06-02$ sudo halcompile --install orientv2.comp
File "/usr/bin/halcompile", line 1542, in <module>
main()
File "/usr/bin/halcompile", line 1512, in main
process(f, mode, outfile)
File "/usr/bin/halcompile", line 1363, in process
a, b = parse(filename)
File "/usr/bin/halcompile", line 434, in parse
f = open(filename).read()
File "/usr/lib/python3.10/codecs.py", line 322, in decode
(result, consumed) = self._buffer_decode(data, self.errors, final)
UnicodeDecodeError: 'utf-8' codec can't decode byte 0xb0 in position 3620: invalid start byte
JT
3 years 9 months ago - 3 years 9 months ago #262571
by alkabal
Sorry for inconvenience.Can you try this one ?
Last edit: 3 years 9 months ago by alkabal.
Time to create page: 0.277 seconds
