Pimping the mini-lathe
- RotarySMP
- Thank you received: 595
16 Jul 2020 14:43 #174854
by RotarySMP
Do I first use PNCConf to set up the connection, IP address etc between the PC and 7i96, and then flash it with the PWM bitfile, or do I have to manually configure the connection and then flash it, before using PNCConf?
Replied by RotarySMP on topic Pimping the mini-lathe
The as shipped 7I96 has the 7i96d.bit bitfile loaded
This has 5 stepgens and no PWM.
To load 7i96d_1pwm.bit you would need to fetch the 7i96.zip archive from Mesa,
extract the 7i96d_1pwm.bit bitfile and run these commands:
mesaflash --device 7i96 --addr [the cards current ip address] --write 7i96d_1pwm.bit
mesaflash --device 7i96 --addr [the cards current ip address] --reload
- RotarySMP
16 Jul 2020 15:09 - 16 Jul 2020 15:48 #174859
by RotarySMP
Is the Ethornton 7i96 configuration tool still the way to do it, like in this video from ~6minutes?
Well, that video helps. I jumpered for the fixed IP address of the EEPROM, and set a fic IP address as DEAD IO showed there, and now have them connected and the PWM bitfile flashed. I am still a bit unsure whether it is better to use that one Ethornton configuration widget, as I thought PNCConf has now been revised to configure a 7i96.
Either way, I am not off to buy a new (used) camera (panasonic G81) as the current video set up with the older Olympus EM10 I am not too happy with. I'll continue with the 7i96 tomorrow.
Last edit: 16 Jul 2020 15:48 by RotarySMP.
- Thank you received: 5328
16 Jul 2020 17:14 #174868
Replied by PCW on topic Pimping the mini-lathe
I think Johns utility has trouble with the new spindle pin names (that changed
sometime in the 2.8 line) Easily fixable in hal though
You can certainly try both
- Thank you received: 4149
16 Jul 2020 21:20 #174886
Replied by rodw on topic Pimping the mini-lathe
I'd go with Pncconf as its part of the core. I did have a few issues getting John's tool running..
I also did not like the hal file data as it is filled in from ini file values which I thought it would be hard to maintain.
Given that I've only ever used a hand coded hal and ini file.....
- RotarySMP
19 Jul 2020 14:32 #175149
by RotarySMP
Here is episode 24...
Enjoy,
Mark
Enjoy,
Mark
- Thank you received: 7487
19 Jul 2020 16:00 #175158
Replied by tommylight on topic Pimping the mini-lathe
LOL, you are becoming worse than "this old Tony" !
To stop anything in a terminal
ctrl+c
.300 for Z axis ???
ctrl+c
- RotarySMP
19 Jul 2020 17:32 #175165
by RotarySMP
I take that as a compliment thanks.
Ctrl-C - Thanks.
I picked up the .300 instead of 300, but dumped it from the edit as it seemed too boring
Mark
Ctrl-C - Thanks.
Mark
19 Jul 2020 17:38 #175168
It was meant as a compliment, for sure. He is very good at doing such subtle "miss directions", and this was on the same level.I take that as a compliment thanks.
- RotarySMP
20 Jul 2020 06:29 #175223
by RotarySMP
Nice teaser for the next installment of his MAHO retro in this weeks TOT clutch video. He really has a talent for telling a story and explaning.
20 Jul 2020 10:24 #175232
Yes he does, and there are plenty others who try to do what he does, but not nearly as good.Nice teaser for the next installment of his MAHO retro in this weeks TOT clutch video. He really has a talent for telling a story and explaning.
Moderators: piasdom
Time to create page: 0.155 seconds
