developing drivers for custom boards
- btvpimill
- Thank you received: 3
function read
function write
In that order. Does that mean the read will be first then the write or is that controlled by the HAL file?
- Thank you received: 4992
but how do I tell it to always generate the start but never worry about the reset? Or if I need to keep the reset thread in there, how to not actually send the reset to the port?.
Setting the space_length to zero in the HAL file does this.
Yup, another thing came to mind. In the comp file I have:
function read
function write
The execution order is set by the HAL file, it is the order that the functions are added to the thread in.
- btvpimill
This way I can not worry about having the threads in the wrong order.
Now PCW may have already suggested I do it this way, But I took his advice to mean a single address write then clock all the data both ways. So PCW, if you did mean that, it only took me a week to come around and see it - LOL
- btvpimill
sudo comp --install/somewhere/eppdriver.comp
here are the errors:
ruby@ruby-desktop:~$ sudo comp --install /home/ruby/emc2/configs/eppdriver.comp
[sudo] password for ruby:
File "/usr/bin/comp", line 1321, in <module>
main()
File "/usr/bin/comp", line 1290, in main
process(f, mode, outfile)
File "/usr/bin/comp", line 1164, in process
a, b = parse(filename)
File "/usr/bin/comp", line 404, in parse
a, b = f.split("\n;;\n", 1)
ValueError: need more than 1 value to unpack
now not really knowing if thesew are errors, warnings, or flat out failures, I tried to load it in my hal file:
loadrt eppdriver ioaddr=0x378
won't load, message after all the intresting stuff is:
can't find module 'eppdriver' in usr/realtime......
I looked and in fact it is not there. So I can only assume there was a real problem with the comp --install? The comp file is the one I posted here with only the base_address +3 changes
- btvpimill
- btvpimill
www.linuxcnc.org/component/option,com_ku...tart,0/lang,english/
I am not clear to how the OP resolved the same exact error I have, But I am going to make sure the file is "clean" Update in just a bit.
- btvpimill
- BigJohnT
- Thank you received: 1176
- BigJohnT
component constant;
pin out float out;
param r float value = 1.0;
function _;
license "GPL";
FUNCTION(_) {
out = value;
