Pimping the mini-lathe
6 years 3 months ago #173660 by RotarySMP
Replied by RotarySMP on topic Pimping the mini-lathe
I now have Episode 22 up...
Enjoy,
Mark
The following user(s) said Thank You: phillc54, tommylight
6 years 3 months ago - 6 years 3 months ago #173712 by RotarySMP
I should have my little NUC powered up today. I remember that it was a PITA to get it to boot from USB. I had to dick around in some UEFI settings I didn't understand. I got it to boot more by luck than by skill, and now have the standard LinuxCNC 2.7 image on it.
I understand that need to both upgrade this to 2.8 and alter the Linux Kernal to replace RTAI with Preempt_rt for the 7i96 driver to work.
Peter (Talla83) has an excellent video on how to do a clean install, but I was wondering if I can use APT-GET or SPM to make the changes to the existing install?
Mark
Last edit: 6 years 3 months ago by RotarySMP.
6 years 3 months ago #173728 by tommylight
Replied by tommylight on topic Pimping the mini-lathe
Linux Mint
forum.linuxcnc.org/9-installing-linuxcnc...nd-easy-installation
Debian 10
forum.linuxcnc.org/9-installing-linuxcnc...ick-and-easy-install
Most probably you can change the kernel and for sure you can install 2.8, but if you have RTAI, that is Debian Wheezy so there is no support for it, meaning anything you want to install is going to be a pain.
6 years 3 months ago #173740 by rodw
Replied by rodw on topic Pimping the mini-lathe
Don't listen to Tommy, Mark. Everybody who uses a Gigabyte Brix really should experience the fun of compiling the kernel on Linux Mint like I had to do before we had all these various shortcuts.
I still recall the horrors 4 years later........
I've got an Odroid H2+ motherboard coming in the next few days which I hope I will let me do something similar to what you are doing but my Brix is mounted to the back of the monitor... Its a bit messy there though. Lots of coiled up cables....
I'm thinking though my next cabinet will be a DIY plasma cut version so all the holes are cut before its folded up. So I'll only need zero tools! I did a simple one the other day and it came up like a bought one once it was powder coated!
6 years 3 months ago - 6 years 3 months ago #173743 by RotarySMP
Thanks guys.
Rod, I bought the Brix because you seemed so enthusiast about it. Little did I know you were into S&M and just trying to lure an unsuspecting victim into your fetish world :)
Thanks Tommy, So I can't avoid try to get something to boot from USB again. Bummer.
Mark
6 years 3 months ago #173745 by tommylight
RotarySMP wrote: Thanks Tommy, So I can't avoid try to get something to boot from USB again. Bummer.
Mark
LOL on S&M, he seems to be quite into it, mostly the M part of it ! :)
Mint will boot and install even on UEFI as i tested on 2 PC's, not sure about Debian as i never tested it on UEFI machines.
Moderators: piasdom
Time to create page: 3.561 seconds
