Pimping the mini-lathe
04 Aug 2020 08:02 #177194 by machinedude
Replied by machinedude on topic Pimping the mini-lathe
vibration has been my go to method but on something that big it was it was impossible so tamping it down as you go was what i was able to do. mixing that much material by hand is not the best way to go about it but that was what i ended up doing. don't care to do it again :)
04 Aug 2020 08:10 #177195 by machinedude
a small cement mixer would work well but the clean up would be impossible with epoxy. if you could line the mixer with a plastic bag of some sort that might work for clean up? what ever is used for mixing gets destroyed pretty much so on something big you would need something to act as a disposable liner if a mixer was used.
  • RotarySMP
  • RotarySMP's Avatar Topic Author
  • Platinum Member
  • Platinum Member
04 Aug 2020 10:10 - 04 Aug 2020 10:31 #177208 by RotarySMP
Replied by RotarySMP on topic Pimping the mini-lathe
I used a concrete vibration motor to vibrate the parts I made. I guess you could clean out the concrete mixer with a few shovels full of gravel and gallon of acetone after the last mix. Any remaining epoxy would be soon worn out once you used it for concrete again.
Last edit: 04 Aug 2020 10:31 by RotarySMP.
04 Aug 2020 12:40 #177231 by Mike_Eitel
Replied by Mike_Eitel on topic Pimping the mini-lathe
For my epoxy stuff (making diving rebreathers) i sucessfully use normal cheep candel wax. If geting out is a problem, heatgun is yourbest friend.
Mike
  • RotarySMP
  • Platinum Member
  • Platinum Member
06 Aug 2020 13:12 - 06 Aug 2020 13:20 #177507 by RotarySMP
I cleaned up my wiring diagrams (attached). Pretty simple so far.
Mark
Last edit: 06 Aug 2020 13:20 by RotarySMP.
  • RotarySMP
  • Platinum Member
  • Platinum Member
07 Aug 2020 10:36 #177591 by RotarySMP
Just playing around, what is the syntax to use natural constants like Pi or "e" in gcode?
#<103>=[pi/e]
Mark
  • RotarySMP
  • Platinum Member
  • Platinum Member
07 Aug 2020 11:43 #177598 by RotarySMP
Given that my lathe only uses a fraction of the 7i96's capacity (2 Stepgen, 1 ENC and 1 Pwmgen) at present, would it be possible to add a further encoder through mesaflash to read a jog wheel? I looked through the bit files, and see there is one that looks like it converts to six ENC (7i96_6enc_d.bit). What would I need to do to make a 1pwmgen+ 1 addition ENC bitfile?
Actually given that jogwheels are only 100 PPR, and the normal input pins are read at 1kHz, I can't hand jog at 10 RPS anyway, so there is probably no disadvantage of puttnig the jog wheel onto general I/O except that they need a few pins.
Bonus question, would it be possible to reconfigure both the two unused Stepgens to ENC? With two stepgens, 1 pwmgen, and 3 Enc (the existing one plus two more), I could add linear encoders to the two axis, and run the jog wheel off I/O. That would be awsome for a lathe.
Mark
07 Aug 2020 12:03 #177601 by tommylight
Replied by tommylight on topic Pimping the mini-lathe
I do not think so
stepgens = outputs
enc = inputs
but you do have a 26 pin header that you can use for anything and they are very fast, so there is room for some 8 more encoders there.
  • RotarySMP
  • Platinum Member
  • Platinum Member
07 Aug 2020 12:19 - 07 Aug 2020 12:19 #177605 by RotarySMP
Good point Tommy, but then why is there a 5ENC bit file?
Last edit: 07 Aug 2020 12:19 by RotarySMP.
07 Aug 2020 12:54 #177613 by tommylight
No idea, never had a 7i96, yet.
Moderators: piasdom
Time to create page: 0.136 seconds
