Pimping the mini-lathe
26 Jul 2020 14:37 #175903 by tommylight
Replied by tommylight on topic Pimping the mini-lathe
No need for flashing the 7i96, it was already set for the PWM on STEP4 / TB2
26 Jul 2020 14:50 #175906 by PCW
Replied by PCW on topic Pimping the mini-lathe
"fatal: destination path 'mesaflash' already exists and is not an empty directory."
You might try
cd ~
rm -rf mesaflash
and refetch/rebuild
I just did this and I get the TB names
  • RotarySMP
  • RotarySMP's Avatar Topic Author
  • Platinum Member
  • Platinum Member
26 Jul 2020 14:58 #175907 by RotarySMP
Replied by RotarySMP on topic Pimping the mini-lathe
I am sure helping me with this feels like pulling teeth for you.
minilathe@minilathe:~$ cd ~
minilathe@minilathe:~$ rm -rf mesaflash
minilathe@minilathe:~$ refetch/rebuild
bash: refetch/rebuild: No such file or directory
minilathe@minilathe:~$ rebuild mesaflash
Command 'rebuild' not found, did you mean:
command 'debuild' from deb devscripts
command 'rebuildd' from deb rebuildd
I am sorry, that sometimes I stumble on the simplest linux stuff.
26 Jul 2020 15:24 #175912 by PCW
by rebuild I mean
git clone github.com/LinuxCNC/mesaflash.git
cd mesaflash
sudo make install
  • RotarySMP
  • Platinum Member
  • Platinum Member
26 Jul 2020 18:23 #175944 by RotarySMP
It still not giving me the current mesaflash...
minilathe@minilathe:~$ git clone github.com/LinuxCNC/mesaflash.git
fatal: repository 'github.com/LinuxCNC/mesaflash.git' does not exist
minilathe@minilathe:~$ git clone https://github.com/LinuxCNC/mesaflash.git
Cloning into 'mesaflash'...
remote: Enumerating objects: 265, done.
remote: Counting objects: 100% (265/265), done.
remote: Compressing objects: 100% (159/159), done.
remote: Total 1922 (delta 155), reused 193 (delta 103), pack-reused 1657
Receiving objects: 100% (1922/1922), 805.14 KiB | 1.88 MiB/s, done.
Resolving deltas: 100% (1352/1352), done.
minilathe@minilathe:~$ cd mesaflash
minilathe@minilathe:~/mesaflash$ sudo make install
[sudo] password for minilathe:
gcc -O0 -g -Wall -Werror=format -Werror=format-security -std=c99 -D_GNU_SOURCE  -c mesaflash.c
gcc -O0 -g -Wall -Werror=format -Werror=format-security -std=c99 -D_GNU_SOURCE  -c common.c
gcc -O0 -g -Wall -Werror=format -Werror=format-security -std=c99 -D_GNU_SOURCE  -c lbp.c
lbp.c: In function ‘lbp_read’:
lbp.c:75:15: warning: variable ‘recv’ set but not used [-Wunused-but-set-variable]
     int send, recv;
lbp.c:75:9: warning: variable ‘send’ set but not used [-Wunused-but-set-variable]
     int send, recv;
lbp.c: In function ‘lbp_write’:
lbp.c:92:9: warning: variable ‘send’ set but not used [-Wunused-but-set-variable]
     int send;
gcc -O0 -g -Wall -Werror=format -Werror=format-security -std=c99 -D_GNU_SOURCE  -c lbp16.c
lbp16.c: In function ‘lbp16_read’:
lbp16.c:39:9: warning: variable ‘send’ set but not used [-Wunused-but-set-variable]
     int send, recv;
lbp16.c: In function ‘lbp16_write’:
lbp16.c:61:9: warning: variable ‘send’ set but not used [-Wunused-but-set-variable]
     int send;
lbp16.c: In function ‘lbp16_board_reset’:
lbp16.c:75:9: warning: variable ‘send’ set but not used [-Wunused-but-set-variable]
     int send;
lbp16.c: In function ‘lbp16_board_reload’:
lbp16.c:86:9: warning: variable ‘send’ set but not used [-Wunused-but-set-variable]
     int send;
gcc -O0 -g -Wall -Werror=format -Werror=format-security -std=c99 -D_GNU_SOURCE  -c bitfile.c
gcc -O0 -g -Wall -Werror=format -Werror=format-security -std=c99 -D_GNU_SOURCE  -c hostmot2.c
gcc -O0 -g -Wall -Werror=format -Werror=format-security -std=c99 -D_GNU_SOURCE  -c eeprom.c
gcc -O0 -g -Wall -Werror=format -Werror=format-security -std=c99 -D_GNU_SOURCE  -c anyio.c
gcc -O0 -g -Wall -Werror=format -Werror=format-security -std=c99 -D_GNU_SOURCE  -c eth_boards.c
eth_boards.c: In function ‘eth_scan_one_addr’:
eth_boards.c:140:9: warning: variable ‘send’ set but not used [-Wunused-but-set-variable]
     int send = 0, recv = 0, ret = 0;
gcc -O0 -g -Wall -Werror=format -Werror=format-security -std=c99 -D_GNU_SOURCE  -c epp_boards.c
gcc -O0 -g -Wall -Werror=format -Werror=format-security -std=c99 -D_GNU_SOURCE  -c usb_boards.c
gcc -O0 -g -Wall -Werror=format -Werror=format-security -std=c99 -D_GNU_SOURCE  -c pci_boards.c
gcc -O0 -g -Wall -Werror=format -Werror=format-security -std=c99 -D_GNU_SOURCE  -c sserial_module.c
gcc -O0 -g -Wall -Werror=format -Werror=format-security -std=c99 -D_GNU_SOURCE  -c encoder_module.c
gcc -O0 -g -Wall -Werror=format -Werror=format-security -std=c99 -D_GNU_SOURCE  -c eeprom_local.c
gcc -O0 -g -Wall -Werror=format -Werror=format-security -std=c99 -D_GNU_SOURCE  -c eeprom_remote.c
eeprom_remote.c: In function ‘read_page’:
eeprom_remote.c:41:15: warning: variable ‘recv’ set but not used [-Wunused-but-set-variable]
     int send, recv;
eeprom_remote.c:41:9: warning: variable ‘send’ set but not used [-Wunused-but-set-variable]
     int send, recv;
eeprom_remote.c: In function ‘write_page’:
eeprom_remote.c:54:15: warning: variable ‘recv’ set but not used [-Wunused-but-set-variable]
     int send, recv;
eeprom_remote.c:54:9: warning: variable ‘send’ set but not used [-Wunused-but-set-variable]
     int send, recv;
eeprom_remote.c: In function ‘erase_sector’:
eeprom_remote.c:71:15: warning: variable ‘recv’ set but not used [-Wunused-but-set-variable]
     int send, recv;
gcc -O0 -g -Wall -Werror=format -Werror=format-security -std=c99 -D_GNU_SOURCE  -c spi_boards.c
gcc -O0 -g -Wall -Werror=format -Werror=format-security -std=c99 -D_GNU_SOURCE  -c serial_boards.c
serial_boards.c: In function ‘serial_boards_scan’:
serial_boards.c:176:19: warning: variable ‘recv’ set but not used [-Wunused-but-set-variable]
     int send = 0, recv = 0;
serial_boards.c:176:9: warning: variable ‘send’ set but not used [-Wunused-but-set-variable]
serial_boards.c: In function ‘serial_print_info’:
serial_boards.c:217:15: warning: variable ‘recv’ set but not used [-Wunused-but-set-variable]
     int i, j, recv;
rm -f libanyio.a mesaflash
ar rcs libanyio.a common.o lbp.o lbp16.o bitfile.o hostmot2.o eeprom.o anyio.o eth_boards.o epp_boards.o usb_boards.o pci_boards.o sserial_module.o encoder_module.o eeprom_local.o eeprom_remote.o spi_boards.o serial_boards.o
ranlib libanyio.a
gcc -O0 -g -Wall -Werror=format -Werror=format-security -std=c99 -D_GNU_SOURCE  -o mesaflash mesaflash.o libanyio.a -lm -lpci
install -p -D --mode=0755 --owner root --group root mesaflash /bin/mesaflash
install -p -D --mode=0644 --owner root --group root mesaflash.1 /share/man/man1/mesaflash.1
minilathe@minilathe:~/mesaflash$ mesaflash --device 7i96 --addr 10.10.10.10 --readhmid
Configuration Name: HOSTMOT2
  BoardName : MESA7I96
  FPGA Size: 9 KGates
  FPGA Pins: 144
  Number of IO Ports: 3
  Width of one I/O port: 17
  Clock Low frequency: 100.0000 MHz
  Clock High frequency: 200.0000 MHz
  IDROM Type: 3
  Instance Stride 0: 4
  Instance Stride 1: 64
  Register Stride 0: 256
  Register Stride 1: 256
Modules in configuration:
  Module: DPLL
  There are 1 of DPLL in configuration
  Version: 0
  Registers: 7
  BaseAddress: 7000
  ClockFrequency: 100.000 MHz
  Register Stride: 256 bytes
  Instance Stride: 4 bytes
  Module: WatchDog
  There are 1 of WatchDog in configuration
  Version: 0
  Registers: 3
  BaseAddress: 0C00
  Module: IOPort
  There are 3 of IOPort in configuration
  Version: 0
  Registers: 5
  BaseAddress: 1000
  Module: PWM
  There are 1 of PWM in configuration
  Version: 0
  Registers: 5
  BaseAddress: 4100
  ClockFrequency: 200.000 MHz
  Module: StepGen
  There are 4 of StepGen in configuration
  Version: 2
  Registers: 10
  BaseAddress: 2000
  Module: QCount
  There are 1 of QCount in configuration
  Version: 2
  Registers: 5
  BaseAddress: 3000
  Module: SSerial
  There are 1 of SSerial in configuration
  Version: 0
  Registers: 6
  BaseAddress: 5B00
  Instance Stride: 64 bytes
  Module: Transformer
  There are 1 of Transformer in configuration
  Version: 0
  Registers: 2
  BaseAddress: 7D00
  Module: LED
  There are 1 of LED in configuration
  Version: 0
  Registers: 1
  BaseAddress: 0200
Configuration pin-out:
IO Connections for P1
Pin#  I/O   Pri. func    Sec. func       Chan      Pin func        Pin Dir
 1      0   IOPort       None
14      1   IOPort       None
 2      2   IOPort       None
15      3   IOPort       None
 3      4   IOPort       None
16      5   IOPort       None
 4      6   IOPort       None
17      7   IOPort       None
 5      8   IOPort       None
 6      9   IOPort       None
 7     10   IOPort       None
 8     11   IOPort       Transformer      0        Drive           (Out)
 9     12   IOPort       Transformer      0        Ref             (Out)
10     13   IOPort       Transformer      0        Null3           (Out)
11     14   IOPort       Transformer      0        Null4           (Out)
12     15   IOPort       Transformer      0        Null5           (Out)
13     16   IOPort       Transformer      0        Null6           (Out)
IO Connections for TB1
 1     17   IOPort       StepGen          0        Step/Table1     (Out)
14     18   IOPort       StepGen          0        Dir/Table2      (Out)
 2     19   IOPort       StepGen          1        Step/Table1     (Out)
15     20   IOPort       StepGen          1        Dir/Table2      (Out)
 3     21   IOPort       StepGen          2        Step/Table1     (Out)
16     22   IOPort       StepGen          2        Dir/Table2      (Out)
 4     23   IOPort       StepGen          3        Step/Table1     (Out)
17     24   IOPort       StepGen          3        Dir/Table2      (Out)
 5     25   IOPort       PWM              0        PWM             (Out)
 6     26   IOPort       PWM              0        Dir             (Out)
 7     27   IOPort       QCount           0        Quad-A          (In)
 8     28   IOPort       QCount           0        Quad-B          (In)
 9     29   IOPort       QCount           0        Quad-IDX        (In)
10     30   IOPort       SSerial          0        RXData1         (In)
11     31   IOPort       SSerial          0        TXData1         (Out)
12     32   IOPort       SSerial          0        TXEn1           (Out)
Segmentation fault (core dumped)
26 Jul 2020 18:30 #175947 by tommylight
26 Jul 2020 18:44 #175950 by PCW
I wonder if you have another older mesaflash in your executable path...
you might try
cd ~/mesaflash
./mesaflash --device 7i96 --addr 10.10.10.10 --readhmid
To see if that is the case
  • RotarySMP
  • Platinum Member
  • Platinum Member
26 Jul 2020 19:03 #175953 by RotarySMP
You are right tommy, but I would still like to be able to read out the cards state correctly.
PCW, that was correct. with the commands you gave I get the correct hmid readout:
nilathe@minilathe:~/mesaflash$ cd ~/mesaflash
minilathe@minilathe:~/mesaflash$ ./mesaflash --device 7i96 --addr 10.10.10.10 --readhmid
  FPGA Size: 9 KGates
  FPGA Pins: 144
  IDROM Type: 3
  Module: DPLL
  Version: 0
  Registers: 7
  BaseAddress: 7000
  Module: WatchDog
  Version: 0
  Registers: 3
  BaseAddress: 0C00
  Module: IOPort
  Version: 0
  Registers: 5
  BaseAddress: 1000
  Module: PWM
  Version: 0
  Registers: 5
  BaseAddress: 4100
  Module: StepGen
  Version: 2
  Registers: 10
  BaseAddress: 2000
  Module: QCount
  Version: 2
  Registers: 5
  BaseAddress: 3000
  Module: SSerial
  Version: 0
  Registers: 6
  BaseAddress: 5B00
  Module: SSR
  There are 1 of SSR in configuration
  Version: 0
  Registers: 2
  BaseAddress: 7D00
  Module: LED
  Version: 0
  Registers: 1
  BaseAddress: 0200
IO Connections for TB3
TB3 1                   0   IOPort       None
TB3 2                   1   IOPort       None
TB3 3                   2   IOPort       None
TB3 4                   3   IOPort       None
TB3 5                   4   IOPort       None
TB3 6                   5   IOPort       None
TB3 7                   6   IOPort       None
TB3 8                   7   IOPort       None
TB3 9                   8   IOPort       None
TB3 10                  9   IOPort       None
Internal               10   IOPort       None
TB3 13,14              11   IOPort       SSR              0        Out-00          (Out)
TB3 15,16              12   IOPort       SSR              0        Out-01          (Out)
TB3 17,18              13   IOPort       SSR              0        Out-02          (Out)
TB3 19,20              14   IOPort       SSR              0        Out-03          (Out)
TB3 21,22              15   IOPort       SSR              0        Out-04          (Out)
TB3 23,24              16   IOPort       SSR              0        Out-05          (Out)
IO Connections for TB1/TB2
TB1 2,3                17   IOPort       StepGen          0        Step/Table1     (Out)
TB1 4,5                18   IOPort       StepGen          0        Dir/Table2      (Out)
TB1 8,9                19   IOPort       StepGen          1        Step/Table1     (Out)
TB1 10,11              20   IOPort       StepGen          1        Dir/Table2      (Out)
TB1 14,15              21   IOPort       StepGen          2        Step/Table1     (Out)
TB1 16,17              22   IOPort       StepGen          2        Dir/Table2      (Out)
TB1 20,21              23   IOPort       StepGen          3        Step/Table1     (Out)
TB1 22,23              24   IOPort       StepGen          3        Dir/Table2      (Out)
TB2 2,3                25   IOPort       PWM              0        PWM             (Out)
TB2 4,5                26   IOPort       PWM              0        Dir             (Out)
TB2 7,8                27   IOPort       QCount           0        Quad-A          (In)
TB2 10,11              28   IOPort       QCount           0        Quad-B          (In)
TB2 13,14              29   IOPort       QCount           0        Quad-IDX        (In)
TB2 16,17              30   IOPort       SSerial          0        RXData0         (In)
TB2 18,19              31   IOPort       SSerial          0        TXData0         (Out)
Internal               32   IOPort       SSerial          0        TXEn0           (Out)
Internal               33   IOPort       SSR              0        AC Ref          (Out)
 1                     34   IOPort       None
14                     35   IOPort       None
 2                     36   IOPort       None
15                     37   IOPort       None
 3                     38   IOPort       None
16                     39   IOPort       None
 4                     40   IOPort       None
17                     41   IOPort       None
 5                     42   IOPort       None
 6                     43   IOPort       None
 7                     44   IOPort       None
 8                     45   IOPort       None
 9                     46   IOPort       None
10                     47   IOPort       None
11                     48   IOPort       None
12                     49   IOPort       None
13                     50   IOPort       None
What should I do to remove the incorrect instance?
26 Jul 2020 19:19 #175954 by PCW
You could run
which mesaflash
and find out where the old one is and either delete it or overwrite it with the new one
  • RotarySMP
  • Platinum Member
  • Platinum Member
26 Jul 2020 19:29 #175955 by RotarySMP
It only returned one in /usr/bin/mesaflash
Moderators: piasdom
Time to create page: 0.167 seconds
