Pimping the mini-lathe
6 years 3 months ago #174868 by PCW
Replied by PCW on topic Pimping the mini-lathe
I think Johns utility has trouble with the new spindle pin names (that changed
sometime in the 2.8 line) Easily fixable in hal though
You can certainly try both
6 years 3 months ago #174886 by rodw
Replied by rodw on topic Pimping the mini-lathe
I'd go with Pncconf as its part of the core. I did have a few issues getting John's tool running..
I also did not like the hal file data as it is filled in from ini file values which I thought it would be hard to maintain.
Given that I've only ever used a hand coded hal and ini file.....
6 years 3 months ago #175149 by RotarySMP
Replied by RotarySMP on topic Pimping the mini-lathe
Here is episode 24...
Enjoy,
Mark
  • Moderator
  • Moderator
6 years 3 months ago #175158 by tommylight
Replied by tommylight on topic Pimping the mini-lathe
LOL, you are becoming worse than "this old Tony" ! :)
To stop anything in a terminal
ctrl+c
:woohoo: .300 for Z axis ??? :)
6 years 3 months ago #175165 by RotarySMP
I take that as a compliment thanks.
Ctrl-C - Thanks.
I picked up the .300 instead of 300, but dumped it from the edit as it seemed too boring :)
Mark
  • Moderator
  • Moderator
6 years 3 months ago #175168 by tommylight
RotarySMP wrote: I take that as a compliment thanks.
It was meant as a compliment, for sure. He is very good at doing such subtle "miss directions", and this was on the same level.
Moderators: piasdom
Time to create page: 0.264 seconds
