- Thank you received: 595
Pimping the mini-lathe
- RotarySMP
6 years 3 months ago #175223
by RotarySMP
Replied by RotarySMP on topic Pimping the mini-lathe
Nice teaser for the next installment of his MAHO retro in this weeks TOT clutch video. He really has a talent for telling a story and explaning.
- Thank you received: 7491
6 years 3 months ago #175232
Replied by tommylight on topic Pimping the mini-lathe
Yes he does, and there are plenty others who try to do what he does, but not nearly as good.RotarySMP wrote: Nice teaser for the next installment of his MAHO retro in this weeks TOT clutch video. He really has a talent for telling a story and explaning.
- RotarySMP
6 years 3 months ago #175233
by RotarySMP
Yep. I try not to copy his comedic chop's, because he's unique. But the basic concept of showing the project and not putting you own ugly mug in front of the camera is a good one, when you have a face made for radio, like me
6 years 3 months ago #175241
He does have one single video where he is full frontal.
LOL, same here.RotarySMP wrote: ...... when you have a face made for radio, like me
- RotarySMP
6 years 3 months ago #175486
by RotarySMP
Some eagle eyed veiwers were not yet asleep at 10:10 of the last video, and picked up that PNCConf reset the PWM = 1 --> PWM =0 as soon as I exited that field. I have since tried it a few times and it seems like a bug ( or more likely a simplification) in PNCConf, as with the default firmware, there are no PWM available.
I assume I'll just have to edit the PWM manually into the HAL.
I read that the 1 PWM config of the 7i96 normally assigns it instead of Step/Dir 4 to TB2 pin 1-6. Is the PWM signal output between GND and STEP4+, between GND nd DIR4+, or between STEP4+ and DIR4+?
- Thank you received: 5334
6 years 3 months ago - 6 years 3 months ago #175545
Replied by PCW on topic Pimping the mini-lathe
if you use the latest mesaflash:
github.com/LinuxCNC/mesaflash
you can list the terminal connections by using the --readhmid option:
mesaflash --device 7i96 --addr 10.10.10.10 --readhmid
For example, using the 7i96d_1pwm firmware, you get this listing:
Configuration Name: HOSTMOT2
BoardName : MESA7I96
FPGA Size: 9 KGates
FPGA Pins: 144
Number of IO Ports: 3
Width of one I/O port: 17
Clock Low frequency: 100.0000 MHz
Clock High frequency: 200.0000 MHz
IDROM Type: 3
Instance Stride 0: 4
Instance Stride 1: 64
Register Stride 0: 256
Register Stride 1: 256
Modules in configuration:
Module: DPLL
There are 1 of DPLL in configuration
Version: 0
Registers: 7
BaseAddress: 7000
ClockFrequency: 100.000 MHz
Register Stride: 256 bytes
Instance Stride: 4 bytes
Module: WatchDog
There are 1 of WatchDog in configuration
Version: 0
Registers: 3
BaseAddress: 0C00
Module: IOPort
There are 3 of IOPort in configuration
Version: 0
Registers: 5
BaseAddress: 1000
Module: PWM
There are 1 of PWM in configuration
Version: 0
Registers: 5
BaseAddress: 4100
ClockFrequency: 200.000 MHz
Module: StepGen
There are 4 of StepGen in configuration
Version: 2
Registers: 10
BaseAddress: 2000
Module: QCount
There are 1 of QCount in configuration
Version: 2
Registers: 5
BaseAddress: 3000
Module: SSerial
There are 1 of SSerial in configuration
Version: 0
Registers: 6
BaseAddress: 5B00
Instance Stride: 64 bytes
Module: SSR
There are 1 of SSR in configuration
Version: 0
Registers: 2
BaseAddress: 7D00
Module: LED
There are 1 of LED in configuration
Version: 0
Registers: 1
BaseAddress: 0200
Configuration pin-out:
IO Connections for TB3
Pin# I/O Pri. func Sec. func Chan Pin func Pin Dir
TB3 1 0 IOPort None
TB3 2 1 IOPort None
TB3 3 2 IOPort None
TB3 4 3 IOPort None
TB3 5 4 IOPort None
TB3 6 5 IOPort None
TB3 7 6 IOPort None
TB3 8 7 IOPort None
TB3 9 8 IOPort None
TB3 10 9 IOPort None
Internal 10 IOPort None
TB3 13,14 11 IOPort SSR 0 Out-00 (Out)
TB3 15,16 12 IOPort SSR 0 Out-01 (Out)
TB3 17,18 13 IOPort SSR 0 Out-02 (Out)
TB3 19,20 14 IOPort SSR 0 Out-03 (Out)
TB3 21,22 15 IOPort SSR 0 Out-04 (Out)
TB3 23,24 16 IOPort SSR 0 Out-05 (Out)
IO Connections for TB1/TB2
TB1 2,3 17 IOPort StepGen 0 Step/Table1 (Out)
TB1 4,5 18 IOPort StepGen 0 Dir/Table2 (Out)
TB1 8,9 19 IOPort StepGen 1 Step/Table1 (Out)
TB1 10,11 20 IOPort StepGen 1 Dir/Table2 (Out)
TB1 14,15 21 IOPort StepGen 2 Step/Table1 (Out)
TB1 16,17 22 IOPort StepGen 2 Dir/Table2 (Out)
TB1 20,21 23 IOPort StepGen 3 Step/Table1 (Out)
TB1 22,23 24 IOPort StepGen 3 Dir/Table2 (Out)
TB2 2,3 25 IOPort PWM 0 PWM (Out)
TB2 4,5 26 IOPort PWM 0 Dir (Out)
TB2 7,8 27 IOPort QCount 0 Quad-A (In)
TB2 10,11 28 IOPort QCount 0 Quad-B (In)
TB2 13,14 29 IOPort QCount 0 Quad-IDX (In)
TB2 16,17 30 IOPort SSerial 0 RXData0 (In)
TB2 18,19 31 IOPort SSerial 0 TXData0 (Out)
Internal 32 IOPort SSerial 0 TXEn0 (Out)
Internal 33 IOPort SSR 0 AC Ref (Out)
IO Connections for P1
1 34 IOPort None
14 35 IOPort None
2 36 IOPort None
15 37 IOPort None
3 38 IOPort None
16 39 IOPort None
4 40 IOPort None
17 41 IOPort None
5 42 IOPort None
6 43 IOPort None
7 44 IOPort None
8 45 IOPort None
9 46 IOPort None
10 47 IOPort None
11 48 IOPort None
12 49 IOPort None
13 50 IOPort None
Last edit: 6 years 3 months ago by PCW.
Moderators: piasdom
Time to create page: 0.157 seconds
