Pimping the mini-lathe
- Thank you received: 7465
26 Jul 2020 10:20 #175881
Replied by tommylight on topic Pimping the mini-lathe
Pin5 only.
Pin 6 is direction and your board does not use that.
Gnd goes from Mesa gnd to pwm board gnd.
- RotarySMP
- Thank you received: 595
26 Jul 2020 10:50 - 26 Jul 2020 11:13 #175882
by RotarySMP
Replied by RotarySMP on topic Pimping the mini-lathe
Thanks Tommy.
The 7i96 is connected with ethernet, flashed with 7i96d_1pwm and communicating normally with Linux. P3 is powered with 5V. With LinuxCNC running, I used HALShow to:and
According to the manual TB1-1 would normally be a ground. but according to MESA Flash readhmid, it is now the Step signal for Stepgen 0. Where do you find a GND once you use a non-standard bitfile?
Using my Osci, I cant see a 50% square wave (or any other signal) between TB1-1 and TB1-5
Also is it normal that the Mesaflash readhmid shows nothing on TB2 or TB3? Shouldn't all the generic I/O pins still show up? The read out from Mesaflash readhmid is very different to the one you posted for 7i96d_1pwm.
***edit***
I also just noticed that this readhmid readout shows only single ended connections for the encoder, whereas there should be pairs for differential connection.
setp hm2_7i96.0.pwmgen.00.enable truesetp hm2_7i96.0.pwmgen.00.value 50According to the manual TB1-1 would normally be a ground. but according to MESA Flash readhmid, it is now the Step signal for Stepgen 0. Where do you find a GND once you use a non-standard bitfile?
***edit***
Last edit: 26 Jul 2020 11:13 by RotarySMP.
- RotarySMP
26 Jul 2020 10:57 - 26 Jul 2020 11:36 #175883
by RotarySMP
The ICSTATION PWM-analog board I am using only accepts PWM signals between 1kHz and 3kHz. What is the PWM frequency which the 7i96 ouputs?
+++edit+++
Found this:
forum.linuxcnc.org/39-pncconf/38723-pncc...tting-up-pwm-on-7i96
+++edit+++
Found this:
Last edit: 26 Jul 2020 11:36 by RotarySMP.
26 Jul 2020 11:43 - 26 Jul 2020 11:44 #175888
Your Mesa pinout shows "transformer" and that is something i have not seen before !
From what i gather, the PWM output should be on the STEP4 header, so there is the GND and the PWM.
So TB2, pin 1 GND and pin 3 PWM+ should go to the pwm board.
The frequency can be set in hal.
Last edit: 26 Jul 2020 11:44 by tommylight. Reason: More info
- RotarySMP
26 Jul 2020 11:49 - 26 Jul 2020 11:51 #175889
by RotarySMP
I flashed the 7i96_1pwm bit file last week, and from the video I took it looked like I did the right one, but the result is very different than sample PCW posted here last week.
forum.linuxcnc.org/26-turning/38280-pimp...the?start=140#175545
I think I'll flash it again, and see if it returns a different result.
Mark
Mark
Last edit: 26 Jul 2020 11:51 by RotarySMP.
- RotarySMP
26 Jul 2020 13:42 #175896
by RotarySMP
I reflashed it, but no change...
This is from the 7i96.zip file on the MESAnet 7i96 webpage. Could it be that there is a different version of this bitfile I should be using?
minilathe@minilathe:~/Downloads/7i96/configs/hostmot2$ dir
7i96_5abob_d.bit 7i96_6enc_d.bit 7i96_7i77d.bit 7i96_7i85sd.bit 7i96d_1pwm.pin 7i96_fallback.bit 7i96_inmd.bit 7i96_pktd.bit
7i96_5abob_d.pin 7i96_6enc_d.pin 7i96_7i78d.bit 7i96_7i85sinmd.bit 7i96d.bit 7i96_fallback.pin 7i96_inmd_dp.bit 7i96_pktd.pin
7i96_5abob_inmd.bit 7i96_7i76d.bit 7i96_7i78d.pin 7i96_7i89d.bit 7i96d.pin 7i96_g540dpl.bit 7i96_inmd_dp.pin source
7i96_5abob_inmd.pin 7i96_7i76d.pin 7i96_7i85d.bit 7i96d_1pwm.bit 7i96dpl.bit 7i96_inm_7i85sd.bit 7i96_inmd.pin
minilathe@minilathe:~/Downloads/7i96/configs/hostmot2$ mesaflash --device 7i96 --addr 10.10.10.10 --write 7i96d_1pwm.bit
Checking file... OK
File type: BIT file
Boot sector OK
EEPROM sectors to write: 6, max sectors in area: 16
Erasing EEPROM sectors starting from 0x100000...
|EEEEEE
Programming EEPROM sectors starting from 0x100000...
|WWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWW
Board configuration updated successfully.
Checking file... OK
File type: BIT file
Boot sector OK
Verifying EEPROM sectors starting from 0x100000...
|VVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVV
Board configuration verified successfully.
You must power cycle the hardware or use the --reload command to load a new firmware.
minilathe@minilathe:~/Downloads/7i96/configs/hostmot2$ mesaflash --device 7i96 --addr 10.10.10.10 --reload
minilathe@minilathe:~/Downloads/7i96/configs/hostmot2$ mesaflash --device 7i96 --addr 10.10.10.10 --readhmid
Configuration Name: HOSTMOT2
BoardName : MESA7I96
FPGA Size: 9 KGates
FPGA Pins: 144
Number of IO Ports: 3
Width of one I/O port: 17
Clock Low frequency: 100.0000 MHz
Clock High frequency: 200.0000 MHz
IDROM Type: 3
Instance Stride 0: 4
Instance Stride 1: 64
Register Stride 0: 256
Register Stride 1: 256
Modules in configuration:
Module: DPLL
There are 1 of DPLL in configuration
Version: 0
Registers: 7
BaseAddress: 7000
ClockFrequency: 100.000 MHz
Register Stride: 256 bytes
Instance Stride: 4 bytes
Module: WatchDog
There are 1 of WatchDog in configuration
Version: 0
Registers: 3
BaseAddress: 0C00
Module: IOPort
There are 3 of IOPort in configuration
Version: 0
Registers: 5
BaseAddress: 1000
Module: PWM
There are 1 of PWM in configuration
Version: 0
Registers: 5
BaseAddress: 4100
ClockFrequency: 200.000 MHz
Module: StepGen
There are 4 of StepGen in configuration
Version: 2
Registers: 10
BaseAddress: 2000
Module: QCount
There are 1 of QCount in configuration
Version: 2
Registers: 5
BaseAddress: 3000
Module: SSerial
There are 1 of SSerial in configuration
Version: 0
Registers: 6
BaseAddress: 5B00
Instance Stride: 64 bytes
Module: Transformer
There are 1 of Transformer in configuration
Version: 0
Registers: 2
BaseAddress: 7D00
Module: LED
There are 1 of LED in configuration
Version: 0
Registers: 1
BaseAddress: 0200
Configuration pin-out:
IO Connections for P1
Pin# I/O Pri. func Sec. func Chan Pin func Pin Dir
1 0 IOPort None
14 1 IOPort None
2 2 IOPort None
15 3 IOPort None
3 4 IOPort None
16 5 IOPort None
4 6 IOPort None
17 7 IOPort None
5 8 IOPort None
6 9 IOPort None
7 10 IOPort None
8 11 IOPort Transformer 0 Drive (Out)
9 12 IOPort Transformer 0 Ref (Out)
10 13 IOPort Transformer 0 Null3 (Out)
11 14 IOPort Transformer 0 Null4 (Out)
12 15 IOPort Transformer 0 Null5 (Out)
13 16 IOPort Transformer 0 Null6 (Out)
IO Connections for TB1
1 17 IOPort StepGen 0 Step/Table1 (Out)
14 18 IOPort StepGen 0 Dir/Table2 (Out)
2 19 IOPort StepGen 1 Step/Table1 (Out)
15 20 IOPort StepGen 1 Dir/Table2 (Out)
3 21 IOPort StepGen 2 Step/Table1 (Out)
16 22 IOPort StepGen 2 Dir/Table2 (Out)
4 23 IOPort StepGen 3 Step/Table1 (Out)
17 24 IOPort StepGen 3 Dir/Table2 (Out)
5 25 IOPort PWM 0 PWM (Out)
6 26 IOPort PWM 0 Dir (Out)
7 27 IOPort QCount 0 Quad-A (In)
8 28 IOPort QCount 0 Quad-B (In)
9 29 IOPort QCount 0 Quad-IDX (In)
10 30 IOPort SSerial 0 RXData1 (In)
11 31 IOPort SSerial 0 TXData1 (Out)
12 32 IOPort SSerial 0 TXEn1 (Out)
Segmentation fault (core dumped)
minilathe@minilathe:~/Downloads/7i96/configs/hostmot2$ This is from the 7i96.zip file on the MESAnet 7i96 webpage. Could it be that there is a different version of this bitfile I should be using?
- Thank you received: 5316
26 Jul 2020 13:49 - 26 Jul 2020 13:50 #175897
TB2 pins 2 and 3 are the PWM outputs (- and + respectively)
You need to update mesaflash to get the TB numbers:
github.com/LinuxCNC/mesaflash
Replied by PCW on topic Pimping the mini-lathe
TB2 2,3 25 IOPort PWM 0 PWM (Out)
TB2 4,5 26 IOPort PWM 0 Dir (Out)
TB2 7,8 27 IOPort QCount 0 Quad-A (In)
TB2 10,11 28 IOPort QCount 0 Quad-B (In)
TB2 13,14 29 IOPort QCount 0 Quad-IDX (In)TB2 pins 2 and 3 are the PWM outputs (- and + respectively)
Last edit: 26 Jul 2020 13:50 by PCW.
- RotarySMP
26 Jul 2020 13:59 #175899
by RotarySMP
I only just installed mesaflash using the instructions for that github link. What do I need to do differently to get the most current version?
Is there any documentation on the PWM setup? I just found:
Basic PWM setup:
setp hm2_7i96.0.pwmgen.pwm_frequency 10000
setp hm2_7i96.0.pwmgen.00.scale 24000 # full scale is 24000 RPM
setp hm2_7i96.0.pwmgen.00.output-type 1 # standard PWM and direction
And was wondering what the outut type is for only PWM in only one direction? or do I just use this and ignore the direction part?
Basic PWM setup:
26 Jul 2020 14:08 - 26 Jul 2020 14:17 #175900
It sounds like you did not install the latest mesaflash (so you are using the old one)
after building mesaflash, did you run "sudo make install" ?
git clone github.com/LinuxCNC/mesaflash.git
cd mesaflash
make
sudo make install
And yes standard PWM (mode 1) is correct
cd mesaflash
make
sudo make install
Last edit: 26 Jul 2020 14:17 by PCW.
- RotarySMP
26 Jul 2020 14:23 #175901
by RotarySMP
I followed the lines of the git instructions one by one, including make including the four list. When I repeat them
minilathe@minilathe:~$ git clone github.com/LinuxCNC/mesaflash.git
fatal: destination path 'mesaflash' already exists and is not an empty directory.
minilathe@minilathe:~$ cd mesaflash
minilathe@minilathe:~/mesaflash$ make
make: Nothing to be done for 'all'.
minilathe@minilathe:~/mesaflash$ sudo make install
[sudo] password for minilathe:
install -p -D --mode=0755 --owner root --group root mesaflash /bin/mesaflash
install -p -D --mode=0644 --owner root --group root mesaflash.1 /share/man/man1/mesaflash.1
Moderators: piasdom
Time to create page: 1.473 seconds
