OLD Lathe conversion to a CNC
1 year 6 months ago #326889 by andypugh
This looks very odd. It looks like a gmoccapy glitch, but can you try the same sequence in:
1) The gmoccapy lathe sim config
2) The axis lathe sim config
And see if you see the same behaviour?
1 year 6 months ago #326900 by besriworld
I guess there is a problem with the hall configuration. Today I broke 2 carbide inserts. After 10 made parts the axis started to move with a larger feed. But not too much, maybe 20-30% more. I tried in simulation but I don't know how to load my configuration into the simulation. There is no problem with the sample configurations.
1 year 6 months ago #326923 by PCW
Replied by PCW on topic OLD Lathe conversion to a CNC
Not sure if it's related, but here is a similar issue, also using gmoccapy:
forum.linuxcnc.org/20-g-code/44739-g96-issue
1 year 6 months ago #326934 by besriworld
It seems that the two problems are related. I just have to try another gui
1 year 6 months ago - 1 year 6 months ago #326962 by besriworld
Today I ran some more tests. I can now reproduce the issue described in the other thread with 100% consistency. I noticed that when the Z-axis is moving, G96  doesn't seem to be working. I recorded a video showing that the spindle speed doesn't change at all during the movement.
PS. I think there might be something wrong with the HAL configuration. I just noticed that when starting LinuxCNC, I need to go into the calibration settings and re-save the PID values for the spindle (I enter test). If I don’t do that, the PID control is soft– under higher spindle load, it triggers a hold  .Also, if I leave LinuxCNC running idle (without running a program) for about an hour, and then start program execution again, the axis movement speed during a G1 command is once again higher than what was set.
Last edit: 1 year 6 months ago by besriworld.
1 year 6 months ago #327171 by besriworld
Today I started the program with the axis graphical interface. No change, the problem remains. Could someone check the HAW connections?
this problem also exists : " ... I just noticed that when starting LinuxCNC, I need to go into the calibration settings and re-save the PID values for the spindle (I enter test). If I don’t do that, the PID control is soft– under higher spindle load, it triggers a hold .Also, if I leave LinuxCNC running idle (without running a program) for about an hour, and then start program execution again, the axis movement speed during a G1 command is once again higher than what was set."
Time to create page: 0.188 seconds
