Pimping the mini-lathe
  • RotarySMP
  • RotarySMP's Avatar Topic Author
  • Platinum Member
  • Platinum Member
20 Jul 2020 10:27 #175233 by RotarySMP
Replied by RotarySMP on topic Pimping the mini-lathe
Yep. I try not to copy his comedic chop's, because he's unique. But the basic concept of showing the project and not putting you own ugly mug in front of the camera is a good one, when you have a face made for radio, like me :)
20 Jul 2020 10:48 #175241 by tommylight
Replied by tommylight on topic Pimping the mini-lathe
...... when you have a face made for radio, like me :)
LOL, same here.
He does have one single video where he is full frontal.
  • RotarySMP
  • Platinum Member
  • Platinum Member
23 Jul 2020 09:42 #175486 by RotarySMP
Some eagle eyed veiwers were not yet asleep at 10:10 of the last video, and picked up that PNCConf reset the PWM = 1 --> PWM =0 as soon as I exited that field. I have since tried it a few times and it seems like a bug ( or more likely a simplification) in PNCConf, as with the default firmware, there are no PWM available.
I assume I'll just have to edit the PWM manually into the HAL.
I read that the 1 PWM config of the 7i96 normally assigns it instead of Step/Dir 4 to TB2 pin 1-6. Is the PWM signal output between GND and STEP4+, between GND nd DIR4+, or between STEP4+ and DIR4+?
23 Jul 2020 14:01 - 23 Jul 2020 14:04 #175545 by PCW
Replied by PCW on topic Pimping the mini-lathe
if you use the latest mesaflash:
github.com/LinuxCNC/mesaflash
you can list the terminal connections by using the --readhmid option:
mesaflash --device 7i96 --addr 10.10.10.10 --readhmid
For example, using the 7i96d_1pwm firmware, you get this listing:
Configuration Name: HOSTMOT2
  BoardName : MESA7I96
  FPGA Size: 9 KGates
  FPGA Pins: 144
  Number of IO Ports: 3
  Width of one I/O port: 17
  Clock Low frequency: 100.0000 MHz
  Clock High frequency: 200.0000 MHz
  IDROM Type: 3
  Instance Stride 0: 4
  Instance Stride 1: 64
  Register Stride 0: 256
  Register Stride 1: 256
Modules in configuration:
  Module: DPLL
  There are 1 of DPLL in configuration
  Version: 0
  Registers: 7
  BaseAddress: 7000
  ClockFrequency: 100.000 MHz
  Register Stride: 256 bytes
  Instance Stride: 4 bytes
  Module: WatchDog
  There are 1 of WatchDog in configuration
  Version: 0
  Registers: 3
  BaseAddress: 0C00
  Module: IOPort
  There are 3 of IOPort in configuration
  Version: 0
  Registers: 5
  BaseAddress: 1000
  Module: PWM
  There are 1 of PWM in configuration
  Version: 0
  Registers: 5
  BaseAddress: 4100
  ClockFrequency: 200.000 MHz
  Module: StepGen
  There are 4 of StepGen in configuration
  Version: 2
  Registers: 10
  BaseAddress: 2000
  Module: QCount
  There are 1 of QCount in configuration
  Version: 2
  Registers: 5
  BaseAddress: 3000
  Module: SSerial
  There are 1 of SSerial in configuration
  Version: 0
  Registers: 6
  BaseAddress: 5B00
  Instance Stride: 64 bytes
  Module: SSR
  There are 1 of SSR in configuration
  Version: 0
  Registers: 2
  BaseAddress: 7D00
  Module: LED
  There are 1 of LED in configuration
  Version: 0
  Registers: 1
  BaseAddress: 0200
Configuration pin-out:
IO Connections for TB3
Pin#                  I/O   Pri. func    Sec. func       Chan      Pin func        Pin Dir
TB3 1                   0   IOPort       None
TB3 2                   1   IOPort       None
TB3 3                   2   IOPort       None
TB3 4                   3   IOPort       None
TB3 5                   4   IOPort       None
TB3 6                   5   IOPort       None
TB3 7                   6   IOPort       None
TB3 8                   7   IOPort       None
TB3 9                   8   IOPort       None
TB3 10                  9   IOPort       None
Internal               10   IOPort       None
TB3 13,14              11   IOPort       SSR              0        Out-00          (Out)
TB3 15,16              12   IOPort       SSR              0        Out-01          (Out)
TB3 17,18              13   IOPort       SSR              0        Out-02          (Out)
TB3 19,20              14   IOPort       SSR              0        Out-03          (Out)
TB3 21,22              15   IOPort       SSR              0        Out-04          (Out)
TB3 23,24              16   IOPort       SSR              0        Out-05          (Out)
IO Connections for TB1/TB2
TB1 2,3                17   IOPort       StepGen          0        Step/Table1     (Out)
TB1 4,5                18   IOPort       StepGen          0        Dir/Table2      (Out)
TB1 8,9                19   IOPort       StepGen          1        Step/Table1     (Out)
TB1 10,11              20   IOPort       StepGen          1        Dir/Table2      (Out)
TB1 14,15              21   IOPort       StepGen          2        Step/Table1     (Out)
TB1 16,17              22   IOPort       StepGen          2        Dir/Table2      (Out)
TB1 20,21              23   IOPort       StepGen          3        Step/Table1     (Out)
TB1 22,23              24   IOPort       StepGen          3        Dir/Table2      (Out)
TB2 2,3                25   IOPort       PWM              0        PWM             (Out)
TB2 4,5                26   IOPort       PWM              0        Dir             (Out)
TB2 7,8                27   IOPort       QCount           0        Quad-A          (In)
TB2 10,11              28   IOPort       QCount           0        Quad-B          (In)
TB2 13,14              29   IOPort       QCount           0        Quad-IDX        (In)
TB2 16,17              30   IOPort       SSerial          0        RXData0         (In)
TB2 18,19              31   IOPort       SSerial          0        TXData0         (Out)
Internal               32   IOPort       SSerial          0        TXEn0           (Out)
Internal               33   IOPort       SSR              0        AC Ref          (Out)
IO Connections for P1
 1                     34   IOPort       None
14                     35   IOPort       None
 2                     36   IOPort       None
15                     37   IOPort       None
 3                     38   IOPort       None
16                     39   IOPort       None
 4                     40   IOPort       None
17                     41   IOPort       None
 5                     42   IOPort       None
 6                     43   IOPort       None
 7                     44   IOPort       None
 8                     45   IOPort       None
 9                     46   IOPort       None
10                     47   IOPort       None
11                     48   IOPort       None
12                     49   IOPort       None
13                     50   IOPort       None
Last edit: 23 Jul 2020 14:04 by PCW.
  • RotarySMP
  • Platinum Member
  • Platinum Member
23 Jul 2020 14:04 #175546 by RotarySMP
Another 7i96 config question, in addition to the one in the last post...
Do I have to use only the new MESA naming convention in HAL generated by the new PNCConf.
[HMOT](card0)...
or are these just place holders, and I have to modify each instance to the syntax used by HALshow?
23 Jul 2020 14:13 - 23 Jul 2020 14:16 #175547 by PCW
That is just a way to have the card name in one place (in the ini file):
[HMOT]
# **** This is for info only ****
CARD0=hm2_7i96.0
in the hal file
hm2_7i96.0.xxxxxxxx
is the same as
[HMOT](card0).xxxxxxxx
if the ini file [HMOT] entry is CARD0=hm2_7i96.0
Last edit: 23 Jul 2020 14:16 by PCW.
  • RotarySMP
  • Platinum Member
  • Platinum Member
23 Jul 2020 14:48 - 23 Jul 2020 14:51 #175551 by RotarySMP
Thanks for the prompt replies. Now I can continue wiring up the VFD and configure it.
in the hal file
hm2_7i96.0.xxxxxxxx
is the same as
Replacing 10 characters with 13 characters doen't seem like a benefit, what is the advantage of this?
Mark
Last edit: 23 Jul 2020 14:51 by RotarySMP.
23 Jul 2020 14:57 #175552 by tommylight
Make a config for say 5i25 and later want to use that same config for 7i92, now requires only changing the card name in the ini file and adding the IP address in the hal file.
Without this option it would require a lot of "search and replace" for everything referring to 5i25 in hal.
23 Jul 2020 15:25 #175553 by PCW
It also can allow you to use the same hal file for different cards
  • RotarySMP
  • Platinum Member
  • Platinum Member
26 Jul 2020 09:49 - 26 Jul 2020 09:50 #175878 by RotarySMP
I havent made enough progress to merit editing a video this week. Sorry about that.
I installed mesaflash and read out the card. WIth only two step gens, one encoder and one pwmgen, it looks like this...
minilathe@minilathe:~$ sudo apt install git
[sudo] password for minilathe:
minilathe@minilathe:~/mesaflash$ mesaflash --device 7i96 --addr 10.10.10.10 --readhmid
  FPGA Size: 9 KGates
  FPGA Pins: 144
  IDROM Type: 3
  Module: DPLL
  Version: 0
  Registers: 7
  BaseAddress: 7000
  Module: WatchDog
  Version: 0
  Registers: 3
  BaseAddress: 0C00
  Module: IOPort
  Version: 0
  Registers: 5
  BaseAddress: 1000
  Module: PWM
  Version: 0
  Registers: 5
  BaseAddress: 4100
  Module: StepGen
  Version: 2
  Registers: 10
  BaseAddress: 2000
  Module: QCount
  Version: 2
  Registers: 5
  BaseAddress: 3000
  Module: SSerial
  Version: 0
  Registers: 6
  BaseAddress: 5B00
  Module: Transformer
  There are 1 of Transformer in configuration
  Version: 0
  Registers: 2
  BaseAddress: 7D00
  Module: LED
  Version: 0
  Registers: 1
  BaseAddress: 0200
 1      0   IOPort       None
14      1   IOPort       None
 2      2   IOPort       None
15      3   IOPort       None
 3      4   IOPort       None
16      5   IOPort       None
 4      6   IOPort       None
17      7   IOPort       None
 5      8   IOPort       None
 6      9   IOPort       None
 7     10   IOPort       None
 8     11   IOPort       Transformer      0        Drive           (Out)
 9     12   IOPort       Transformer      0        Ref             (Out)
10     13   IOPort       Transformer      0        Null3           (Out)
11     14   IOPort       Transformer      0        Null4           (Out)
12     15   IOPort       Transformer      0        Null5           (Out)
13     16   IOPort       Transformer      0        Null6           (Out)
 1     17   IOPort       StepGen          0        Step/Table1     (Out)
14     18   IOPort       StepGen          0        Dir/Table2      (Out)
 2     19   IOPort       StepGen          1        Step/Table1     (Out)
15     20   IOPort       StepGen          1        Dir/Table2      (Out)
 3     21   IOPort       StepGen          2        Step/Table1     (Out)
16     22   IOPort       StepGen          2        Dir/Table2      (Out)
 4     23   IOPort       StepGen          3        Step/Table1     (Out)
17     24   IOPort       StepGen          3        Dir/Table2      (Out)
 5     25   IOPort       PWM              0        PWM             (Out)
 6     26   IOPort       PWM              0        Dir             (Out)
 7     27   IOPort       QCount           0        Quad-A          (In)
 8     28   IOPort       QCount           0        Quad-B          (In)
 9     29   IOPort       QCount           0        Quad-IDX        (In)
10     30   IOPort       SSerial          0        RXData1         (In)
11     31   IOPort       SSerial          0        TXData1         (Out)
12     32   IOPort       SSerial          0        TXEn1           (Out)
Segmentation fault (core dumped)
So I need to connect the PWM to analog card to TB1 pins 5 and 6. Does it matter which is GND and which is signal?
Last edit: 26 Jul 2020 09:50 by RotarySMP.
Moderators: piasdom
Time to create page: 0.272 seconds
