- Thank you received: 92
OLD Lathe conversion to a CNC
- besriworld
- Topic Author
It works, so easy. Thanks again! I am also adding a new drilling video.
- besriworld
- Topic Author
sudo chrt ping -i .001 -q -c 60000 10.10.10.10
(takes 1 minute)
and
lspci | grep -i eth
docs.google.com/document/d/1jeV_4VKzVmOI.../edit?usp=drive_link
- besriworld
- Topic Author
moriseiki@debian:~$ sudo chrt -f 99 ping -i .001 -q -c 60000 10.10.10.10
PING 10.10.10.10 (10.10.10.10) 56(84) bytes of data.
--- 10.10.10.10 ping statistics ---
60000 packets transmitted, 60000 received, 0% packet loss, time 59999ms
rtt min/avg/max/mdev = 0.065/0.074/0.241/0.007 ms
moriseiki@debian:~$ lspci I grep -i eth
Usage: lspci [<switches>]
Basic display modes:
-mm Produce machine-readable output (single -m for an obsolete format)
-t Show bus tree
Display options:
-v Be verbose (-vv or -vvv for higher verbosity)
-k Show kernel drivers handling each device
-x Show hex-dump of the standard part of the config space
-xxx Show hex-dump of the whole config space (dangerous; root only)
-xxxx Show hex-dump of the 4096-byte extended config space (root only)
-b Bus-centric view (addresses and IRQ's as seen by the bus)
-D Always show domain numbers
-P Display bridge path in addition to bus and device number
-PP Display bus path in addition to bus and device number
Resolving of device ID's to names:
-n Show numeric ID's
-nn Show both textual and numeric ID's (names & numbers)
-q Query the PCI ID database for unknown ID's via DNS
-qq As above, but re-query locally cached entries
-Q Query the PCI ID database for all ID's via DNS
Selection of devices:
-s [[<domain>]:]<bus>]:][<slot>][.[<func> Show only devices in selected slots
-d [<vendor>]:[<device>][:<class>] Show only devices with specified ID's
Other options:
-i <file> Use specified ID database instead of eth
-p <file> Look up kernel modules in a given file instead of default modules.pcimap
-M Enable `bus mapping' mode (dangerous; root only)
PCI access options:
-A <method> Use the specified PCI access method (see `-A help' for a list)
-O <par>=<val> Set PCI access parameter (see `-O help' for a list)
-G Enable PCI access debugging
-H <mode> Use direct hardware access (<mode> = 1 or 2)
-F <file> Read PCI configuration dump from a given file
6.1.n kernel has huge latency and networking issues that are frankly getting to damn tiresome to read about them daily for nearly two years.
I have 6.8.n and 6.10.n on laptops without any issues.
