OLD Latche conversion to a CNC
- besriworld
- Thank you received: 48
14 May 2024 05:53 #300553
by besriworld
OLD Latche conversion to a CNC was created by besriworld
It's one of those stupid/crazy CNC lathe projects. If I could turn back time, this project would not exist.I will try to upload more pictures but not everything is documented ..
We bought an old machine probably 2 tons of iron and immediately begins disassembly, washing and painting
I threw out a lot of parts from the gearbox
This is the first layout of the electrical cabinet
I have reached the maximum number of files allowed .I will continue in the next post
- besriworld
14 May 2024 06:21 #300554
by besriworld
Replied by besriworld on topic OLD Latche conversion to a CNC
Here I am sanding the back end of the spindle.
I made two parts that grip the spindle Pulley V-groove .This part has a cone from the outer part, the second part (not in the pictures) presses the first part to the axis of the spindle.
I keep the original oil pump. It was necessary to make several parts.
We put linear guides. They had to be level and make holes for threads.
The following user(s) said Thank You: tommylight, Aciera
- besriworld
14 May 2024 19:49 #300596
by besriworld
- besriworld
14 May 2024 20:00 #300597
by besriworld
- Thank you received: 6092
14 May 2024 20:57 #300606
Replied by tommylight on topic OLD Latche conversion to a CNC
Looking nice.
And i need help, professional help, i was looking at pictures and started thinking "hey i could do this to my manual lathe"... i have to go past the Mazak to get to manual lathe, Mazak being already CNC and retrofitted and working, sans the hydraulic chuck!
![:) :)](/media/kunena/emoticons/smile.png)
- besriworld
15 May 2024 06:28 - 15 May 2024 06:40 #300656
by besriworld
Thanks!
Yes, we all seem to have a professional distortions
A few more pictures of the control panel.
It's not perfect but I like it![:) :)](/media/kunena/emoticons/smile.png)
First there is a primer, then a paint base and clear varnish. Then I engraved it on the router. I used a white paint base for filling. But it would be better with a white body filler
Last edit: 15 May 2024 06:40 by besriworld.
The following user(s) said Thank You: tommylight, TangentAudio
- TangentAudio
- Thank you received: 19
20 May 2024 16:55 #301016
by TangentAudio
Replied by TangentAudio on topic OLD Latche conversion to a CNC
Great project, and nice workmanship! The control panel looks great in the photo!
Is the board with the orange heat sink an HDMI to LVDS board for the display?
- besriworld
20 May 2024 18:39 #301021
by besriworld
Yes, this is the display board. By modern standards the display is very small 10.1"
with 2k resolution .
25 May 2024 05:11 #301373
by jimmyrig
Replied by jimmyrig on topic OLD Latche conversion to a CNC
Looks great, love the control panel design.
The following user(s) said Thank You: RotarySMP, besriworld
25 May 2024 10:11 #301397
Replied by andypugh on topic OLD Latche conversion to a CNC
My CNC lathe is a converted manual, but I kept it a lot more original in some ways, and much less so in others (I had a bunch of custom castings made to replace the apron and the feeds gearbox, for example)
For the kind of projects I do the layout of a conventional lathe, without full enclosure, makes more sense.
bodgesoc.blogspot.com/2015/08/holbrook1.html
Moderators: piasdom
Time to create page: 0.615 seconds
