- Thank you received: 5334
Pimping the mini-lathe
6 years 4 months ago #171443
Replied by PCW on topic Pimping the mini-lathe
As long as you have loaded the
7i96d_1pwm.bit
Bitfile, PWM should be present, as long as it's not disabled in the hal file
with a "num_pwmgens=0" token in the hm2_eth driver command line.
7i96d_1pwm.bit
- RotarySMP
- Thank you received: 595
6 years 4 months ago #171447
by RotarySMP
Replied by RotarySMP on topic Pimping the mini-lathe
Thanks PCW. The 7i96 is currently in the "as delivered"configuration. Is that the default bitfile which MESA loads?
Mark
Mark
6 years 4 months ago #171454
The as shipped 7I96 has the 7i96d.bit bitfile loaded
This has 5 stepgens and no PWM.
To load 7i96d_1pwm.bit you would need to fetch the 7i96.zip archive from Mesa,
extract the 7i96d_1pwm.bit bitfile and run these commands:
mesaflash --device 7i96 --addr [the cards current ip address] --write 7i96d_1pwm.bit
mesaflash --device 7i96 --addr [the cards current ip address] --reload
- RotarySMP
6 years 4 months ago #171466
by RotarySMP
Thanks very much.
- RotarySMP
6 years 4 months ago #171589
by RotarySMP
Episode 19 is now up...
Happy fathers day.
Mark
Happy fathers day.
Mark
The following user(s) said Thank You: tommylight, StoneB
- StoneB
6 years 4 months ago #172004
by StoneB
Replied by StoneB on topic Pimping the mini-lathe
Hi Mark - it's amazing how much work you're putting it this small lathe, and I love the IKEA shelves idea.
Look forward to see movement, now that we're moving to the CNC part!
Will you be reutilizing the acetal ballscrew mounts, or are we in for a Maho threadmilling video soon?
Pierre
Pierre
Moderators: piasdom
Time to create page: 4.036 seconds
